The built-in speakers do not work can you walk me thru how to fix this problem? ruth
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Champion:
  • 214 Answers
Built in speakers works if the signal cable is good so check it first.
second check the volume
Posted on Sep 23, 2009
My built in laptop speakers don't play
need to go into the laptops setup and browse thru the listings..especially the audio stuff..
Jan 25, 2014 | Toshiba Computers & Internet
Cannot get test pattern to run. I select Menu->setup-> 5.1 Pattern...then press enter....and nothing happens... Have easy setup set to yes....I remember there was a static pattern that would...
press the tes ttone button on your remote control for the test signal. it will sequence thru each speaker clockwise starting with the right front. watch the unit display to see which speaker it sending the signal to as it goes thru it paces.
Dec 22, 2010 | Sony STR-DE897 Receiver
My bose companion 2 series II speakers worked fine when they were first connected to my mac laptop. Then I disconnected it to take the laptop with me. When I plugged it in again it would not connect to the...
i noticed you mention an apple icon
is this computer an apple
have you tried selecting desktop speakers if there is that option
or maybe the drivers have been corrupted you might have to uninstall then reinstall either the sound device or the sound drivers
make sure you have them backed up to a disk before uninstalling them/anything
hope this helps
Dec 11, 2010 | Bose Companion 2 Series II Multimedia...
Oven not working f7 light on
F7 indicates a stuck button or the ERC needs replacing. This link should walk you thru testing and replacing the problem
http://appliancehelponline.com/ovenerc.html
Jun 28, 2010 | GE 24" Built-In Single Gas Wall Oven
My receiver powers up and powers down instantly, same issue what is the fix ?
Disconnect all speakers at the receiver and power it back on. If it stays on, check your wiring and speakers for shorts, if it cuts out, it needs to be serviced. If you need further in depth troubleshooting, post a comment and I can walk you thru it. Hope this helps
Oct 24, 2009 | Aiwa AV-DV75
Message "PROTECTOR"
Disconnect all speakers at the receiver and power it back on. If it stays on, check all speaker wires and speakers for shorts. If it cuts out, it needs service. If you need detailed troubleshooting help on this after testing receiver without speakers connected and it passes, post a comment and I can walk you thru it. Hope this helps.
Oct 24, 2009 | Sony STR-DE625
Hooking up Kenwood AR-304 to LG TV
You need to connect the TV "Monitor Output" which will be standard audio (RCA) red and white. Then you need to make sure you go into the TV's main menu and go thru "Audio". You may need to turn off the TV's internal speakers to get output via the RCA monitor out. If by chance it has a setting for "Fixed or Variable" for the output, select "Fixed" and control the volume thru the receivers volume control. If you still need further help, don't hesistate to ask! I can walk you thru it. Hope this helps
Aug 18, 2009 | Audio Players & Recorders
Audio jack damaged on Lowrance XOG
the cost of fixing may well exceed the cost of a new unit 110 for the board and 90 an hour 2 hrs minimum
Jul 19, 2009 | Garmin Nuvi 350 Car GPS Receiver
Onkyo 6.1 surround
Check the settings on your cable box for "Audio" settings and check the output. Should be set to "Dolby Digital" If you need more help, post a comment with the make and model of your cable box and I can walk you thru setup. Hope this helps
Jun 29, 2009 | Onkyo TX-SR605 Receiver
Onkyo sr-dr2.2 cuts out quickly after starting
Disconnect all speaker wires from the unit and power back up. If it does not go into protection, post a comment and I will walk you thru troubleshooting. If it still goes into protection, it needs to be serviced.
Jun 24, 2009 | Onkyo LS-V955 System
Computers & Internet Logo
195 people viewed this question
David Payne
David Payne
