Question about Samsung SyncMaster 940N Flat panel Monitor
Moniter lites up for about 1 sec, then goes out.
Capacitors look ok, but which ones go bad so i can replace them
  • 748 Answers
Hello
Sometimes you can get a good incation because the tops have domed over. However, the best method is to take each out of circuit and test with an ESR meter. Even though it's unlikely, other components can cause this same symptom. For more info see my website: www.micromendllc.com
Good Luck
Posted on Sep 23, 2009
It runs out of fuel
sound like pilot lite is not getting thermocouple hot.
check that pilot lite flame is extending out to and touching thermocouple. If not, clean out pilot lite orface and pilot lite gas feed pipe all the way back to the main gas valve if necessary.
If pilot lite flame is touching thermocouple, then replace thermocouple
Jan 22, 2013 | Mr. Heater Big Buddy Heater
After about 1 minute warmup the moniter goes black , click the switch off and back on it only lasts a few seconds.model x224w
The problem you are describing is in the inverter board that powers the back lights behind the screen. The cause is bad capacitors in most cases and develop a bulge at the top indicating it is open. Repairs can be attempted or the board replaced.
Mar 19, 2011 | Hyundai Computers & Internet
Hi...I have a Flatron W2234S that is about one year old. It has been problem free until recently when I moved. Now all of a sudden it comes on and immediately goes off and I have to turn it on and off 3 or...
You can take it apart and inspect for bulging capacitors - the tops should be perfectly flat. Even a slight bulge at the top is an indication that the capacitor is bad.
Nov 11, 2010 | LG 22" FLATRON LCD Monitor
Moniter goes black 2 sec after i turn it on and when i turn off then back on it stays on for 2 sec then goes black again
Look for bad caps, shorted out transistors, cold solder joints. You will have to do in-depth troubleshooting and you need to narrow down the problem to find out if it is the lamp assemblies problem or the inverter/power supply problem.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Nov 02, 2010 | Dell SE198WFP 19 inch LCD Monitor
Syncmaster 216 bw samsung goes black. when i push
your power supply needs to be repaired . you have bad capacitors. very comon problem
Dec 31, 2009 | Computers & Internet
WD-52525
You have a bad DM Board. You need to replace it. Changing the capacitors will not cure the problem. Completely replace the entire board
May 26, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Ds lite comes on for a sec when charger plugged in then it goes of unit does not come on or charge
Hi three things come to mind, you dropped it but usually they wont admit it (dont go mad they usually all break when you do) if it rattles the capacitor under the power switch just fell off (common you have to solder it back on) if not that you replaced the bottom screen and forgot to insulate the metal of the back of the screen against the circuit board and blew either the f1 or f2 fuses (Replace them if you did) last thing i wont go into if you havent pulled it apart if you have reply and i will tell you Good Luck
May 20, 2009 | Nintendo DS Lite - Onyx
It does not start, gives one long beep (about 2-3 seconds) silence and beep again
Switching DDR cards solved the problem. I was getting long beeps every 2 seconds. No short beeps. Just one long beep every 2 seconds. Thanks Josh Whitehead.
Apr 23, 2009 | Computers & Internet
19inc moniter power on then goes off within 1 sec
bad capacitors in the power circuit for the inverter power supply, replace these and everything should be alright it requires soldering skills or I can do it for a fee. It can also be transistors but much more likely it is capacitors.
Jan 12, 2009 | Proview PL926WBi 19" LCD Monitor
Gateway FPD1960 TFT works with laptop, not desktop
Elbtax,
Click start > right click on "My Computer" > Properties > Hardware tab > Device Manager button > Display adapters > Right click on your device and select uninstall and re boot your computer. Windows should pick up your adapter and re configure it automatically. This method should Fixya!
Good luck, and let us know how it goes.
Mar 18, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Samsung SyncMaster 940N Flat panel Monitor Logo
339 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
