Question about Curtis Coffee Makers & Espresso Machines
Hello i have a curtis abruzzi espresso machine and the water doesnt fill up it seems that the valve sensor on the front left corner doesnt work
  • 2039 Answers
SOURCE: Fill Water Tank But Water Tank is Full
hello in the water tank they is a float it was probably out of water for a while and the float is stuck take the container in our hand and tap it gently by doing that the float gonna get loose move the container you gonna ear the float move put it back fill with water enjoy cheers
Posted on Jan 15, 2008
Master_Tech
  • 770 Answers
SOURCE: kenmore 80 series leaking
the pump is most likely the cause if you have mach skills i can walk you thru it on how to open the unit and check it let me know
Posted on Jan 24, 2008
  • 38 Answers
SOURCE: Washing Machine Hoover H100M fills too much water in the drum.
this is 1 of 2 solutions  2 this problem the first thing to check is the vacuum system or it is a split in the pressure switch hose
Posted on Mar 05, 2008
  • 74 Answers
SOURCE: Saeco Gran Crema Espresso does not pump water
The machine needs to be primes.
Please trie and release hot water though the steam nossle.
Do like this
Open the steamer and then trie and make a cup of coffe. this will make the hot water come out thought the steamer instead of the coffe outlet.
Why you should do this is becuse the machine has it alot more easier to prime it self though the steamer then the coffe outlet.
Posted on Jul 11, 2008
SOURCE: Gaggia classic espresso machine doesn't
Don't be annoyed, but the first thing is to eliminate possible obvious reasons.
First -- Do you have the water reservoir filled?
Second -- Is the Steam Toggle (the middle black button) turned on? If so, that's the problem. Turn it off, then turn on the far right button -- the machine should purge steam from the group head which will turn to water quickly.
Third -- do you have a blind filter in the portafilter? That is, is there anything other than the filter basket inside the portafilter handle?
Can you get water to come out of the steam handle? To do this, open the steam valve (the round knob on the side of the machine) by turning it toward you. Then, turn on the machine using the third black button. You should hear the pump running and water should flow through the steam wand. If it doesn't, my guess is that the pump is shot.
There is not an awful lot involved in engineering terms in the system, so if water is not coming out at all after trying all of these things, you're going to have to have it serviced by someoe who can actually address the pump issue. This can be done at home, but if it's under warranty I wouldn't hassle with it.
Posted on Feb 01, 2009
Does not refill after brew cycle.
Fill sensor needs to be cleaned. Clean with vinegar. Or solenoid to water inlet is not working. Clean or replace.
Sep 11, 2013 | Curtis D500GT DV Airpot Brewer
The machine will say Fill water tank. So, we will take the container out of the machine fill it to or just a little above the recommended line and then put it back into the machine. It will be full and it...
After filling the water tank, can you see if a grey plastic piece, in the back of the water tank, is floating?. If no, then that part needs to be replaced. If it does float, then the integrity of the water sensor, (located in the back of where the water tank is housed into), will need to be tested. Testing this sensor requires, tricking the coffee maker... that the door is closed. With Coffee Maker in the "ON" position, you will need to hold door switch in (located top right corner of unit, with door opened). As switched is held in, you will need to use a magnet and place it around the rear of where the water tank is housed into (Rear-left middle height area)... just around where the water tank float would be, if it were filled with water and inserted into the coffee maker. This sensor isn't visible, but is activated when a magnet is placed around it. If "FILL WATERTANK" message goes away, then replace plastic float or water tank itself.
Nov 16, 2010 | Miele CVA615 Espresso Machine
Looking for valve
You mean the inlet valve (dishwasher valve), you can get it from wilber curtis online.
May 01, 2010 | Wilbur Curtis Concourse D500GTH G3
Astoria SAE 1 trickle of water from hot water faucet
Some models have an economiser valve, which mixes hot water from boiler with cold from inlet line, that could be closed or obstructed. The line from the boiler to the solenoid or the pipe inside the boiler could be blocked.
Mar 20, 2009 | Astoria Argenta SAE-2 Espresso Machine
Machine wont start
fill it with water start the machine when hot open side valve to let water out if it doesnt do the job remove water tank in the kit of the machine there a little pump put water in the pump in the water hole force water in there with side valve open let me no pierre
Jan 07, 2009 | Saeco Vienna De Luxe Espresso Machine
MyCurtis,Alpha-111S coffee machine isover filling the coffee pots
that model may have a digital timer that is acssed using the panal swithes get the number for wilbur curtis from thier web site they will talk you through it {simple} the other style timer is a potentiometer type To adjust first unplug brewer, look behind either the front panel or top cover for a dial with numbers around it. turn the dial down slightly brew a pot of water see where the water level comes keep turning down till desired level is reached
Jan 04, 2009 | Wilbur Curtis Alpha G3 Concourse...
Front loading washer
if washer is turned off doeas water still come in? if so suspect fill valve if not suspect small hose from tank on left rear corner either plugged or crimped almost closed if hose cks ok suspect water level control
Sep 24, 2008 | Frigidaire Washing Machines
Fill tank
ok on the bottom left side( from the front) is a magnet in the water tank. Sometimes that gets stuck and the sensor wants you to fill.
it can also be that the machine needs to be primed
Mar 27, 2008 | Saeco Vienna De Luxe Espresso Machine
Solis Palazzo Espresso Machine
The machine is still stuck in the descaling cycle. You must open the steam valve and let all the liquid drain from the tank. This takes approx. 45 min. because it comes out intermittenly. After this is complete all the front buttons will flash. Close the steam valve, rinse the tank, then fill it with fresh water. Open the valve again and let all the water drain from the tank again. This time it will only take a couple of minutes. After it has completed close the valve and the machine will return to normal operation.
May 29, 2007 | Solis Palazzo Espresso Machine
Coffee Makers & Espresso Machines Logo
129 people viewed this question
Top Curtis Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Curtis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
