Question about Desa International ReddyHeater® R115DT Utility
Reddyheater r100 My heater will run if you open the top cover,but when you close the cover the flame goes out.I have replaced the nozzle,plug,and filters.any ideas? thanks
  • frank55 Dec 28, 2007
    I have the same problem I have rebuilt the air pump, replaced the spark plug, replaced the injector nozzle replaced the filters. If i turn the air pressure all the way up it will run but at a weak temperature and if it cycles it will not relight. If i remove the cover it will light and run fine but the pressure still has to be about 6 psi. It seems that there is deflection of the air as you slide the cover from back to front that is causing turbulance that is blowing out the flame. The fan is runnig fine at all points of operation. The combustion chamber is clean and unrestricted. There is no dents or bent material. I am at wits end with this and need a GOOD explanation as to what may be wrong
  • 625 Answers
The fan must be hitting th upper cowling. see that the fan bracket is fully seated in the cutouts in the lower half of the unit.
Posted on Dec 27, 2007
Turbo heater will only run and heat with top open
NO MAKE NO MODEL no help can be found or given
Mar 04, 2015 | Heating & Cooling
When i take the top of my reddy hearter off it will start right up . but when it is on it will not start>
A worn nozzle creates a spray pattern, where a good nozzle creates a fog.With a coarse spray pattern poor combustion results in an off colorflame, . The photocelldoesn't like the color, sends a signal to the computer whichshuts everything down. That's the job of the electronics. On HSI ( hot surfaceignitor) heaters it is all about correct flame color , not just flame. The part where you write "If I remove the cover again it runsfine" is a symptom of a bad, worn, or restricted nozzle (generally).Remember- the ignitor only stays red for 5 seconds, then the flame keeps itselflit. The nozzle's pattern is a cone. Lift the lid & the pattern widens(aerodynamics) - replace the lid and the cone narrows & possibly distortsthen the flame goes out. This nozzle rule will only apply if everything is correct as far asfuel delivery applies. The pump pressure must be correct- not almost correct.Set the pressure with a low-pressure gauge that registers12-15 psi max. A gaugewith a higher scale just will not read close enough to satisfy the system. If the pressure is not correct, the aboverule will not apply. Instructionsfor setting the pressure can be viewed at http://reddyparts.com/pressure.htm. In addition, a fan can cause the same problem if damaged ormis-matched to your specific model. I must mention that any air leaks onthe pressure side (or vacuum leaks on the fuel line, for that matter) betweenthe pump and the nozzle will create a rich/lean mixture at the combustionchamber, creating an off-color flame.
Mar 27, 2011 | Reddy HEATER R115 115,000-BTU PORTABLE...
I plug my reddy heater in and it comes on then shuts back off. What is the problem?
Try cleaning the flame sensor. Remove the top of the heater. The flame sensor is a black rubber boot close to the fuel nozzle. Pull is out of it's holder and use a soft cloth or cotton swab to reach into the openning and clean the eye. While you have the top off, watch out for the fan and turn the heater on and use a flashlight to look for fuel spraying from the fuel nozzle into the burn and make sure the igniter is working. I don't know which type you have but it may be the spark plug type or a hot surface igniter which should just glow red hot. Let me know what you find.
Jan 02, 2011 | Heating & Cooling
Heater does not fire or run while top cover is on. take it off it runs perfect try to put the cover on while running it shuts off.
The air pump pressure could be off a little causing incorrect fuel delivery. Follow this link for instructions.
OR
The nozzle could be worn to a point where a spray is being produced rather than a fog. By removing the top lid you are changing the aerodynamics and the safety system likes the color of the flame (falsely). Replace the nozzle. Follow this link.
Nov 05, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
DESA ReddyHeater R55BT will not stay lit. Sometimes it will huff and puff and blow a cloud of black smoke and quit; other times it will light for a moment or two and go out; others still it will run 2-3...
this unit has neither flame sensor or oxygen sensor.it has an photo cell in it.look at the plate that is on the back of unit.that is the air pump filter cover.if you look very closly you will probbaly see tiny cracks around one of the holes,either the adjuster or the plug.these covers crack all the time and they are not noticeable.when they crack it changes the air pressure and the unit doesn't work right.let me know and i hope this was helpful to you.
