Question about A4tech KBS-720 Anti-RSI Keyboard
Hi- numbers on keyboard will not work. Only numbers 5 and 6 are working. I can't even log in because I have a password set and the password requires numbers. PLEASE HELP!!
  • 82 Answers
You have a dead keyboard. have it replaced or fixed.
Posted on Sep 23, 2009
I have to enter my password several times to get my kindle to log on. I always have to log on..the signal seems to be weak adjacent to the router. authentication failed is a normal response on my kindle....
your kindle device should be able to connect the network automatically , if this is not happening try adding the network manually.
1.First, make sure you are within range of the network you want to add, and that you know the network name and password (if required).
2.From the Home screen, tap Menu and select Settings.
3.Select Wi-Fi Networks to display a list of detected Wi-Fi networks.
4.Tap Join to enter network details.
5.Use the onscreen keyboard to enter the name of the Wi-Fi network that you want to add.
6.Once the Network Name has been entered, tap the Password box and enter Wi-Fi password / Network Key using the onscreen keyboard (if required).
Tip: Tap the 123 key to enter numbers or symbols. Tap the ABC key to return to the regular keyboard. Tap the Shift key (up arrow) to enter uppercase characters. Your password may include non-English letters (accents, umlauts etc.). To view accent options, press and hold a letter down, and accent options appear.
7.Tap Connect
Does all your wireless devices have weak signal issues?If so , Then problem may be with the wireless router.Try changing the wireless channel on the router by logging into the router interface page.
Authentication failed is the message u ll normally get when u enter the password incorrectly.
Aug 07, 2013 | Belkin (F5D7230-4) Router (587009)
Keyboard will not function at all. The mouse is working but I can't even log in due to the inability to add login password etc.
Try to plug in a USB/PS2 (with adapter) keyboard to see if this works.
Try to get in the BIOS and check to see if the keyboard is enabled.
You can buy a new keyboard for the laptop check amazon. If you do not want to replace it see if office depot or staples have a tech that will.
Jan 22, 2013 | HP 8710p PC Notebook
Required a password for my loptop what do i do?
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
cmos battery Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment. Hope this helps
Jul 23, 2011 | Toshiba 10GB NOTEBOOK HARD DRIVE KIT...
Dell Studio 17 Laptop - all keys are locked....can't even type in password to log in for diagnostic
Unplug the mouse. Boot into the bios and see if the keyboard will work there. If it will. exit the bios. As soon as you see the Dell splash screen start tapping the F8 key and boot inot safe mode. See if the keyboard will work in safe mode. If it will that means you have a driver conflict in normal mode.
If neither of these options work, Contact Dell to get the system either
A. Onsite repair
B. Replace the system.
Also try.....1) disconnect A/C power supply, 2) remove battery, 3) press and hold the "power on" button for between 15 to 30 seconds, 4) re-install the battery, 5) re-start the laptop.
Please check the links bellow to resolve your issue:-
http://www.ehow.com/how_5063232_unlock-dell-keyboard.html
http://www.ehow.com/how_6120625_do-unlock-keyboard-dell-laptop_.html
Please get back to us if you have any further query or else accept the solution.
Thanks for contacting fixya.com
Nov 03, 2010 | Dell Computers & Internet
I tried using Inland Pro USB mini keyboard Model # 70141 with windows 7. when the windows boot and ask me for the password for log in I used the above keyboard and when I type the password it does not...
Try type 'i' key. If it shows '5' instead, then you accidentally press the "Num Lock" key (in blue color next to PrtSc/SysRq key) and turned on the Number lock. Just press this key again and it should work now -- Lakefront
Sep 28, 2010 | Computers & Internet
I need to change our Auto Attendant message to remove the name of an employee that is no longer with us. I have tried Feature 983 but when I enter the recommended 120000 (we have 2 digit mailboxes) it says...
The best thing to do at this point is to reset the admin. password.
To reset the administrator pasword enter feature 985 press 9, at the password prompt enter 73738767793 (resetsmpwsd) and press ok or #,press yes to reset password. password should be defaulted to 0000. then try Feature 983. if your system has 2 digit intercom #s your password is 120000.
To reset your voice mail password, press feature 983 the screen should say log:
enter 120000 (default password)
the display should say mbox, AA, and othr above the three soft keys
press the mbox soft key
the screen should say add, del, and chng above the soft keys
press the chng soft key
enter in the mailbox number you wish to reset the password on
press ok
the screen should say reset and next above the soft keys
press the reset soft key
press the Rls key
your password should be reset to 0000
Aug 13, 2010 | Nortel T7316E 2-Line Corded Phone
LDAP issues with Konica C451
5 Network settings
5-52 bizhub C650/C550/C451 (FE3)
Setting up LDAP
Register LDAP servers and specify authentication settings. Settings can be specified for the following.
