Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Hose attachment doesn't work
My 5914-900 is only a couple of months old. I've never used the hose attachment because the brushes won't turn. It works fine except for this. What could be wrong? Thanks
  • 1 more comment
  • mareem56 Oct 12, 2009
    Everything works fine except the brushes on the hose attachment. Thanks
  • rkintz May 11, 2010
    Please clarify: Are you saying the brushes on the floor do not turn, or the brushes on the hand tool?
    Scholar:
  • 190 Answers
If there is sufficient suction at the end of the hose, the brushes should turn. Temporarily cover the rectangular opening that contacts the carpet/upholstery. This increases the suction to the air turbine, and may start it. The only other thing the user can do is to try to turn one of the brushes to assure the components rotate internally. It will not rotate easily.
Posted on Oct 13, 2009
Sweeper stopped after using wand
Hi there, it's Jack at Dyson.
Most of our vacuums include a thermal cut out, which shuts the machine off if it starts to overheat. Usually this will be because the filter needs a wash, or because there's a blockage in the machine. From what you've described it sounds like there's a blockage in the hose, wand or duct.
To resolve this, please follow the steps shown in our online Support guide: http://content.dyson.com/support/help.asp?article=954&product=DC17-ANIMAL
It's important to wash your machine's filter at least once every 3-6 months, as shown in the video above. Use cold water without detergent, and allow at least 24 hours for it to dry completely before replacing it.
This should resolve the issue, but if you would like some further advice from our experts, please email us at askdysonUS@dyson.com. We'll be in touch as soon as possible.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Apr 30, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
Can I turn off the brushes when using the hose attachement?
Nope, unless you see a big button on top of the hood that says brush. (which I doubt it does) That brush will stay running. It doesn't hurt anything really. When you lean the machine to upright it lifts the brush up off the floor.
Feb 02, 2013 | Hoover UH70120 WindTunnel TSeries Rewind...
My vac cleaner doesn't pick up.
There could be a few things that would cause your Dyson to have no suction. I will give you detailed step by step instructions along with pictures on how you can diagnose this.
Possible Problem #1. The first problem is extremely common. In fact, we probably see between 2-3 of these problems every week. It mostly happens after people take the bottom plate off the vacuum in order to clean the roller brush. What happens is when they reinstall the bottom plate, they put it on on incorrectly. It's actually very easy to do. When the bottom plate (soleplate) is installed wrong, there will be a gap between the bottom plate, and the agitator housing, or the purple tray the roller brush sits in. This will cause the soleplate to be a few inches higher off the ground then it should be, preventing the brushes from even hitting the carpet. This makes it seem to the user that vacuum has lost suction power because without the brushes hitting the carpet, the machine will not pick up very well on floors, but when they use the attachment hose there's plenty of suction power.
Here's a picture of the WRONG way to install the bottom plate. Notice the gap in between the two housings:
Here's another picture, that is the RIGHT way to install the soleplate:
I would say probably 6 times out of 10 this is the problem with the customers machine. If you checked the soleplate and it is installed correctly, move on to the second possible problem.
Possible Problem # 2. Turn the vacuum cleaner upside down so the brush roller is facing upwards. I found the easiest way to work on it is to put it on a counter top or work bench. On the left hand side behind the roller brush you should see a flexible transparent hose that goes from the motor to the agitator housing. This hose actually has a lot of strain on it when the vacuum cleaner is in the reclined position. When the first few series of Dyson DC07 models came out, they didn't make this hose long enough, so when the vacuum was in the reclined position, it would put too much stress on the hose, and cause the hose to actually crack, usually right where the end of the hose that goes into the agitator housing. Examine your hose and see if you have any visible cracks in this hose. If you need to you may just remove the entire hose assembly by pulling on it. It will easily come right out of the machine so you can inspect it better. Here's a picture of where the hose usually cracks:
This would also explain why the vacuum works fine when using the attachments, but not on the floors. The attachment hose uses a different suction channel, and when the machine is in the upright position, no suction goes through this hose. If you do find a crack in this hose, the this hose needs to be replaced. Here's a direct link to that hose on our GoVacuum website.
