Question about Lexmark JetPrinter Z11 InkJet Color Printer
My lexmark z11 prints everything 3 times. how can i stop this from happening?
  • 3,866 Answers
If your printing in word click on print setup that should pull up a dialog box where it says copies put zero and save it. You should be good to go from there.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Sep 23, 2009
First line prints okay with Lexmark Z-11, but after that it's anybody's ball game.
What is the operating system of your computer? Disconnect the printer from your computer. Reboot pc. Unplug and replug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Try to print again.
Note: The Lexmark Z11 printer only works on Windows XP 32-bit and Windows 2000 (http://bit.ly/m41dci)
May 24, 2011 | Lexmark JetPrinter Z11 InkJet Color...
I need to get instructions on how to properly line up the print heads after installing a new cartridge on my printer, a Lexmark Z11 color printer. Thanks.
In XP - Maybe in Vista and 7 too.
Start
Control Panel
Printer and Fax
Highlight your printer (Z11)
RIGHT click it
Select Properties
Print test page
Follow directions
Dec 22, 2009 | Lexmark JetPrinter Z11 InkJet Color...
Triple vertical printing with Z11
Here's what worked for me: (I'm using a black ink cartridge, but my 'printer properties' were set for a color cartridge, thus basically sending a '3-color signal' to my printer; making it print in triple vertical.)
Go to Settings > Control Panel > Printers. Right click on your printer, and click Properties. Click the Cartridge Maintenance tab, then click Install / Change Cartridge. Select the cartridge you are using in the drop-down list, and click Continue. Print an Alignment Page. If this dosen't work, close everything and try it again: I had to do it twice to get mine to work. Hope this helps!
Kerry
Apr 27, 2009 | Lexmark JetPrinter Z11 InkJet Color...
Lexmark Z11 won't work
Remove the software for the printer through ad remove programs in control panel
Then keep unit unplugged from usb. Install the device drivers then plug unit in when software asks or after it requests a reboot.
Jan 16, 2009 | Lexmark JetPrinter Z11 InkJet Color...
PRINTER INSTALL
plz download the drivers from the lexmark website
Jun 16, 2008 | Lexmark JetPrinter Z11 InkJet Color...
Reinstall printer
You can download your driver here:
http://downloads.lexmark.com/cgi-perl/downloads.cgi?lxkprod=Z11+Color+Jetprinter
If you have Vista:
Please note: At this time, Lexmark does not have a driver for this printer which is supported by Windows Vista.
However, people have reported success using the Windows 2000 driver on Vista.
Feb 11, 2008 | Lexmark JetPrinter Z11 InkJet Color...
Lexmark z11 Vista Compatible?
Looks like I've cracked it [Touches wooden desk]. Need a USB to IEEE 1284 36-pin Parallel Printer Cable, like the one I received today (ordered yesterday from www.cables2u.co.uk). First, connect it to Z11. Turn on Z11 and boot up Vista PC/laptop. (I run Vista Business on my laptop.) Connect cable to computer. Message appears "Installing device driver software". Click it for status. 'Found New Hardware' box appears. Click 'Locate and install driver software'. A message appears "Error loading LXADSUI.DLL. Specified module could not be found". Click 'OK'. Message appears saying driver software installed successfully. ["Yeah, right ..."] (Have faith, folks!) Now, click Start, then Control Panel and double-click Printers. Right click on Z11 and click on Set As Default Printer. Right click on Z11 again and click on Properties. Check on Ports tab that Port USB is ticked for Z11. On Cartridge Maintenance tab, check right cartridge is showing. If not, click 'Install/Change Cartridge' and follow instructions. Then 'Clean Print Nozzles' and 'Align Cartridges'. Check settings on the other tabs in Properties look OK and try printing a test page! It looks good to me!
Jan 15, 2008 | Lexmark JetPrinter Z11 InkJet Color...
Lexmark z11
Your printer thinks you are using a color cartridge. If have the lexmark printer manager software, go to "install new cartirdge" and tell it that you are using a black cartridge. Otherwise, install a printer driver, reinstall the printer, and set it up again.
Driver link (if needed):
Dec 24, 2007 | Lexmark JetPrinter Z11 InkJet Color...
Lexmark Z11 Printer will not work
i am having the same problem and after looking it over, something is not feeding it thru the beginning of the paper starting in. if i pust 1 sheet down far enough to grab the paper it will print one page at a time. I have been unable to determine what is not feeding at the beginning yet.
Oct 03, 2006 | Lexmark JetPrinter Z11 InkJet Color...
Open Questions:
I have a Lexmark Z11 that sat unopened in the box for several years until it was given to me as an emergency printer. The black ink cartridge had been pilfered by the original owner ( he got several of the se printers on clearance for $15 each). I bought a remanufactures high capacity cartridge. It workef fine for the three days of printing I did last week (about 25-30 pages of resumes and reference letters). When I went to use it a week later, it goes through the motions of printing but no ink is put on the page. I ran the clean cartridge several times but still no ink. I tried the new still-in-the-box color cartridge and did get color on the page in the alignment trial, but it was faded and full of white lines. I figured the cartridge was just old. It could be the ink leaked out of the remanufactured cartridge, but when I gently blew on the air hole I got a small splat of ink. (I used to be a sales rep for Canon printers a dozen years ago and we were told to do that to see if the cartridge still had ink.) I deleted and reinstalled the printer, unplugged and replugged cable and power cord twice. The printer receives the command and goes through the motion of printing, but as I said, no ink is put on the page. I have come to the conclusion the perhaps the remanufactured cartridge is at fault and I should take it back for an exchange, Can I get your take on it - is it the cartridge or the printer? Thanks! -Kathleen Brockway
Mar 01, 2017 | Lexmark JetPrinter Z11 InkJet Color...
Lexmark JetPrinter Z11 InkJet Color Printer Logo
145 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
