Question about Dell Latitude XT2 Tablet PC
Dell Latitude XT2 fails to start up.
I am running a Dell Latitude X2T and i can get no response from it. The lights above the F4 and F5 keys and the caps lock come on and screen never powers up.
    New Friend:
I know this is an old post, but the LED code for CAPS lock on, F4 flashing, F5 on means memory issue. I had this issue, reseated the memory, and the issue was resolved.
Posted on Apr 09, 2013
  • Napoleon Boneypart
    Napoleon Boneypart Jul 25, 2014
    Tried several times, subbed spare memory. Nothin ... but had success with the WLAN cables (see other comment)
    Where did you find the LED codes?
I had the same problem and was able to fixed it by using the other set of wires that connects the display to the wireless adapter (on the bottom of the laptop) ... use the grey and white/grey wires instead of the black and white wires.
Posted on Nov 23, 2010
    Worked for me -- but I had the startup disk in an external drive. When I first switched the wires, came up well -- with notes on an unfinished install, and instructions to restart and reintall. When I tried to start up with the external drive, we were back to the caps lock, F5, and flashing F4. I'm thinking along the lines of a power issue with the draw from the external drive (D/bay PD01S)(which seems to run fine on an older Latitude)..
    New Friend:
I've tried this and it doesnt work for me. Also I have 3 Plug wire antenna Black, Grey, White, With the White/grey and the Black/White wires covered with a plastic cap. What else may work?
Posted on May 04, 2013
It might be a screen problem. Try connecting it to an external monitor.
Posted on Nov 06, 2009
My Hdd is locked on my Dell XT2 I have the password but I cant find where to put in the Password
Restart the computer and tap F2 key during POST to enter System Setup (BIOS). This should prompt for the Hard Drive (HDD) or BIOS password. Knowledge Base
This should help.
While the computer is powering up keep tapping f2.
Turn it off. Press the power button again and keep hitting f2.
Aug 11, 2016 | Dell Latitude XT2 Tablet PC
Master hdd password
I believe the only way to remove it is to contact Dell with your service tag number.
Nov 16, 2013 | Dell Latitude XT2 Tablet PC
Dell Latitude XT2 sound doesnt work 1/2 of the time. Windows 7.
Download and install the drivers from manufacturer website. If you are unable to recognize the device specific drivers then i would suggest to use the driver scanning tool, it will search for the drivers online and will show a list of of device specific updated drivers.
You can download the driver scanner tool here:
www.DriverScanner2013.net
Dec 14, 2012 | Dell Latitude XT2 Tablet PC
My Dell XT2 tablet pen doesn't work.
Did you install the correct N-Trig drivers for your pen ? You can find them at http://support.dell.com/support/downloads/index.aspx?c=us&cs=19&l=en&s=dhs and by entering your TAG number which is located underneath your tablet pc.
Feb 02, 2011 | Dell Latitude XT2 Tablet PC
How can you get the touch screen or pen work on the dell latitude xt2? I can't figure out how to get the buttons to work or the screen to rotate.
What OS are you using ? Windows Vista or Windows 7 ?
In order to get the buttons and touchscreen working, you need to install the proper drivers.
Go to http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=LAT_XT2&os=WLH&osl=en&catid=&impid=
Select your operating system
and download the following drivers and install them in the following order :
  1. System Utilities : - > Dell Utility : System Software
  2. ControlPoint -> Dell - Application : ControlPoint System Manager
  3. Input device drivers - > Ntrig Application
Restart your computer. Run Windows Update Restart your computer Everything should work.
Feb 01, 2011 | Dell Latitude XT2 Tablet PC
Pen and touchscreen not responding on my Dell Latitude XT2 Tablet PC
Hmmm does the penn have a battery then? I guess something is wrong with the wiring as not just the pen does not work but touching all all not. Stuff should just simply work and not require loads of troubleshooting.
Oct 06, 2010 | Dell Latitude XT2 Tablet PC
Cursor opening start menu and other applications by itself
Hi there, there are two possibilities here, one, the touch screen is compressed in 1 or more areas of the screen. two, it sounds like your PC has a prank virus in it that is causing unwanted side-effects. Try booting in safe mode on your tablet PC, and run a full virus scan.
Jan 18, 2010 | Dell Latitude XT2 Tablet PC
How do I enable presentation mode on an XT2 tablet? I am in a meeting connecting a Dell Tablet XT2 to a Panasonic projector via vga cable and trying to use Fn8 to display the laptop screen. The setting...
You could be able to enable presentation mode by pressing the "settings" button on the bootom of your display, next to the power button and the "ctrl" and the rotate button. After you press that, your dell control point manager should pop up and then go to the tablet tab on the left and open it. after that, go to the display tab and you should see an option that allows you to turn your presentation mode on.
Nov 05, 2009 | Dell Latitude XT2 Tablet PC
Dell Latitude XT2  Tablet PC Logo
2,415 people viewed this question
Top Dell Tablets & eReaders Experts
captain anonymous
Level 1 Expert
Andrew Taylor
Andrew Taylor
lolthepcman
Are you a Dell Tablet and eReader Expert? Answer questions, earn points and help others
