Question about Belkin N1 Wireless USB 2.0 Network Adapter (S6359026)
We formerly used a linskys router, How can we
We formerly used a linskys router, How can we change our laptop to Belkin router? We have installed the Belkin router on the desktop. How can we get our laptop to accept this Belkin router?
  • 3,289 Answers
The short answer is to duplicate the SSID, Encryption Method and Encryption Key that was on the LinkSys router onto the new Belkin Router.
If unable to determine the old settings in the LinkSys Router, start a new wireless network in the Belkin Router by logging into the router with your web browser as directed in the instruction manual or setup disk. It is likely at http:\\192.168.0.1 or http:\\192.168.1.1. On the wireless set up page of the router, create a new SSID and choose an Encryption Method (WPA, WEP, etc.) that is also available in the wireless adapter's setup program. Next, create an Encryption Key on the wireless set up page of the router and put the same key in the wireless adapter. If the laptop's network settings match the Belkin Router settings, you should be able to connect. Put these same settings in all computers and devices that are to connect wirelessly to the Belkin Router.
Posted on Sep 23, 2009
  • 82 Answers
If you have not changed any settings from belkin router, access the wireless configuration on your windows machine and search for the belkin ssid then hit on connect
Linsky cisco E 1000 will not recognize belkin wireless usb adapter N150
You have to check if your router is properly configured.Try changing the settings of the channel from Auto to channel 6and the b and g mode into mixed mode.
Feb 18, 2012 | Cisco Linksys E1000 WirelessN Broadband...
My linsky adapter will not pick up wireless from my belkin router
Well, I require certain information from you before I can help you resolve the issue.
# The model make of the Linksys adapter? # The model make of the belkin router? # Operating system installed on the concerned computer?
Mar 21, 2010 | Linksys Wireless-G Broadband Router
Adding a desktop in bedroom that will NOT connect
PERHAPS DYNEX,AND LINSKYS ARE NOT COMPATIBLE,I WOULD GO FOR LINSKYS ANY DAY SO EASY TO CONNECT,TRY USING A WIRELESS ROUTER,INSTALL SOFTWARFE 1ST,NEVER HAD A PROBLEM WITH LINSKYS
Nov 29, 2009 | E-Machines eMachines Desktop PC
How do I hook up a G wireless router to my h/p computer
The usual setup is to connect your internet cable or dsl model to the WAN port on your wireless router. any devices that were formerly connected to your cable/dsl modem then get connected to the LAN ports on your router. You will need to connect to the wireless router via etehrnet cable the first time in order to setup your wireless connection, it's usually a simple setup following the prompts.
Sep 29, 2009 | Belkin (F5D8231-4) Wireless Router...
How do i install my new belkin systyem when ive
yes you can use it.
first connect your Belkin router to computer with lan cable .
Then access it wityh this link.
http://192.168.15.1
user name as "admin" and password as "admin"or
blank or
"password"
then configure your router as your old lynksys settings.then save settings and restart .
Aug 22, 2009 | Belkin N1 Vision Router
BELKIN G+ PCM NETWORK CARD
Yep! As long as the linksys is "G" also!
Feb 13, 2009 | Belkin 802.11g Wireless Desktop Network...
Inability to connect to Internet
The easiest solution would be to use an ethernet connection. A second problem is probably on most cable modems you can either use a USB connection OR an ethernet connection you cannoot use both at the same time.
Dec 12, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Problem with connection to router and DSL
I would go to run and type in cmd. then type in ipconfig, I believe that is right for windows 98. I would look on there and see if that is getting a correct IP and if the DNS server says 192.168.0.1 if it is a belkin router. ipconfig /? will give you the commands you can use with that. There is a ipconfig /renew that will refresh them all. You might have it set to be a static IP and you would want it to be dynamic and have it refresh by itself. You can go to http://hippo.colorado.edu/info/ipsetup/staticip_setup.cgi?os=win98 for directions to change it to dynamic, I would just do the opposite of what they suggest to make it auto config. It sounds like it is looking for a previous DNS server which is not there anymore because the DSL connection reset.
Dec 20, 2007 | Belkin (F5D7230-4) Router (587009)
Belkin N1 Wireless USB 2.0 Network Adapter (S6359026) Logo
262 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