Dyson DC-07 & DC-14 Upright Replacement Internal Hose Part # 904219
Possible Problem #3. I would suspect that this may not be the problem, but if neither of the solutions above worked, then try this one. Dyson's in general are prone to clogging. There are a few clog ports throughout the vacuum cleaner that were added there due to Dyson prototypes becoming clogged at these points. Here are pictures of how and where to check for these clogs. Simply remove the suction port covers at both of these locations:
Possible Problem #4. If none of the above solutions worked for you, try this last one. The Dyson DC07 models use a clutch mechanism that stops the roller brush from spinning when changed from carpet mode to bare floor mode. This clutch mechanism is a notorious problem with all Dyson models, in fact they were such a problem that Dyson had to redesign the DC07 model to a non-clutch system. Even if yours is one of the newer ones that don't use a clutch, yours still has a belt inside. You can tell if your model uses a clutch or not by the shape of the roller brush. If your brush is a perfect cylinder shape, yours does NOT have a clutch. To check and see if the clutch or the belt have gone bad, first release the handle on the vacuum as if you were vacuuming carpets. Make sure the machine is set to carpet mode. Now while the handle has been released, turn the machine upside down and see if the brushes are spinning. If the brushes are spinning then turn the vacuum right side up and put the brushes on the floor. Can you still hear the brushes spinning when they are hitting the carpet? If yes, then this is not the problem. If the brushes however are NOT spinning, this indicates either your brush roll, clutch, or belt have gone bad.
Jan 13, 2013 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My hover extract deep cleaner won't spray water or cleaning solution
If you have the receipt from when you bought it, take it to the closest Hoover warranty center and they will fix it under the warranty at no cost to you.
Jun 11, 2017 | Hoover F7431-900 SteamVac Vacuum
Shark SV736R motorized brush won't rotate
The 2 metal pins of the motorized brush are not in contact with the vacuum cleaner. or the Motorized brush is clogged up. You have mentioned that it is cleaned, but still give a thorough inspection. For the metal pins, firmly insert the motorized brush into the air-intake nozzle. This will connect the motorized nozzle to the unit power supply.
Oct 21, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I have the bissell pro heat turbo microban cleaner. It's about 2 1/2 years old and maybe used 8 times. The brushes do not work and it's not suctioning up the water. I've checked the belt on...
You already said it, so check the carbon brushes. Once it is no longer able to push the rotor or stator it need to be replace. Carbon brushes are customized at the machine shop, so you should bring it so that you have a sample of the brushes itself. Just be observant when disassembling the motor so that you put it back to exact place.
Thanks for asking.
Jul 13, 2011 | Bissell ProHeat Turbo Deep Cleaner Upright...
My vacuum isn't cleaning/suctioning very well. The hose attachment will work and pick up debris but the main part of the vacuum (where the brush is) doesn't pick up. The brush only spins but there...
Check to see if the brush is turning when you have the vac on and the handel down 'of course keep your hands from that area when doing this ,you might have to lean the vac ,to see the resaults.
Jul 09, 2011 | Panasonic MC-V7582 Bagless Upright Vacuum
Where is the belt located on my hoover steam shampoer
There is probably not a belt. The brushes on the carpet cleaner head and attachments work from air and there is a roller bearing deep inside that will wear out and the brushes won't turn. I've found no way to fix this. I consider it a design defect.
Apr 20, 2011 | Hoover SteamVac Carpet/Upholstery Deep...
Old Kirby Heritage 2 (Model 2Hd ) won't power on
the power light is a 2 stepswitch make sure when u put yhe power head back on it is locking all the way back if so and not working the switch may have failed
Jul 10, 2009 | Kirby Vacuums
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
130 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
