Question about Poulan Pro " Pro" Self Propelled Mower
Mower starts but shut off after 5 seconds - Poulan Pro " Pro" Self Propelled Mower
Bosch Rotak 32R. Why does it keep shutting down in 4-5 seconds??
Check gas cap for proper venting, will it run better with cap off.
Feb 13, 2016 | Garden
Lawn mower will start and run for 5 seconds and shut down
will it stay running with your choke on? if so then clean your carb. if not then look for a blockage from tank to carb. ie fuel shut off, deteriorated fuel line. plugged filter etc
Oct 17, 2014 | Toro Power Lawn Mower
I'm have a yard machine push mower with a 4.75 Briggs engine. Starts fine but shuts down in 5 seconds?
Sounds like a fuel pump diaphragm or fuel filter blocked if it has one. try removing filter if there is one.
Aug 10, 2014 | Garden
My lt 1000 17.5 hp riding mower will backfire once in awhile when starting but runs fine once it starts. why
first smell the oil is there a gas smell to it?the needle valve maybe dripping fuel and over flowing into the intake
Apr 18, 2012 | Craftsman Garden
Lawn mower starts up , but only runs for 5 seconds or so and shuts down It is a troy bilt model # 11A546N711
dirty carborator. needs to be removed and cleaned there is dirt in the main jets
Jul 25, 2009 | Garden
Troybuilt 675 hp lawn mower doesnt start
self propelled not working on troy built 675 series bought 5/08. The belt is still on.
Jun 17, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Started lawn mower first time of the season and it ran straight for a good 25 monutes with no problems. i turned it off to move it to the front yard andnow wwon't stay running. will only run for 5 to
Immediate thought is that something got ingested into the needle feeding the carb. Might have to remove the carb and clean it out thoroughly to maintain fuel flow through the engine. Generally if it runs a few seconds and shuts down then it is running off the initial burst of fuel and then starving out for any more from there.
May 12, 2009 | Craftsman Garden
Poulan Pro " Pro" Self Propelled Mower Logo
75 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
