Question about Optoma Panoview Matte White Motorized Electric Projector Screen
I have a panoview graywolf II motorized screen that is stuck in the down position. I have used the screen fairly often up unitl it got stuck. What are the possible causes?
Fix driver side front window?
You need to remove the door panel, & inspect to see if the glass came out of it's track & is jammed. or could be the electric motor itself, that's if you have power windows. you can purchase a new motor & regulator fairly cheap if this is the issue. You didn't specify if it was power or crank.
Oct 14, 2014 | 2005 Ford Taurus SE
My treadmill is stuck at the highest incline and will not decline
Although it is fairly rare the incline motor can jam up into the highest position and get stuck there. To fix this take off the plastic hood that covers the incline motor and depending on the motor you should be able to wind it with your hand out of the highest position. When it is out of the highest position run the calibration as described in the owner's manual and it should go all the way up and all the way down. If it is not this type of motor that can be wound by hand then the first and last thing to do is to try calibration of the incline as described in your manual. If this does not work then a new incline motor is needed.
Dec 31, 2009 | Proform Quick Burn Pro Treadmill with 12...
Hi! where can i purchase a 12 volt trigger cable for a motorized screen
Most projectors have a 1/8 inch (mono) or tip and sleeve female connector for screen trigger and output 12volts dc when the projector is powered up. So if the Optima screen has the optional trig in and it's 12 volts the cable is very easy to put together. Optima may have a cable available or you could spend just a few bucks at Radio Shack and your all set.
Oct 31, 2009 | Optoma Panoview Matte White Motorized...
Antenna motor runs while the radio is on or off. The antenna is stuck in the extended position. When the car is shut off the antenna motor continues to run to retract the antenna, but it doesn't go
You need to pull the fuse for the antenna or just unplug it. It has a fairly ridgid plastic wire that pushes the antenna up and down. Works fine until the wire breaks then it rolls up (antenna down) but it never increases resistance because the antenna never comes down , it's like a fishing reel when the lure breaks off, so the motor thinks that the antenna is still coming down and it will run and run and run trying to do it's job. Your lucky it stuck up and not down. If you want your antenna to go up and down again you'll have to buy and install a new one.
Jun 02, 2009 | 1992 Jeep Cherokee Limited
Power window broke, stuck up need temporaily lower then back up
you can disconnect the motor and the gear and the window should slide down.. if you can't access that.. you can force the gears to turn
Apr 05, 2009 | 1999 Ford Explorer
My IBM Selectric clutch is vibrating and I can't type
The clutch is dry there is a hole for greasing it but you need a special grease gun you can try to get some oil into it.
DickyO
Jan 30, 2009 | Lexmark Wheelwriter 15 Series II...
IBM Selectric clutch on motor is vibrating
either the shift spring needs grease or the cycle clutch under the left protection shield you will see a gear with a belt to the left of that gear is the cycle clutch which has a hole to install grease
CTX Panoview 630 Monitor
Panoview 630 Power Connector pinouts:
It has been many years since the question was posted but who knows, maybe this will help someone. Looking at the end of the connector clockwise from 1-oclock position:
1pm:NC
3pm:+12
5pm: no pin
7pm:+5V
9pm:+5V
11pm:GND
shield is GND
+5V@3A
+12V@1.5A
(you can modify an Apple ADB cable to work)
Mar 15, 2007 | CTX Panoview 630 Monitor
Optoma Panoview Matte White Motorized Electric Projector Screen Logo
85 people viewed this question
Top Optoma Televison & Video Experts
rostit
Are you an Optoma Televison and Video Expert? Answer questions, earn points and help others
