Question about Mitsubishi WS-65511 65" Rear Projection Television
Plug it in and will not turn on , the green light
Iplug it in and will not turn on , the green light just keeps blinking. the tv does not respond to any buttons on the panel nor remote.
  • 360 Answers
Only thing I think you left out was to try another outlet and power strip. I don't think it matters, like mine they give two thumbs up and won't respond or contact Mitsubishi. I wonder if this is serious or a joke!
Posted on Nov 03, 2009
  • 1 more comment
  • Richard Klein
    Richard Klein Nov 03, 2009
    Whoops! that comment was to go under clarification. FixYa, where is the clarification button. You can't clarify any more? They just say it my computer.
  • Richard Klein
    You can tell I'm real hard up to answer questions. I figure, even if you have a great solution to a problem you better think twice about posting it, because not even a drawing a map will help you if they can't read maps.
  • Richard Klein
    You really don't get your pick of the quick fix solution, or the correct solution here.
  • Mitsubishi Master
  • 3,866 Answers
This Tv has issues with its powersupply it would be hard to narrow down through email. This will need service to the power supply you might have a bad fuse or capcitor going on in there but to be sure of those facts please consult a tv reapir in your area.
Posted on Sep 23, 2009
I turned my t.v. on w/the remote. it came on then turned right off. at least i thought it did. there was no picture and the power light was blinking on and off with a green light. I pushed the power button...
Hello; This problem is likely caused by bad inverter board(s). I think there are 2 on the left side on this model. If either inverter doesn't start, the microcomputer on the main board see's this and generates one "lamp error" . Once it counts 5 lamp errors, the screen will not light and led(s) will flash. These boards are about $100 each and no way to know which is bad. It can also be caused by a bad LCD panel ( cost more than the TV sold for). You can verify a lamp error problem by doing a "forced start" . The set must be unplugged. then"I think" Hold the channel up and volume down buttons on the set or VISa Versa, and plug in without releasing these buttons for several seconds. If the set makes a buzzing noise , the power supply board is bad. If the set comes on and stays or goes off this is the inverter and/ or LCD panel problem. John
Dec 10, 2010 | Sharp LC-32SB24U 32 in. LCD TV
I have a Sharp flat panel model LC-20SH4U. The units power LED light is red. No effect (sound or picture) when remote or on/off switch is activated. The LED light slightly blinks.
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Hope this may help;
Regards,
VOTIT
Aug 09, 2008 | Televison & Video
62HM15 Toshiba DLP TV won't respond to remote or control panel
Blinking is a trouble code. Try unpluging for a longer time then hold power button in when pluging back in to try and reset.
Mar 15, 2010 | Toshiba 62HM15 62" Television
Flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
The timer light green blinking all the time
You most likely have some bad capacitors on the dm board, unfortunately the board is not available for this set, the complete chassis has to be sent in to Mitsubishi to be rebuilt.
Sep 08, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Plasma tv wont respond to the buttons being pushed on the tv
ok ,try cleaning the remote, first.open it up and clean it with alcohol and soft cloth.let it dry.then,assemble it.be sure your batteries are ok.
May 28, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
Apr 10, 2009 | Sony WEGA KDE-42XBR950 42 in. HDTV Plasma...
Green light blinking
The green light on the front blinkes and does not stop even after hitting re-set button.
Oct 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Timer light blinks on and off and tv wont turn on
Resetting the TV
NOTE:
7. Turn on the TV.
If ever resetting is no effect then the problem is in the "DM board"
The constant blinking green light means that the TV is not booting up. This is a common problem on this set. Hope it may help you; Regards, VOTIT
Sep 25, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Sep 22, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Open Questions:
See all Mitsubishi WS-65511 65" Rear Projection Television Questions
Mitsubishi WS-65511 65" Rear Projection Television Logo
201 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