Feb 24, 2009 | Reddy Heater RLP100 Portable Forced Air...
I have a reddy heat r100 when I have the top cowl off everything runs fine as soon as I replace the cowl and plug it in the fan starts and then the overload switch trips
check for a wire getting piched or pierced by a screw or the cowling. If not look for an air flow pressure switch and be sure it is working.
Dec 18, 2008 | Desa International ReddyHeater® R115DT...
165,000 forced air reddy heater
It would help if I knew the model of heater because there are 2 different technologies that are used in Reddy Heaters. Having more information could affect my answer.
Generally, if a heater runs with the lid off but shuts down with the lid on, its a sign that either the air pump pressure is not to specs or the nozzle is restricted or worn out. Desa International, the manufacturer, recommends annual replacement of the nozzle, but this is arguable, depending on the age of the heater.
I am pasting a document that I've had around for awhile, that may help:
"A worn nozzle creates a spray pattern, where a good nozzle creates a fog. With a coarse spray pattern poor combustion results in an off color flame, . The photocell doesn’t like the color, sends a signal to the computer which shuts everything down. That’s the job of the electronics. On HSI heaters it is all about correct flame color , not just flame.
The part where you write "If I remove the cover again it runs fine" is a symptom of a bad, worn, or restricted nozzle. Remember- the ignitor only stays red for 5 seconds, then the flame keeps itself lit. The nozzle's pattern is a cone. Lift the lid & the pattern widens (aerodynamics) - replace the lid and the cone narrows & possibly distorts then the flame goes out.
This nozzle rule will only apply if everything is correct as far as fuel delivery applies. The pump pressure must be correct- not almost correct. Set the pressure with a low-pressure gauge that registers12-15 psi max. A gauge with a higher scale just will not read close enough to satisfy the system. If the pressure is not correct, the above rule will not apply. Instructions for setting the pressure can be viewed at http://reddyparts.com/pressure.htm.
In addition, a fan can cause the same problem if damaged or mis-matched to your specific model.
I must mention that any air leaks on the pressure side (or vacuum leaks on the fuel line, for that matter) between the pump and the nozzle will create a rich/lean mixture at the combustion chamber, creating an off-color flame."
Good luck, I hope this helps.
Dec 03, 2008 | Reddy Heater-30-55,000 BTU Variable
Troubleshooting reddy heater 115,000btu
runs for awhile shuts down with a big puff of smoke comes out poured diesel 911 thought i had water in diesel fuel cans nothing help need solution ASAP
Oct 30, 2008 | Desa International ReddyHeater® R115DT...
Remove the nozzle and clean it. Clean the photo cell also. Check the fuel pump pressure it should be 5.1 #.
Feb 26, 2008 | Desa International ReddyHeater® R115DT...
Won't stay running
is this kerosene or propane. if kerosene, two types of ignition is used.  a spark plug or a hot surface ignitor.  the kero unit uses a cad cell flame detector, the propane unit uses a millivolt generator.
the kero unit uses an air pump that comes off the backside of the fan motor - this airline goes to the nozzle and acts like a siphon for fuel.  there is no air pump for the propane heater. the fan just accelerates airflow through the combustion chamber.  the cad cell of the kero unit sees the flame and varies its resistance.  it is sensitive to the infrared generated by the flame and feeds this signal to the lockout relay. no flame after a few seconds, opens and locks out the unit.  the propane unit uses a millivolt generator.  it is a copper cappillary tube that has two spade connectors on it. the spade connectors are connected to a high limit mounted on the backside of the combustion chamber.  under normal conditions the hi limit is closed and completes the electrical circuit to the main valve. the millivolt generator is electrically connected to the pilot/main valve electromagnet inside. with a flame detect signal the electromagnet is energized and holds the main valve slug open allowing the propane to feed to its nozzle in the chamber. as long as there is a flame the valve stays open. no flame, no signal and the unit releases the valve pellet and closes.  you can test the hi limit by jumping out the two spade connectors and see if the unit starts and stays running.da8a32c.jpg
Apr 06, 2007 | Reddy Heater R70 Portable Forced Air Space...
Desa International ReddyHeater® R115DT Utility Logo
121 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
vance jones
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
