Question about Philips 9P5034C 50" Rear Projection Television
9P5034c 52 inch
Picture was half size with green red and blue outlines around it
until it warm up. This happened for a few weeks, now it doesn't have picture or sound at all but the light comes on and you can hear a noise as the power comes on. Green ooze is coming out of the bottom of one of the picture tubes could this be the problem or did something else cause that
  • Philips Master
  • 8,617 Answers
Your crt coolant is leaking and thats whats wrong with your set as the coolant causes corrosion on the chassis. You will need to remove your crt clean and repair the seal put new coolant into it then clean your circuit boards relly good resolder any components that got affected. and hopefully it will be allright. If you need instructions on how to remove your CRT and discharge it sfafely go to the following link for 10.99 they have your service manual and offer unlimited support to help you. They will even email the manual to you if you return to the store and click on the contact us link and provide your email address they will also email the instructions on how to obtain support. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Jan 17, 2008
The picture looks like a bowtie and red blue and
TURN YOUR COLOR OFF.IF YOU SEE THE RED,BLUE AND GREEN AROUND THE EDGES EX.SOMEONES FACE YOU CONVERGANTS IS OUT NEEDS RE LINEMENT.
Apr 24, 2010 | RCA Televison & Video
My RCA big screen picture messed up after one of my children fell nto screen?? How can I fix this
The picture on my 52 inch RCA Projection television has green, red and blue squiggly lines around the objects on the screen and the picture looks 3-D.
Oct 30, 2009 | RCA P52960 52" Rear Projection Television
My ge has to warm up to get a picture
CRT televisions usually do somewhat of a warming up before the picture looks normal. These sets monitor the performance or current drain of each CRT (red, green and blue) and if they are out of balance meaning one CRT is weaker than the others it will wait until they are somewhat balanced before it allows the picture to come up. Its a sign of aging on the CRT's and is to be expected.
Oct 17, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
Color picture jumps in and out of normal color mode . . .
You have bad solder connection in or around the Jungle IC and or color processing Circuits. Most commonly the area is the color cyrstal, located on the main board.
Oct 10, 2009 | Televison & Video
52 Inch Zenith TV has red blue and green squiggly lines what is wrong, no picture
I belive that the red light means that it is off and the blue means that its on
Jun 10, 2009 | Zenith D52WLCD 52" Rear Projection...
Philips Magnovox Rear Proj. TV wont keep vertical/horizontal hold
Hello clifftonian,
I would suggest checking the HV trippler block and the voltage output from the IHVT (Integrated High Voltage Transformer), and comparing them against the schematic diagram. In addition to this after solving your HV problem I would suggest doing a complete convergence adjustment, both static and dynamic. Just don't go replacing parts because that approach does more harm then good. Troubleshoot the problem and find out what other parts are marginal and replace them all. Your stepdad is correct with a good place to start.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Apr 01, 2009 | Philips Magnavox 9P6034C 60" Rear...
How do i get a crystal clear picture on this set?
Your tv is experiencing convergence problem. if you have tried the perfect focus adjustment from the menu and still not fixed, then the convergence ics need to be replaced. these ics converge the blue and red beams with the green to give a clear picture.
Hope this helps
please rate me!
Mar 19, 2009 | Philips 9P5034C 50" Rear Projection...
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
Picture jumps after a few hours turned on
I have a 3 yr old 55 inch mitsubishi TV and when I turn it on the green light starts flashing and I must reset the TV about four times before it finally comes on has anyone had this problem if so what solution did you have?
Jul 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Philips 9P5034C 50" Rear Projection Television Logo
37 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
