I have an rca remote rcu703sp and a samsung tv model txj1366. Yesterday, the remote stopped working after a family member played with the buttons on the remote and the tv. How can I get the remote working again
  • 142 Answers
My freesat remote just stopped working. Ive put new battries in, turned box off and on, disconnected and reconnected it but the remote just wont work anymore please help me
Have you got a video camera? Here is the trick to find out if the remote doesn't really work, or it's the TV that is not picking up the remote signal. Most remote use an infrared led to beam signals to the TV's. And this trick will show you whether that remote's LED is actually working. You and a friend or member of the family is all you need to begin testing your remote. Ask your friend or family member to hold the remote and you hold the camera on without recording. Point the remote about 5-6 feet from the camera. You watch the camera monitor screen while your friend or family member presses the On button or presses the buttons that you think are not operating the TV. With a dim room light, you should be able to see a flickering light coming from the remote in the camera screen. If it's hard to see, which I doubt, since remote infrared LED are pretty bright, you can turn your room lights off and try again. If the flickering LED from the remote is seen and is bright, then try all the buttons on the remote, or at least try the ones that you say are not working with the TV. If all is well, then there is nothing whatsoever wrong with the remote, but chances are that though the remote may beam out infrared light, it doesn't mean it is the right frequency for the TV. It could have lost the frequency and no longer sends the correct signals for the TV. However, the problem can also be with the TV remote's LED receiver. This falls into the hands of a technician's inspection on whether the receiving end of the remote is effective or needs replacement. In this part, you need to have the TV checked.
Nov 17, 2014 | Televison & Video
Hello,i have samsung 13" tv
The original remote has an infrared sensor that you point to the tv "looks like a led except it see through" it has become defective and must be changed, some service shops may carry some, also try Radio Shack.
Feb 06, 2011 | Samsung TXJ1366 13" TV
I need the Magnavox TV codes for a RCA remote control model RCU703SP.
You can get the codes on the link below if the magnavox codes do not work try the philips codes Philips and magnavox are made by the same people.
http://remotefinder.rca.com/default.aspx?site=rca
Good Luck
Nov 28, 2010 | RCA Universal Remote Control
None of my remote controls will control the volume on my samsung
buy yourself a cheap sky remote or get one off a friend or family member.
on the sky remote:
TV,
RED + SELECT (blinks twice)
TV,
0060
TV,
SELECT.
there you go you can now use this as a telly remote and change your channel over, volume, power, if you press the help button this will also change your source/av's
Cheers
Little Dish Fitter
Sep 02, 2009 | Samsung Remote Control
I have a trutech t.v. and i want to program it useing a rcu703sp
I'm having the same problem with my Trutech tv and the RCA remote. My email is legolastt2002@hotmail.com If you have solved it, id appreciate any and all help. Thanks
Jun 15, 2009 | RCA 244889 Remote Control
How do i program my remote control rcu703sp and my
Programming a Device using Code Search:
1.
2.Manually turn ON your device (TV, VCR, Cable Box)
3.Press and "HOLD" CODE SEARCH
4.Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type
of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
5.Release CODE SEARCH.
6.Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
7.Once the device turns off, press and release ENTER.
8.With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
1.
2.Find codes for each device and brand below.
3.Press and "HOLD" CODE SEARCH.
4.Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable).
When the selected device button flashes proceed to the next step.
5.Enter the three digit code from the TV, VCR or Cable Box code lists.
6.Release CODE SEARCH.
7.With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using
another code number from the lists.
Mar 16, 2009 | RCA Universal Remote Control
RCA universal remote RCU703SP wont program Magnavox TV
cheap universals dont hold as many codes, the best universal remote is the all for one range with the best being the comeleon
Jul 23, 2008 | Philips Magnavox Learning Universal Remote
Tried everything, but can't find the right code to work.
While this isn't really a solution, I have the manual and it doesn't list an Emerson DVD/VCR (EWD2204) that I have. I can't get it to work with my VCR. I bought the RCE Universal remote (RCU703SP) at Lowes (in 2008). I can't help but notice that the date on the package is "2004 Thompson, Inc." I know that the DVD/VCR is newer than that. Perhaps this remote is a bit old (explains why it was cheap?) Anyway I did find a site that you can get the codes like in the instructions: http://remotefinder.rca.com/default.aspx?site=rca so hope this helps.
Feb 23, 2008 | RCA ACC-RCAURC Remote Control
Televison & Video Logo
134 people viewed this question
Top Televison & Video Experts
Electro Med Services...
