Question about Konica Minolta Office Equipment & Supplies
Bizhub C350 gives error code C-OF36 while making duplex copies . M achine will produce half a dozen copies, then return the error code.
  • Konica Minolta Expert
  • 158 Answers
That code means low toner density in the black developer unit so you either have a failed pwb mc board or a failed black toner motor
Posted on Oct 15, 2009
I ave problem on c350 error code 2160
BIZHUB C350 SHOWING ERROR CODE C-0900 AND
NOW C-0950
Sep 30, 2013 | Konica Minolta Bizhub C350 Digital Copier,...
Konica minolta bizhub c350 error codes c-0510
eror code c-0098 meaning ??????????????pls tell me the solution
Jul 31, 2012 | Konica Minolta Bizhub C350 Digital Copier,...
How do you clear error code on a bizhub C350. A piece of paper was fused on the fuser unit and we were able to get the paper off. Now we have no access because the panel is locked.
while powering up machine hold down utility/counter key until trouble reset appears on screen. select it and ok should apper under it. power down machine for atleast 10 sec and turn machine back on.
Jul 22, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
BIZHUB C350 code C-0208
You need to replace the drum-corona wire assembly. It is a consumable part, but it is a bit more complicated than just replacing a toner cartridge. You will have to determine which color the bad drum is associated with as well.
May 19, 2011 | Minolta C350 Printer
When printing duplex A3
If you have the duplexer installed and can use it in the copy mode fine then you probably don't have it installed under you printer setup screen. Just go to printers&faxes in Windows. Double click on the C350. Then click on properties, then upper left should be a configure or advanced tab which lists all the installed options. Make sure that duplex unit is installed and not disabled.
Apr 07, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Volume track (e.k.c.) error on Minolta C350 Bizhub.
go to the properties of the driver and click on printing preferences and click on authentication/account track and the user name and password that you use to make a copy will have to be enter in this area to to print
May 27, 2009 | Minolta C350 Printer
Konica Minolta Bizhub c350 error code c-0510. What is it? How do I fix it?
C0510 Upper fusing roller abnormally low temp
replace the thermistor in the fuser
Sep 25, 2008 | Office Equipment & Supplies
Copier malfunction
Code C0F36 is a low toner density error on the black developing unit.
Was it asking for black toner before this code appeared?
Feb 10, 2008 | Konica Minolta bizhub C250 All-In-One...
Erroe code
You post a wrong printer nr, you must have bizhub C350 not bizhub 350, beacause 350 doesnt have that kind of code.
In Bizhub C350 that code means:
C12C0: Hard disk recognition error
You have the following options:
- reinstall the hard disk
- change hard disk
or as a last chance change PWB-MFP
good luck
Feb 06, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
631 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
