Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
Can you tell me how clear the water should look in my hot tub? I looked at it today and it was murky. The test strip was fine but it looks a little off.
  • jackiek957 Sep 24, 2009
    can you tell me how clear the water should look in my hot tub? I looked at it today and it was murky. The test strip was fine but it looks a little off.
    Thank you I will take a sample tomorrow to the spa guys.
  • 333 Answers
Your water should be see thru.
Trust your test strips. If it tells you that a chemical is off a little bit then it shouldn't be a matter for concern. However a big difference should require attention. The following is what you should be reading on your water:
Chlorine is 1.5 - 3.0 PPM
Bromine is 3.0 - 5.0 PPM
PH is 7.2 to 7.8
Alkalinity should be between 80 to 120 PPM
There are a number of products that your pool supply store can recommend to clarify your water. If the water is looking murky, then you probably need to shock it.  Murky water is from the water not being balanced and not enough sanitizer being used. When you do go to your pool supply store, take them a little baggie or vial of your water so they can get a computerized reading on your water. They will then be able to tell you exactly what you need to make it more clear.
Posted on Sep 24, 2009
  • 19,396 Answers
Drain and refill the spa. After draining check the surface skim filter, it may need replacement. The spa must be refilled not longer that every three months.
After refilling also go to water maintenance , and set the water filtration to an higher rate. 0 does not filter.
See page 14 on the manual to set filtration.
Please let me know if comment had been helpful.
Thanks.
Posted on Sep 23, 2009
My dryer had no water going into the container
Not Filling With Water OTHER washers test similiarly- test water inlet valve water and pressure switch. Test the water pressure level switch a pressure activated switch that is used to determine the correct water level in the tub. This part is normally located behind the control panel and will have a hose or air dome tube that connects it to the tub. On washers that use an electronic control, this switch may be located at the sump area below the tub. As the water fills in the tub it will compress the air in the tube and push against a diaphragm inside the switch. The switch will control the water inlet valve and turn the valve off at the correct water level. If the tube has a leak, not enough pressure may be created to activate the switch and the washer may overfill. If the switch is defective it may also cause the machine to overfill. To determine if the switch is bad, you should first eliminate the air dome hose as a problem. Look for signs of cracks or worn areas on the hose. Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well. If the air dome hose appears to be ok, then the water level switch may be defective.
You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube.
If the machine starts to wash. the pressure switch is more than likely good
( No wash- then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED).
# Test procedures to follow
* Disconnect the washer from the wall outlet
* Set the timer dial on regular and pull the knob to turn the timer push-pull switch on
* Set the temperature switch to the cold/cold setting
* Open the controls panel to gain access to the water mixing valve solenoids
* Touch the 2 terminals on the cold water solenoid with your volt meter test proves. Make sure that your body don't touch the washer cabinet, this eliminate the chance of getting an electrical shock.
* Have someone plug the washer cord for you while you check the voltage
* The reading should be 120 volts
* Touch the 2 terminals on the hot water solenoid with your volt meter test proves. Remember, to keep your body from touching the washer cabinet to eliminate the chance of getting an electrical shock
Have your helper plug in the washer cord again so you could check the voltage at the hot water solenoid
The reading should be 120 volts. If you get 120 volts, this tells you that the wall outlet, the timer, the water temperature switch cold and hot water settings are working ok.
If the washer is not filling, the problem should be on the water valve, the screen filters or the water supply
If one of the solenoids is bad you will need to replace the complete water mixing valve assembly YOU SHOULD ALSO GET AN OHMS READING OR SHOW CONTINUITY WHEN TESTED UNPLUGGED ON BOTH SELINOIDS HOT AND COLD
To check the water valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
Jan 16, 2016 | Dryers
I have a floater for my hot tub and add approx. 2 little pucks as required, yet when I take my readings it shows no chlorine present at all!
