Question about Fahrenheat Heating & Cooling
Fahrenheat wall fan heater 1996
This is for my 1996 built home.  It is a Fahrenheat Fan Forced Wall Heater FZL 4004 A and the plastic knob is stripped out and will not turn..just spins.  This plastic knob is grey with long stem and says "Warmer" with arow going around. Can I get this item from you? Thanks  S Thayer 863-324-5384 or susiethayer@earthlink.net
Buffalo12980
  • 625 Answers
SOURCE: fahrenheat wall unit
your on-off switch is faulty - need to replace it.
Posted on Dec 09, 2007
SOURCE: Parts for Fahrenheat F2543 baseboard heater
Go to Home Depot, buy a new one, take the part you need, return the rest...
Posted on Oct 12, 2008
SOURCE: Fahrenheat electric baseboard heaters are not safe for children
A few companies sell child-proof covers that prevent little fingers and small objects from getting into the radiators. Try searching Child-safe baseboard heater covers in a google search or PexSupply.com.... we use them in daycare centers.
Posted on Jan 30, 2009
  • 10 Answers
SOURCE: not sure hooked up correctly
You should have a licensed electrician connect this unit for you.
That being said you need to supply 240v to the unit. You will need a true two pole breaker. (not a split or a twin) There should be two screws or lugs and two slots or clamps on the bus side. These slots must span both phases of your panel. You can measure the voltage across the two screws if you are uncertain, it should read 240v.
Next connect a piece of 12/2 wire to the two screws. Use the black and the white. Land the bare copper wire on the ground bus in the panel.
Then at the unit, land the bare ground to the ground screw and connect your 12/2 to the wires in the unit. You may find the wire nutted together. This is normal, and allows "feeding" the unit from either side. If you are unsure measure the voltage here also, across the white and the black. It should be about 240v.
Posted on Feb 09, 2009
SOURCE: Parts for Fahrenheat lfp6152e
Contact supplier Marley @ 1-800-642-4328
Posted on Apr 28, 2009
Is there an external thermostat that can be used for this and there is a vibration noise, any suggestions?
I'm not aware of a wall thermostat for this heater, because it does not have a Millivolt Control. As far as the vibration is concerned, does it just occur when the fan is on? If so the fan or the fan motor may be loose. Or the fan itself is out of balance. As make sure the fan housing is properly attached to a wall stud or studs.
Feb 14, 2011 | Fahrenheat (FFH1614) Wall Mounted Panel...
I have a fahrenheat wall mounted heater, 120 v model,(can't find a model number on the unit) with a dial temp control. No matter which number setting it is on, the unit cycles off after about 50 seconds....
UNIT SOUNDS LIKE ITS SHUTTING DOWN ON A LIMIT SWITCH IN HEATER. THEY LOOK LIKE ROUND BUTTONS OF DIFFERENT SIZES. THE HAVE 2 WIRES GOING TO THEM AND THEY ARE A NORMALLY CLOSED. THERE IS A FAN DISK NORMALLY OPEN TO UNTILL IT GETS HOT AND CLOSES TO TURN ON FAN.  IF THE FAN SWITCH TAKES TO LONG TO CLOSE THEN LIMIT OPENS TO PROTECT FROM OVER-HEATING
Apr 23, 2010 | Fahrenheat (FFH1614) Wall Mounted Panel...
Electric baseboard heater
You need a meter, it will be hard without this! If you have 220v in the wall, then think of it like this; each wire is 120v. Test to each other, you get 220v. The thermostat is a double pole, you said. So think of it like this, its an adjustable temperature controlled switch that lets electricity through at the temp. you set it at. If you have 120v from one wire connected to one end of the element, and the other 120v connected to the other end of the element, then it will work. DO NOT CONNECT THE 120V TOGETHER. IT MUST GO THROUGH THE ELEMENT FIRST. The thermostat should be between the power from the wall and the element, to control the temperature.
Jan 05, 2008 | Fahrenheat FBE15002 Baseboard Heater
Can someone please tell me what is the lowest temperature setting a Fahrenheat 3000 Watt Large Room Fan-Forced Wall Heater Model FZL3004 will turn on at ?
about the only way I can figure is to let the room get very cool and adjust the thermostat to its lowest setting. now turn on the unit. monitor the heat until the stat just opens. the thermostat bimetal will be closed and will open when the bimetal expands and opens its contacts. another way is to hitch up a chart recorder to measure temperature with its output connected to the heater. [too expensive for you or the DIY to accomplish]
Dec 13, 2007 | Fahrenheat FFH1615 Heater
Fahrenheat wall unit
Dec 07, 2007 | Fahrenheat ECP1524 Wall Mounted Panel...
Fahrenheat 4000 watt wall mounted heater shuts off and needs reset
the reset is probably an inline circuit breaker. if you can get hold of am amprobe clamp around ammeter, check the current when the unit is running at full power. the reading you get check against the current rating of the inline breaker. your fan motor bearings may be dry increasing the current draw of the unit and tripping the breaker. try oiling the fan bearings with a light oil NOT WD-40.
Dec 06, 2007 | Fahrenheat (FFH1614) Wall Mounted Panel...
Low air flow
most fan forced wall heaters do not move a lot of air. check the cfm rating on the heater. the fan sucks in air from the bottom and forces it up to the top where the element is. broan and nutone have good air flow.
Oct 23, 2007 | Fahrenheat FFH1615 Heater
Heating & Cooling Logo
157 people viewed this question
Top Fahrenheat Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
