I have a customer who has changed the input on his P60XC10 monitor and cannot figure out what the input to select to get the picture back. We used an HDMI cable between the receiver and monitor.What are the possible names of the HDMI inputs be on the back of the monitor be? I do not recall it being HDMI 1 or 2.
  • 8,197 Answers
LOook for thisin the settings.
4) DVI
Input digital RGB signals from a computer or HDTV
device having a digital RGB output.
Or you can downlod manual here.
http://www.retrevo.com/support/NEC-60XC10-TVs-manual/id/5890ci261/t/2/
Posted on Sep 23, 2009
I can't find the picture of my play station 3 on this tv. I can't figure out ho to change the tv mode input. I can't find the picture on the tv
If you had this on an HDMI input before you will have to do a reset. Press the power button for 5 to 6 seconds till it beeps. You should be able to select your video output type after that. Don't worry this will not effect anything but your audio and video settings.
Feb 05, 2013 | Televison & Video
My menu monitor setting is not in English, how do I change the setting back to English? Also the picture on the monitor has shrunk, how do I get it back to full screen?
click start control panel,regional and language options select regional language options from the drop down list select the language you want also from the bottom drop up list you can select your present location location or another language
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps
don
Feb 23, 2011 | Emprex LM1704 17" Monitor
I have recently had dish network installed and now I cant get my DVD player to play I have tried contacting dish network for assistance and no one can figure out the problem. I have a LG TV
Hello! This is Dan with DISH Network customer support. have you tried cycling the inputs? If you have an HD tv the DISH receiver and your DVD are probably connected using different cables. I would power them both on and hit the input or source button on your LG remote until you get a picture from the dvd player. Remember what input comes up as you will need to change this to go from satellite to DVDand back.
Jan 12, 2011 | Directed 434MHZ Remote Control
Monitor Display
Check and make certain your monitor is physically hooked to your pc with either the blue or white cable. You cannot use both, so please choose the WHITE one if you can. If you cannot, that's fine. make sure the plugs are fastened SNUG to the back of the monitor and the back of the computer. Make sure the computer is ON (no signal when its off), and then try selecting an input. If it STILL fails, it may indicate a bad cord. unfasten the cables from the screen and the computer, and check the pins for anything bent or twisted. Try another cable if possible.
Jul 01, 2010 | Dell UltraSharp 2407WFP 24" LCD Monitor
Hi, I was recently given a Samsung Syncmasster 2333sw flat screen monitor that I hooked up to my old Dell Dimension 8200 desktop.The monitor says the optimum resolution is 1920x1080 pixels. The maximum the...
hi bob you should be able to adjust the screen size via the menu on the monitor itself, (Available in Analog mode only) Note When TV signal is input in AV mode ,select “Screen Fit “to adjust vertical position in 0-6 levels. Image Size Note Supplied for the wide models only such as 16:9 or 16:10. You can change the size of the screen displayed on your monitor. PC signals • Auto - The screen is displayed in accordance with the screen aspect ratio of the input signals.• Wide - A full screen is displayed regardless of the screen aspect ratio of the input signals. Note • Signals not available in the standard mode table are not supported.• If the wide screen which is the optimal resolution for the monitor is set on your PC, this function is not performed. AV signals • 4 : 3 - Sets the picture to 4:3 normal mode. • 16 : 9- Sets the picture to 16:9 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • 4 : 3 - Sets the picture to 4:3 normal mode. • Wide-Sets the picture to 16:10 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note • It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • When the panel is of 16:10,the screen size options include “4:3”,”wide “,”Screen fit“.hope this helps
Jun 22, 2010 | Dell Dimension 8200 PC Desktop
Have Dell Dimension 2400 and wanting to connect to Emerson LD195EMX.. attach to PC Monitor connection but no scrren comes up/// WHat else can I do?
Is the PC monitor connection - a DVI or DVI-I connection a 15-pin VGA connection an RCA video connection?
Have you set the television input to match the connector used on the TV?
The display resolution on your computer may not be set to a resolution your TV can handle. There is no point trying to put a 1280 by 800 signal into a VGA connector. Start with 640 by 480. However, this will not give you the high resolution you have come to expect from your PC's monitor.
This set also has HDMI input. If your computer has a DVI or DVI-I output, you can buy an adapter that will connect to that HDMI input. Note that this will only handle the video portion of the output from your computer and you will have to use analog connections for the sound and figure out which TV menu input selections allow high definition video with analog sound (not all sets can do this).
Note that LED TVs are not like CRT TVs where an electron beam can put a dot anywhere on the screen. An LED TV has fixed resolution modes.
It might be necessary to use a software product like "PowerStrip" to create a custom resolution mode that will show a high resolution image that will fill the screen of your TV. I wound up using 1352 x 648 to give a full screen image on my LED TV using the HDMI input. ("Your mileage may vary.")
There is a lot more to connecting a high resolution computer display to an LED TV than just plugging it into the "PC Input".
Jan 02, 2010 | Sylvania LD195EMX 19 in. TV
Trying to set my background picture and the browse list is lite up but can't scroll and add picture to the customize desktop and only half my screen gets half the picture the rest of the screen is a color....
try playing around with the position options "stretch and the others" and see if that works. make sure you dont have any desktop theme software on your system aswell and if you do, uninstall it.
is it xp or vista?
Apr 26, 2009 | Computers & Internet
Philips 42" HDMI connection to VGA on laptop connection problems
why dont u just use the vga input and select vga from your input selection. it should work just fine. if not, email me back.
Feb 10, 2009 | Philips 52 In. LCD HDTV
Input not supported
1. Restart the computer.
2. When the computer begins to reboot, press the F8 key repeatedly in one second intervals until the "Windows Advanced Options" appears.
3. Select "Enable VGA Mode" and press ENTER.
4. Select your operating system from the list and press ENTER
5. Follow your normal log on procedure.
6. RIGHT CLICK with mouse anywhere on your desktop.
7. Select PROPERTIES.
8. Select SETTINGS then select ADVANCED.
9. Select ADAPTER then select LIST ALL MODES.
10. Refer to your monitor user's manual or Quick Start Guide for the recommended resolution or mode for your monitor.
11. Select OK then APPLY then OK.
12. Depending on your computer setting, you may need to re-start the computer for the changes above to take effect.
Hope its useful!
Jun 30, 2008 | AOC 193P+ 19" Monitor
Input problem: monitor and thus recording defective, not functioning
I do not know if it will help but i do know that if you do have the original remote control, press the M button, make sure your inputs are the ones selected or else there will be now picture. You can hook this up so many ways but chances are your settings are off, press the M button then press the right arrow key (looks like fast forward key) to change current setting, then press the next key to select the next option, after you have all your hook-ups selected press confirm, it takes about 10 seconds then the picture should come up, if not try the digital cable or the s-video
Jan 12, 2008 | Terapin TX-0002 CD-R Burner
Computers & Internet Logo
David Payne
David Payne
