Question about Whirlpool Duet GHW9150P Front Load Washer
My Duet has been acting up the last week. It flashes the code F2 and will not finish the load. My husband looked in the book and it said a drain problem. He tried to clean out the drain and hose. This did not work. Any suggestions? There is a horrible smell coming from it almost like it is not draining all the water out. Help!!!
  • 135 Answers
Someting is stuck in the pump or the pump has failed and needs replacement. Remove the pump and look inside it.
Posted on Sep 24, 2009
I have a Kenmore HE3t washer than continues to stop during the cycle and flash the F2 error code even after cleaning out lines, hoses, trap, boot and replacing the drain pump.
It is possible that the brushes on the motor that spins the drum are worn down. The drum will start and stop when this happens. Check the brushes.
Nov 07, 2013 | Kenmore Washing Machines
Flashing F2
see the details and fix it. God bless you
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
•check the drain filter pumpfor foreign objects
• If the above does not correct the problem replace the pump
Jul 09, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Have a whirlpool duet model GHW9400PLO. Husband put a rug in it and now it shows an F2 error and will not drain. We have tried unplugging the machine, that has worked in the past, but this isn't fixing it.
Hi dear.According to your explanation,it's drain problem(F2 code).Please get access machine filter.Check it for any obstacle(Rug Fluff etc...)clean it & run the machine.It should get back to normal.Also check for any kink in drain hose.If that does not work you may need to replace the pump.I hope that helps.Thanks.
Sep 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer giving F2 error during wash cycle, cycle doesnt finish
HI. this code represents a Long Drain issue.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain pump filter for foreign objects
Oct 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whrilpool duet front loader washer flashes f2
Potential Causes
• If the above does not correct the problem replace the pump..
Aug 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Started getting an F2 error code
I looked up the F02 code online and this is what it says:
Potential Causes
Hope that helps.
May 18, 2009 | Whirlpool GHW9400 Duet Washer
Whirlpool Duet HT GWH9300P Suds then F2
This means that the drain time has exceeded 8 minutes and the water valves have turned off. After 4 minutes the suds error is displayed then 4 minutes later the F2 error.
Potential causes
1.Check drain hose for kinks or cloggs
2.Check electrical connection at the pump and make sure the pump runs.
3.Check inside of pump for foreign objects
4.If none of the above fixes the machine replace the pump.
Nov 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front Loader
F2=Long Drain If the drain time exceeds 8 mins the water valves are turned off and F02 is displayed
Check drain hose
check pump filter for foreign objects
check pump motor for proper operation
Jul 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front loader
Sounds like you have a board problem. If the machine is only 1 month old, you should really have a warranty agent look at it. You don't want to do anything that could void the warranty.
Oct 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine not draining, not occuring on every cycle. The "F2" code flashes during the cycle. "F2" indicates a drain problem. Is this the control panel or the motor that pumps out the water?
Possible your outlet filer is blocked, clean this out and refit. Refer to manual; the outlet filter requires periodic cleaning according to your usage; things shd be fine...
Aug 30, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
74 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