Setup LDAP screen 1/6
Setup LDAP screen 2/6
Setup LDAP screen 3/6
Setup LDAP screen 4/6
Parameter Description
LDAP Server Name Type in the name of the LDAP server to be registered.
Use the keyboard that appeared in the touch panel to type in the server name (32
characters or less).
Max. Search Results Specify the maximum number of destinations to be displayed after a search. To
change the setting, press the [C] (clear) key, and then use the keypad to type in
the desired setting. (Range: 5 to 1000)
Timeout Specify the maximum wait time for a search operation. To change the setting,
press the [C] (clear) key, and then use the keypad to type in the desired setting.
(Range: 5 to 300 seconds)
Initial Setting for Search Details Specify the initial search conditions for "Name", "E-Mail", "Fax Number", "Last
Name", "First Name", "City", "Company Name" and "Department" in an advanced
search.
Server Address Specify the address of the LDAP server. Use the keyboard that appears in the
touch panel to type in the address (255 characters or less).
Search Base Specify the search starting point in a hierarchical structure arranged on the LDAP
server. Searches are performed by also including the sub-directories lower than
the starting point that was specified.
Use the keyboard that appears in the touch panel to type in the address (up to 255
characters).
SSL Setting Select whether or not SSL (data encryption) is used when connecting to an LDAP
server.
When SSL is used, communication information is encrypted.
Port Number Specify the port number for the LDAP server. To change the setting, press the [C]
(clear) key, and then use the keypad to type in the desired port number. (Range: 1
to 65535)
Port Number (SSL) Specify the port number when SSL is used. To change the setting, press the [C]
to 65535)
Authentication Type Select the authentication method used for logging on to the LDAP server.
Anonymous: This authentication method does not require a user name and password.
If "Anonymous" is selected, dynamic authentication is disabled.
Simple: This simple authentication method requires a user name and password.
Be careful since the passwords can be leaked over the network.
Digest-MD5: This authentication method can be used on a typical LDAP server. If
authentication fails using Digest- MD5, the authentication is performed by automatically
switching to CRAM-MD5.
GSS-SPNEGO: This authentication method can be used with Active Directory in
Windows (Kerberos authentication).
NTLM v1 and NTLM v2: These standard user authentication methods can be used
with Windows NT.
They can be used for logging on when sharing files and printers.
bizhub C650/C550/C451 (FE3) 5-53
Aug 14, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Sister has forgotten password
If she cannot remember the password you can reset it. This will require a seperate computer with a CD burner and a blank CD to make a bootable disk, then simply follow the instructions on the page linked below.
Before resetting the password check the lights for your keyboard though. You may have your number lock turned on which will turn 789UIOKJLM into 7894561230 creating a number pad on your keyboard. If this is the case find the key marked "num lk" if it is the same colour as the letters pressing it should disable the number pad, if it is surrounded by a line or a different colour you will need to hold down the Fn key then press num lk to enable/disable the numberpad, you should see a light with a picture of a lock come on and off to denote number pad on or off. Ensure it is off then retry logging on with her password. If it still doesn't work, then procede to the link below and follow the instructions carefully.
http://www.watchingthenet.com/reset-windows-password-when-you-have-forgotten-it.html
Hope this helps FixYa,
Chris
May 14, 2009 | Dell Studio 17 Laptop Computer PC...
Moved my GATEWAY KR-0401 wireless keyboard & now won't work!
  1. Check and see if batteries are in keyboard and that they are still good and working.
  2. If the batteries are good and ready to go then make sure that the adapter for the wireless keyboard is plugged into the correct USB port in the back of your computer and that it's working.
  3. If none of the above works then what you'll need to do is go buy a wired keyboard and attach that to your computer and log into your account and find out what's going on with the wireless keyboard. Once you have figured out what is going on with your wireless keyboard then you can take the wired one back to the store and continue using the wireless keyboard. If I were you though I would keep the wired one around just in case.
Apr 08, 2009 | Computers & Internet
URGENT! Jumper setting (J4 jumper)
Hi, You can try this
1. Turn off the laptop
2. Disconnect AC adapter
3. Remove battery pack, and remove the keyboard
4. Remove the battery (located underneath the keyboard, the red/white wire)
5. Leave it for about 30 - 60 mins.
6. Reconnect the battery and reassemble the laptop
7. Reconnect AC adapter (Don't put in the battery pack yet!)
8. Turn on the computer and press F10 to enter the BIOS
9. Set the new BIOS password and save all settings.
10. Turn off the laptop and reinsert the battery
If this does not work you can try and check out a manual for your laptop here.
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=101&prodTypeId=321957&prodSeriesId=1847703
Mar 26, 2009 | HP Compaq nc6400 Notebook
A4tech KBS-720 Anti-RSI Keyboard Logo
533 people viewed this question
Top A4tech Computers & Internet Experts
micky dee
Tony
Are you an A4tech Computer and Internet Expert? Answer questions, earn points and help others
