Question about Generic Memory Electronics - Others
I have a usb that has 2gb of files I can longer access I know this because in properties it shows that they are there yet when I open it they are not. Windows did something to them when I had the stick in at start up.It went through correcting files. I did a back up and the files are showing file 000. chk any idea as how i can restore the files ? Is the stick still ok ?
  • 3 Answers
Is it transcend make. if so go to www.transcendusa.com and avail techsupport. your problem should be solved. they have an online recovery program which can be downloaded and pendrive restored.
s.v.raghavan
Bangalore
Posted on Sep 24, 2009
Why my san disk usb fash when i check its properties shows only 8mb out of 2gb and doesnt allow to be formatted
Whenever a computer tries to access a flashdisk, even for just retrieving the properties of the disk, a LED will flash.
Not being able to format your disk is another thing. If you've opened a file at this disk, Windows will prevent formatting. Best is to restart your PC, and than immediatelly start the formatting-process.
Oct 11, 2013 | Computers & Internet
Lexar usb 2gb
click start control panel scroll to folder options view place a tick in show hidden files folders and drives
this may vary depending on your operating system
you might have restore it to its defaults
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
hope this helps
Jul 04, 2012 | Lexar 2GB Multi-Color USB Flash Drive Kit...
I copy some files to the flash drive but the files are not working properly or seem that the folder is empty.
u might have set the property of the files to hidden ......
after opening ur drive folder click on
Tools (in menu bar) > folder options > View > show hidden files........apply..
Feb 23, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My pen drive is of 2GB i dont know how but now it showing 1.50GB as used space and only 500mb odd free space and its completely empty,there is no data inside plz solve my problem
Insert the USB stick in your computer, then go to "Start" then "My Computer", locate the USB icon and right click and select "Properties". From there you can do a format of the stick. This will erase all the data including some hidden files that you might have and solve the problem.
Note that even though it says 2Gb, the data you can use is slightly less. This is true for any storage device out there.
Nov 10, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I scan memory card with quick h antivirus and all the files in the card automatically showing hidden and even not showing on computer in hidden form too..i check it with x plore, it shows all files but...
This is a common problem. Some antiviruses take the data as a threat/virus, and place them in a seperate hidden folder and changes their extensions (extensions are the file types e.g MP3, JPEG, etc) so that they are no longer accessible. I'd advise you to connect it with your computer. Then go to the TOOLS tab in your upper part of the computer window. Select Folder Options and choose "SHOW HIDDEN FILES" Im sure you'll be able to see those files. Unhide them by changing their PROPERTIES, and restore their extensions simply by typing in the previos extension using the RENAME option of your computer. I hpe this solves your problem If not, you may clarify your complaint and mail me at : streetstyles@live.com
Regards. Hamza Naveed Malik
Sep 02, 2010 | SanDisk 2GB microSD Memory Card
USB card memory drop & files lost
Your card is showing signs of improper removal or virus infestation. I would run a virus scan on it at once, back up any remaining data (after scanning of course), then follow the instructions when you remove the card from your computer. Not shutting down the card before removing is similar to turning off your computer without shutting down first. Usually it's ok, but it can cause data loss.
Good luck.
Mar 08, 2009 | SanDisk 8GB microSDHC Memory Card with...
Not able to copy more than 1GB into 2GB Kingston SD card
Hi 1123sun,
Copy your files off the card. Then Format the card and select FAT32 file system. After the format is done try the card again and see if you can copy more files to it.
Kingston Tech Support
Feb 18, 2009 | Kingston 2GB Secure Digital Memory Card
Toshiba 2GB USB Flash Drive Capacity Problem
format the Flash Drive in in slow mode
click on the properties of flash drive
then click on tools then CLICK ON DEFRAGMENT NOW TAB
Mar 11, 2008 | Computers & Internet
Can no longer save to SanDisk Cruzer Micro 256MB
First, have you tried it on another computer? Basically, narrow down the problem- is it the SanDisk, or something with the USB ports on your machine? Assuming it is the SanDisk, try formatting it. You should be able to format it under Windows Explorer...properties... Or, go into Control Panel... Administrative Tools... Computer Management... Disk Management If you had files on it- they will probably be history. You could Google for recovery utilities, but such getting your files is doubtful. Hope this helps!
Jul 24, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Electronics - Others Logo
42 people viewed this question
Top Generic Memory Electronics - Others Experts
Are you a Generic Memory Electronics - Other Expert? Answer questions, earn points and help others
