Question about Boating
I have a 90 hp that idles fine but bogs down when I open the throttle and shuts down. Can you help?
    Sniper:
  • 53 Answers
Tools(1) A compression gauge (2) a spark gap tester.(3) A Clymer service manual for your engine. (you can purchase from your local dealer). I know all these are expensive but if your going to be a outboard tech you will always need them. Troubleshooting (1) check compression. without the year make and model I'm giving you a average numbers. Look at your Clymer manual. all cylinders need to be over 100 lbs and equal each other within 5 lbs.(2) check spark. use a spark gap tester all cylinders should jump a half inch gap. if you have good compression and good spark, fuel is the problem nine times out of ten.Ethanol gas is proven to stay stable in fuel systems for 30 days in 90 + degree heat. Drain gas tank,clean fuel lines replace primer bulb and replace all fuel filters. Yamaha has a gravity filter under engine coul clean it. Finally replace spark plugs, I know spark plugs probably don't look bad but this is a outboard. Fresh spark plugs means less resistance for the ignition system. The ignition system is week compared to automotive. Test drive boat, if the problem is still there then there is further steps to take. Refer to your Clymer manual about cleaning carburetors if its carbureted and not fuel injected. Fuel injected will require more tools and alot more test. I love clymer manuls
Posted on Nov 03, 2009
Starts and idles fine runs half throttle when fuel is applied
Harry, dirty carb or injectors.
Check the attached links,Manuals and guides, Good luck with your Bike
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
ATV TROUBLESHOOTING AND MAINTENANCE
ATV Service and Repair Manuals
http://www.carlsalter.com/motorcycle-manuals.asp
Jan 06, 2016 | ATVs
What will make a johnsonew 50 hp out board motor bog when under load
Evinrude 50 HP Bogs at WOT - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 6, 2002 - 17 posts - ‎3 authors
83 50 HP Evinrude - sat out in weather for 4 yrs. Been cleaning ... At WOT, she bogsdown. Up to. ... Yes, this boat/motor is new to me. Actually ... Mercury 50 1987 bogs down when full @ full throttle
Sep 12, 2013
Motor Runs great bogs down under load.
Jun 23, 2011
1984 Johnson 70 idles but won't go
Jun 1, 2011
Johnson 70 hp no power under load Update
Oct 30, 2006
More results from www.marineengine.com
motor bogs down at full throttle Page: 1 - iboats Boating Forums ..
Dec 09, 2015 | Cars & Trucks
Runs but will not get up to speed. When you first give it throttle it will take off fine, at first, then it bogs down to rough idle if not shutoff.
have you got any water in the fuel tank ?? very basic ski 2cyl 2stroke ! i recomend stripping the carbs and clean and check the diaphams have not gone hard also ! dont try and run it to clear the problem because if one carb shuts off the fuel feed then you will melt a piston !! then boo hoo no more play time !
Apr 02, 2014 | Yamaha 2004 WaveRunner XLT 800
Ttr90 bogs down at high rpms
I have a ttr 90 that idles well but bogs down at full throttle. Carb is clean and has new pilot and main jets. Seems to run slightly better with intake off. Which leads me to believe the mixture is rich. No adjustment on carb. Stumped?
May 28, 2012 | Yamaha Motorcycles
2001 polaris scrambler 90 will crank and idle all day long, but when you try to throttle up, it bogs down and dies. carb has been cleaned, new plug, exaust is clear of blockage, still has same problem
I dont have a solution but mine is doing the same as the posted ones--runs at idle but bogs down with fast fuel feed!! does anyone know the solution?
Sep 05, 2010 | Polaris ATV
At Idle Runs Fine, 50% throttle runs like ****
It could be a lot of things, if you can run some component testing. You should be able to narrow it down. Test the TP, EGR, IAC sensor, Look, does the car act up at high throttle while in neutral or just when its in gear? You may want to check the timing and look inside the distributor for any signs of water, rust, or carbon build-up.
Jun 18, 2009 | 1990 Chevrolet Lumina
Boating Logo
507 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
