Question about Canon PC-735 Copier
The jammed paper light cames on and there is no paper jammed it does not feed paper for copy
  • Canon Master
  • 5,568 Answers
There are two ways the progress of a sheet through the machine are monitored; either photoelectronically or via a 'flag' that is pushed out of the way by the paper as it progresses through the machine. These flags also use photo sensing but if a flag is broken by someone stabbing stuff into the paper path (seen a lot of that), the flag won't reach the paper so the machine thinks there is a jam.
Posted on Sep 23, 2009
2 Suggested Answers
SOURCE: canon pc 420 paper feeds only part way
I had the same problem. I found a parts diagram here http://techno-parts.org/canon/220/320_220.php which showed that the springs hold the bar down. On mine, on each side, one of the spring tabs was broken.
I made a metal pin for one side and insert a screw on the other. Be sure and wrap the spring over the nylon bushing.
Posted on Apr 04, 2010
The paper won't feed and the paper jam light goes
Wich copier model do you using?
My wild ques would be paper feed rollers. Try to clean them with alcohol and try to copy.
But still I would want to know the model.
You can also contact me on emma.servis@gmail.com, if its Canon copier.
Jul 17, 2010 | Canon Office Equipment & Supplies
Paper jam indicator
Your back side of your printer might be loose
Apr 16, 2010 | Toshiba 1370 Black and White Copier
Paper stopping but not really a jam
I am assuming you have checked the paper feeder traying isn't part feeding?
Check the internal unit closest to the toner drum, sorry this is not specific advise for the Minolta fuser unit. You are looking for a lever that slides out revealing the paper it has collected from internal jams - Usually the lever is to the side just above or below the toner unit.
If this doesn't work check the paper loading tray(s)
May 21, 2009 | Konica Minolta Office Equipment & Supplies
Rec paper jam message.
Normal 0 I suggest you get a sheet of Card Stock (Heavypaper) and place it in the feed way. Then press the printbutton applying a slight amount of pressure on the Card Stock so itwill feed through the printer. The reason for this is in some cases Ihave been able to clear the paper track of debris that was deposited thereover time.
Worth a try, as I have fixed a number of printers thisway, saving costly repairs.
Hope this helps. Bud
Jan 27, 2009 | Canon Laser Class 8500 Printer
AL-800 cannot make copies jam light remains on with no jams
First, is the paper being fed at all? If the paper is being fed and jams at the same location then a senor, actuator or switch is bad, out of place or broken. If the device will not clear the jam light, completely power down the device, unplug from wall, let set about 30 sec. to 1 min. and then replug in and see if it reset. If the device did not reset then again a senor, actuator, or switch is out of position ( being held up in the paper path). If the paper does not feed at all then the feed section is the problem. Clean the feed tire (s) the rubber restorer or a high alcohol base cleaner. Listen to hear if the feed tire (s) are even turning. If feed is not turning then it could be clutch, motor or board problem.
Jan 04, 2009 | Sharp AL-800L Copier
I got a canon mp530 printer paper got jam , ipush copy button and paper came , but next i trying to use it didn't work it say chek printer
Did all of the paper come out? If not, there is likely a little piece of paper still pushing the sensor down.
If all the paper came out, you may have a faulty sensor or sensor actuator in the paper feed. Unit will have to be taken apart and inspected.
Nov 04, 2008 | Office Equipment & Supplies
Zerox WorkCentre XD125f E2 red paper jam light
This machine problem can be very involved.
A paper jam as described can be in any locations of the copier.
First of all when the toner-developer falls on the base of the paper feeder, it can contanimate all paper feed shafts and even sensors, and plug connections.
Worn feed rolls can cause the machine to jam. Clean the rollers and see if it corrects the problem.
A bent paper tray can cause the copy to skew, causing jams.
Sometimes the plasic paper path baffles are warped leaving narrow gaps in the paper feed path not allowing the paper to go through properly.
A bad paper feed sensor can cause inttermittant paper feed jams. This sensor is located just above the feed rolls. A involved process to take out without breaking the plastic components.
The machine has paper feed clutches located at the back of the feed rolls. To get to them it is also involved. Sometimes these clutches slip and will cause paper feed problems. There paper feed solinoids may operate intermittantly not allowing the paper feed clutch to operate correctly.
The main board can also cause these types of problems, not allowing the correct signal to operate the paper feed solinoids.
There is so much in this area to locate and isolate for paper feed problems.
If all else fails, call Xerox for a service repair.
Oct 26, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Paper folds and jams before
your description points to a fuser assembly problem which is right where you looked. I'm not sure what that plastic piece is from. if it is black, it probably came from the fuser. That is a replaceable part, but I'm not sure you can still purchase them from Xerox.
Jun 24, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Paper jam light flashes but no paper is jammed. I turned some gears and after a while it started to work. After one try, it did not copy and the light started flashing again.
There are four things I would check first. All depends on what was happening when the problem occurred. 1) If there was a paper jam to begin with, check to make sure all the paper came out and didn't tear. The two areas to check are in the transfer area below the cartridge and at the fuser area. 2) At these same two areas check the (usually black) plastic paw and make sure it isn't broken and functioning properly. 3)Paper/paper dust can accumulate around the photo interrupter and cause mis reads for paper jams. Again this is in the same area. 4) If the paper feeds out of the cassette about in inch and then jams for no apparent reason, it is usually caused from dirty/worn pick up tires. If this is a symptom I would clean the pick ups with alcohol. Hope this helps
Mar 05, 2007 | Canon PC-920 Black and White Copier
Canon PC-735 Copier Logo
625 people viewed this question
old marine
old marine
