Question about Microwave Ovens
My microwave was made in march 1984. the serial numbers have been rubbed off on the door. the fan & lights etc work but it won't heat up...what can i do?
    Sergeant:
  • 269 Answers
HI! the magnetron on your microwave is not working, first thing that you should is check for the fuse or the thermal cut off.
Posted on Sep 23, 2009
My microwave would not turn off. Door closed and light/turntable off, the microwave continues to work when not selected on.
We are very sorry to hear this and we apologize for the inconvenience this has caused you. We would be glad to look into this if you could email us at Whirlpool_Digital@Whirlpool.com with your name, address, phone number and the model & serial numbers of the Microwave.
Mar 09, 2017 | Whirlpool GT4185SK Microwave Oven
Not heating
Please post a new help request here on FixYa and include the full model number from the tag in the cooking cavity or elsewhere on the microwave, such as the door frame, controller frame, etc. and please answer the questions below.
When you hit "Start" to microwave, do the inside light, cooling fan, and turntable all come on?
Any unusual noises? Is it louder or quieter than usual?
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here
May 04, 2013 | Hamilton Beach Microwave Ovens
Microwave light stays on and unit won't heat/run
If it's not heating at all, the magnetron is to blame.
May 26, 2012 | GE JVM1330BW/WW Microwave Oven
I have a GE JES831WB 001 microwave that I'd love to fix. The light, clock & timer are working, but that's all - no fan nor heating. Any suggestions?
The door switches are often a problem, one or two are probably defective which would cause the symptoms that you are describing.
Apr 05, 2012 | Microwave Ovens
What is the serial # range for GE Spacemaker microwaves vintage 1984-1985
That would be difficult to track down, but you can use a universal door switch "open or closed " selection making it handy, some tv repair shops still may carry some parts, appliance repairman another choice.
Mar 06, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave not working (generating heat)
Please check the door switch for proper operation.
May 19, 2010 | Frigidaire PLMV168 Microwave Oven
GE 1800 XL not heating, no power, except fan works and clock also
Hello :
It could be bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
or it could be problem with the control panel .
good luck .
please rate !
Mar 29, 2010 | GE XL1800 1100 Watts Microwave Oven
Microwave not heating.
1 thing here you can check yourself. You need to remove the cover of the microwave. Make sure it is unplugged first. To remove the cover there should be a series of phillips head screws on the backside of the microwave. Once the screws are removed then you need to lift the back of the case towards the front there is a lip at the front that holds the front down that is why you need to lift the case from the back. Once you have accessed the inside follow the powercord from the plug into the microwave along this cord you will see a fuse. Very IMPORTANT do not touch both sides of the fuse holder at the same time. There is a charge stored in the microwave that will curl you hair remove this fuse with a fuse puller (purchased at an auto parts house) Take the fuse to an appliance parts house for replacement. Should be in the area of 10.00 or so. Replace the fuse put the casing back together and try the microwave. If it doesn't work then the magneto or magnatron whichever the machine has is blown and in that case it is cheaper to buy a new microwave
Good luck hope this helped you some
Dave
Jan 18, 2010 | GE JVM1540DM Microwave Oven
Microwave seems to run, but won't heat.
We have a similar problem! It sounds like a problem with the microswitch inside the unit that the door is suppose to engage when closed. If not engaged properly, it will not cook. We had the switch replaced last March but it has started acting up again. We can press in on the door and/or lift it slightly and it will cook. Try putting time on the counter and hit start. It the word "cook" appears then try moving the door slightly and see if the turntable starts turning. If not, then you may have a more serious problem. Good luck!
Oct 09, 2009 | Frigidaire FMV156DC Microwave Oven
Microwave on w/light but fan and heat not working
The problem is the door switch is defective. I'm on my third new switch in 3 years. The part number is 5304440026.
Mar 29, 2009 | Electrolux Microwave Ovens
Microwave Ovens Logo
24 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