Do you smell the chlorine on the puck itself or actually coming from the hot water? If you have to put your nose up to it it sounds like the puck isn't dissolving enough in the water (maybe they put too much binder in the manufacturing mix). You know you can use regular household bleach to put chlorine in there. Put a couple of cups in the tub and take a reading. That bleach is a lot cheaper than the powder or the pucks and works just as well
Feb 26, 2015 | Pool & Spa
No water going in washer
How to Check a Ge/Hotpoint Washer when Is Not Filling With Water OTHER washers test similiarly The water pressure level switch is a pressure activated switch that is used to determine the correct water level in the tub. This part is normally located behind the control panel and will have a hose or air dome tube that connects it to the tub. On washers that use an electronic control, this switch may be located at the sump area below the tub. As the water fills in the tub it will compress the air in the tube and push against a diaphragm inside the switch. The switch will control the water inlet valve and turn the valve off at the correct water level. If the tube has a leak, not enough pressure may be created to activate the switch and the washer may overfill. If the switch is defective it may also cause the machine to overfill. To determine if the switch is bad, you should first eliminate the air dome hose as a problem. Look for signs of cracks or worn areas on the hose. Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well. If the air dome hose appears to be ok, then the water level switch may be defective.
# Test procedures to follow when a GE Hotpoint washer is not filling
* The reading should be 120 volts. If you get 120 volts, this tells you that the wall outlet, the timer, the water temperature switch cold and hot water settings are working ok.
If the GE Hotpoint washer is not filling, the problem should be on the water valve, the screen filters or the water supply
Apr 02, 2014 | Whirlpool Duet GHW9150P Front Load Washer
There is a leak and we can not find it. Any solutions
This may help?
Fill spa to highest level possible.
Heat to 100 degrees or higher.
Then, with your bare hand feel throughout the bottom rim and anywhere else you are able to: see if you can feel "Warm/Hot" water. Any "Cold" water is not the area of the leak, that water has "Travelled" there. The warmer the water, the closer you are to the origin.
Jan 01, 2014 | Eclipse 4 Person Hot Tub Spa - Dream Maker...
Maytag se1000 Series 01
this will be a timer fault most likely. if you can test for voltage at the valves while the machine should be filling you can tell if the timer is sending power to the valves.
Dec 06, 2013 | Washing Machines
Where is heater control valve on 2003 dodge ram pick up
THERE IS NO HEATER CONTROL VALVE ON THE WATER HOSES. NEW HEATER CORE. INLET LINE right before heater core hot, outlet after core look warm. Burped cooling system 5 times with engine at operating temp. Installed homade burp VALVE right after heater core outlet(high part of hose). Still no heat. Removed water pump, impeller still in good shape not stripped off shaft. Removed heater core hoses flushed water thrue the connections on the block to the water pump INLET and outlet. flushed water thrue heater core and hoses. Going to put it back togeter today. Used known good gauge to check water temp for operating temp in test. 195 f
Oct 22, 2010 | 1997 Dodge Ram 1500 Club Cab
My maytag neptune washer stop washing with 10 minutes left to go.
If your machine is a FAV6800AWW or FAV9800AWW the (upside down u and f) may be a “NF” for no fill error. The washer has tried to fill the machine with water and has sensed a water fill issue. The control board has shut the wash cycle down with an “NF” error to the display because of excess time to complete the water fill portion of the wash cycle.
Will the machine complete the cycle with Hot water only or Cold water only? I would do a Quick Wash cycle just to test with an empty wash basket.
Regardless of the above test and assuming you have good water pressure for both Hot and Cold supplies to the washer I would do the following. Close the water source valves to the washer and remove the Hot and Cold hose connections at the back of the machine and check for clogged inlet screens. If the water inlet screens are free of restrictions I would go into Service Mode and turn on the Hot and Cold water valves on one at a time and make sure the tub will fill with about 2 inches of water in about 3 minutes in service mode. Check both Hot and Cold inlet valves individually see page 16 of the SM Board Output Test, enter service mode and do the function test for both Hot and Cold Water Valve’s. If the inlet screens are clean and you have water fill restrictions in service mode we may need to look at replacing the water inlet valve assembly. You can turn on the drain pump in service mode to empty the tub or just start a wash cycle and the machine will empty the tub.
The Service Manual for reference. Sears Parts Direct for reference.
May 11, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Fisher Paykel GWL10US Washer won't spin
Look at my issue on "eco smart won't drain, smells hot". You could have same issue and your motor just hasn't burned up yet.
Oct 16, 2008 | Fisher and Paykel GWL11 Top Load Washer
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
43 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
Ian Kime
Ian Kime
john h
The Cover Guy
The Cover Guy
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
