Question about Samsung SCH-U310 Knack Cell Phone
Whenever I turn my phone on, the startup bar becomes half full, and then reboots.
My laptop only connects to the internet in safe mode
Boot into safe mode with networking. Download malware-bytes Run a full malware scan, remove any malware and reboot into normal mode. This may have fixed the issue. Failing this download super anti spyware and do the same with that tool. If both these tools come back virus free / do not fix the issue click on start, run. Type 'msconfig' into the box, hit enter. Half the startup items and reboot into normal mode. If you can access the Internet the software causing the problem is in the half of the startup items not running. Keep halving this half until you find the suspect software and remove it. ( no matter how big the number of startup items it will always take the same amount if halfing to narrow it down to one.
Apr 17, 2013 | HP Compaq Presario V2000 Notebook
Dell latitude d600 can't click my start button
I would suspect , 1, you have to many startup programs, use CCLEANER at : http://www.filehippo.com/download_ccleaner/ This freeware program will remove the junk from your Dell and in the TOOLS section, STARTUP section, disable ALL unnessary startup programs. 2, Download MALWAREBYTES freeware at : http://www.filehippo.com/download_malwarebytes_anti_malware/ Run a FULL Scam , Delete ALL results , Reboot. If you are using Windows XP use these tips: http://www.wikihow.com/Speed-up-a-Windows-XP-Computer You could consider more Memory, your machine supports up to 2GB's.
Feb 20, 2013 | Dell Latitude D600 Notebook
Remove produtools from computer
First remove ALL TOOLBARS from your broswers, they will kill your broswer. Download MALWAREBYTES at: http://www.filehippo.com/download_malwarebytes_anti_malware/, In the install, uncheck the trial pro version, you want the freeware version. Run a FULL SCAN, depending on the size of your HDD may take hours. DELETE ALL RESULTS. Before you reboot Run a FULL SCAN with YOUR UP-TO-DATE Anti Virus. Download CCLEANER at : http://www.filehippo.com/download_ccleaner/. Clean the junk from your computer. In TOOLS, STARTUP, Disable ALL unnessary Startup programs and Uninstall ALL unnessary TOOLBARS. For further assistance respond to this post.
Dec 08, 2012 | Computers & Internet
Phone memory full and its hanged > turn off the phone and turn back ob....this time it just blink at samasung startup logo..keep on blinking.
masri mutali hello there is no memotyry on the phone for it to boot up. If you can you do a hard reset on the phone. You should be able to reboot the phone. you can use 0000 or 1234. use this of you are still inable to reboot the phone . you will need to go to samsung.com and look for alternative hard reset for your phone. it will givew you step by step directions
Mar 18, 2011 | Cell Phones
Recently, my W760i has not been responding whenever i switch it on,the startup screen appears, but it still would not startup. i also noticed that its battery is bloated.Does it have anything to do with my...
I think there might be a problem with your battery. Check if it is full-charged and if it is, try to switch your phone on. If you still can't access it, i would suggest to get a new battery for your phone.
Dec 23, 2009 | Sony Ericsson W760i Cellular Phone
Magellan RoadMate
The map software has become corrupted..
Please rate my help++++Thanks for using FIXYA
Oct 09, 2009 | Magellan Roadmate 760 GPS Receiver
Freeze when it turn on. Start up bar pass half way
ur fone probably had contact with water take it to the condore shop
Jul 09, 2009 | Sony Ericsson G900 Smartphone
Eee pc won't start
sounds like a registry error try to start in safe mode if it does the same thing then when it starts to boot and says xp and the bar starts to move hold down the on off button till it goes off and let it set for a bit (let the hard drive stop turning) and reboot should send it into chkdisk whick will correct the registry error
Apr 17, 2009 | ASUS Eee PC 1000H Laptop
Samsung F480 won't startup
press Camera button + volume down + power button ( together )
if the mobile turn on and show ( download or any word .. so you can fix it by changing the software )
Dec 19, 2008 | Verizon Communications Samsung Juke Cell...
Whenever I start computer I get Nikon Picture Perfect 'Import Assistant' on desktop. annoying....how do I turn it off so it doesn't show up every time...I know where to find it if I need it.. - using...
go to start, type " msconfig " to get to startup. General tab, click on selective startup.
On the startup tab uncheck picture perfect Import Assistant and anything you don't want running in the backround. Hit apply and reboot.
Jun 30, 2008 | Computers & Internet
Samsung SCH-U310 Knack Cell Phone Logo
649 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
