Question about LG Refrigerators
The internal refrigerator temp gauge won't reset. LG Tri-door fri
The internal refrigerator temp gauge won't reset. Stuck on 36f in fridge and -3 freezer.
  • LG Master
  • 19,396 Answers
Try first disconnecting the power cord for ten minutes. If it does not reset do a complete defrost. If still no luck, and problem is on both fridge and freezer, then the electronic control board may need replacement.
Enter model number here to get parts and diagrams.
Posted on Sep 23, 2009
Electrolux door alarm Won't stop. We open door to turn off alarm. Temp seems right but slight condensation at the very top of the fridge. Need to at least disable alarm until I can get a repair.
Check the back wall of the freezer, I would suspect the beginnings of or a full-on defrost failure... If there is frost on the back wall of the freezer it means the evaporator is blocked, disallowing airflow to the fridge compartment... Electrolux Refrigerator Defrost Thermostat 216731001 . If there is no blockage, but temps are still not cold enough, your Frigidaire may be leaking refrigerant...
Jul 03, 2016 | Electrolux ICON Professional E32AR75JPS...
LG B218JUDA fridge freezer, the fridge compartment has started freezing food. I've checked temp buttons at 3 and made sure air vents clear
there are more warmer settings . but it could possible the air control has stuck open too far also
Jul 01, 2015 | LG Refrigerators
I have a PFSS5PJXCSS French door with bottom freezer GE Profile refrigerator. Was making an awful noise and both fridge and freezer were warm. I opened back panel of freezer to find ice everywhere,...
Had similar problem, freezer was working fine, but fridge was warm, (68 degrees) It wasnt my damper, the mother board was fried, and so was the inverter board that told the compressor what to do, after having the inverter and two mother boards replaced.......I threw it out, biggest piece of ****, only three years old, and Sears would not stand behind it, even though I used their repairmen. I will never buy another GE product, or enter a Sears store again
Jun 03, 2011 | GE Profile PDS20SFS Bottom Freezer...
I have an amana refrigerator w side by side with freezer at the bottom.what is the best temperatur settinfg is most economical for this type refrigerator?
if you have a fridge/freezer thermometer great.leave inside each one for at least 12 hours to get average temperatures if in use. Answer .. the optimum temp for the freezer is -18/20c.0f, for the freezer and +2/5c.34/36f for the fridge.
Mar 10, 2010 | Amana ARS266ZBS Side by Side Refrigerator
My refrigerator smells horrible! And there isn't anything dieing inside. Please help, it makes all the food taste and smell bad. What do I do?
switch it off.manually defrost whole unit,clean all vents/drain holes, wash interior out with bicarb and dry well.leave door open for 12/24hrs to dry out then switch unit back on and leave (empty) to settle down to operating temp 32/36f is normal for a fridge.then load up as usual.smell like wet cardboard/felt ? is "grow your own penicillin".
Feb 23, 2010 | Hotpoint HTS16HBR Top Freezer Refrigerator
GE fridge has loud clicking noise; model freezer on bottom.
The problem is the main control board on back of refrig . Relay bad and clicking . Have to replace the complete board .
Jul 23, 2009 | GE GBS18KBM Bottom Freezer Refrigerator
Fridge stopped working
Sounds as if the unit is stuck in defrost. How old is it? Look for mechanical {twist} timer and turn it until it starts. If it is a newer model unplug unit for 1 minute this might reset control board but you'll have to know if it is either mechanical or Automatic defrost!!
May 27, 2009 | GE GSH25KGRWW Side by Side Refrigerator
GE PFS22SISBSS Refrig compatment freezing
There is an internal door between the fridge and freezer section that allows the freezer air to enter the fridge side to keep the fridge cold. Sounds like the internal door is stuck open. Steve
Dec 21, 2008 | GE Profile PFS22 33" Artica French Door...
LG model LRFC25750WW 25.5 cuft
You may have a problem with the control board and it will need to be replaced.  You will need to have a qualified LG technician to help resolve your issue.
May 11, 2008 | LG LFC25760ST 25 Cu. Ft. Panorama French...
Control panel lights blink and beep, freezer fan cycles
The column between the doors being warm usually indicates that the compressor is running properly but the condenser fan at the bottom rear that cools the condenser and compressor is not running. Remove the cover from the back of the machine and verify this fan is running. It could have stuck from sitting for a period of time or something has gotten stuck in the blade during the move.
I am interested in what the fan inside the freezer is doing. You say 3-4 second pattern, is it running a few seconds then off a few seconds?
Please post back with the exact model number from the decal inside the fridge and I will look it up and see what I can come up with.
Nov 11, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
51 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
