Question about Nokia 6300 Cellular Phone
Screen contrast/greenish tint,can it be adjusted?
The screen has a contrast/greenish tint,can it adjusted? new phone's screen is not as bright as the 6300 it replaced.
How to adjust brightness
The set should have in the on screen customer menu settings for brightness, contrast, color, tint etc.
If in doubt consult the owner manual which will have instructions.
Aug 29, 2012 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Greenish dark, with multible lines across top to bottom of the screen.
That looks like retrace lines. Anyway, you should try to adjust screen pot not focus pot. Make sure you are turning blue screen pot (there are 3 focus pots and 3 screen pots) and do it slowly. If you turn it too much, it will affect your grayscale
Jun 23, 2008 | InFocus ScreenPlay 7200 Multimedia...
LOOKING FOR PICTURE SETTING SAMSUNG MO.NO.LN-T5265F
This may help you...you can also get an owners manual free on line.
English - 23
Using Automatic Picture Settings
Your TV has Three automatic picture settings ("Dynamic", "Standard", "Movie") that are preset at the factory.
You can activate either Dynamic, Standard, Movie by making a selection from the menu.
1. Press the MENU button to display the menu.
Press the ENTER button, to select "Picture".
2. Press the ENTER button to select "Mode".
Press the ??² or ??¼ buttons to select the "Dynamic", "Standard", "Movie" picture
setting. Press the ENTER button.
?³ Choose Dynamic to increase the clarity and sharpness of the picture.
?³ Choose Standard for the standard factory settings.
?³ Choose Movie for a natural Image without picture enhancements.
3. Press the ??² or ??¼ buttons to select "Contrast", "Brightness", "Sharpness",
"Color", or "Tint(G/R)", then press the ENTER button.
4. Press the ??? or ??? buttons to decrease or increase the value of a particular item.
For example, if you select "Contrast", pressing the ??? button increases it.
Press the EXIT button to exit.
• When you make changes to Contrast, Brightness, Sharpness, Color, Tint(G/R)
the OSD will be adjusted accordingly.
• When in PC mode, Tint, Sharpness, and Color are not available.
Press the P.MODE button on the remote control repeatedly to select the desired
picture mode.
Picture Control
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 00
??¼More
TV Picture
Move Enter Return
Mode : Dynamic
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
Dynamic
Standard
Movie
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
50
??² Con trast ??¼
Move Adjust Return
English - 24
Adjusting the Color Tone
You can change the color of the entire screen according to your preference.
Press the ENTER button to select "Picture".
2. Press the ??² or ??¼ button to select "Color Tone", then press the ENT ER button.
3. Press the ??² or ??¼ button to select "Cool2", "Cool1", "Normal", "Warm1",
or "Warm2".
When the picture mode is set to Dynamic or Standard, Warm1 and Warm2
cannot be selected. Movie mode is only available.
Move Enter Return
??²More
Color Tone : Cool2 ???
Detailed settings ???
Size : 16 : 9 ???
Digital NR : Low ???
Active Color : On ???
DNle : On ???
Reset : OK ???
TV Picture
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : On
Reset : OK
TV Picture
Cool2
Cool1
Normal
Warm1
Warm2
Activating Backlight
You can adjust the screen brightness by adjusting the LCD backlight brightness. (0~10)
2. Press the ??² or ??¼ button to select "Backlight", then press the ENTER button.
3. Press the ??? or ??? button to decrease or increase the valueof the backlight
brightness.
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balcklight 1 0
??¼More
TV Picture
5
??² Balcklight
??¼
Move Adjust Return
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : Off
Reset : OK
TV Picture
OK
Cancel
Resetting the Picture Settings to the Factory Defaults
1. Press the ??² or ??¼ button to select "Reset", then press the ENTER button.
Press the ??² or ??¼ button to select "Cancel" or "OK" then press the ENTER button.
Each mode can be reset.
Feb 04, 2011 | Televison & Video
Need to change tint, color on screen using the remote of course
Since you do not provide the make and model number of the TV so we can look for the user manual for you to read on how to make adjustment to your TV.
You just have to get to the MENU button on the remote for the ON screen setup menu and look for Picture adjustment set up to adjust the Pictures.
It should show Brightness, Contrast, Tint, Color adjustment choices.
Jan 03, 2011 | Televison & Video
Can not access PC Brightness or PC Contrast - only X Contrast
From p.29 of the manual
"Brightness, Contrast, Sharpness, Color, and Tint are only available for adjustments
if you select User in Picture Mode.
Press / on the remote control or VOL+/ VOL- on the control panel to adjust these settings."
Apr 12, 2010 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Yellow tint no color red.
you can adjust in color mode. please balance the tint, color,brightness, contrast, & sharpness.
Aug 30, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Cannot adjust color
Have you turned the controls from one of the presets? Presets are Vivid, Movie, etc. Most sets have to be in Custom or Customize to adjust the controls, likely on-screen with one of contrast, brightness, color, or tint selected. If those are horizontal bars then up/down selects which and right/left select decrease/increase or red/green for tint. Start with 50% if no reset (0% for R/G) or start with the non-Vivid settings. Consult AVS forums for you model to get better settings. Rules of thumb: Brightness should be as dark as possible without losing gray scale at lowest part. Contrast should not be so high that whites bloom or make it hard to see. Color should not blow out any color nor be unnatural. Tint is best judged on flesh tones. -Ken
Jul 15, 2009 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
Well i really want to know what level the coular and brightness lvel has to be on a toshiba t.v
You can set these controls to your liking, though a lower brightness setting might increase the life of the screen. First, set the brightness and contrast to a level that is pleasing to the eyes, then adjust the color to look realistic - enough color without being disturbing. If faces area look greenish or purplish, then also adjust the tint (sometimes called Hue) until you get accurate flesh tone. Flesh tone is the best thing to adjust for; when you get good flesh tone, the rest of the picture will look great. ALWAYS make adjustments during a live news broadcast, which tends to have the most accurate balance of brightness, contrast, color level and hue. Note that commercials are all recorded in different studios with different settings, and will usually not look right - it's best to just live with this than to constantly readjust the TV. There are also DVD's available which walk you through proper TV adjustment.
Jan 02, 2009 | Toshiba 36AF41 36" TV
Green tint I can't seem to fix
Hopefully someone on here has a manual and can tell you exactly where the tint controls are. Also need to try adjusting the color level, turn it clear down so you have a black and white picture.
Is the picture still green over the screen with the color control
set clear down to black and white? If it does, you might
have an issue with the green gun going out or problem in the
circuitry to it.
By the way, the best way to adjust the picture settings on a
tv are to first turn the color control clear down, then adjust
brightness and contrast for best black and white picture, then
bring up the color level to where it should be and adjust the
tint for best red/green ratio.
May 20, 2008 | Mitsubishi CS-27205 TV
Color are very off on my emerson EWT2721
Hey just go to menu- picture, and increase your contrast, brightness, and/or tint.
Jan 13, 2008 | Emerson EWF2703 27" TV
Nokia 6300 Cellular Phone Logo
259 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
