Question about Precision Camera Precision Dual-action Airbrush-auto/car Paint Spray Gun
Anyone know any good tips on sraying laquor with and airless air brush seems to run
  • 582 Answers
SOUNDS LIKE TO MUCH LIQUID BEING DISBURSED . I DO KNOW LAQUUOR WILL RUN EASY AND TAKES MORE KIGHT COATS THEN HEAVEY COATS
Posted on Sep 23, 2009
My 640 titan run but will not prime it does not spray product
It is hard to follow your question....however; if the sprayer turns on and the paint fails to enter the nozzle, you may have a blockage. Take the spray nozzle apart and run hot water over it to clean it out. You may need a small brush or cu-tip to clean the inside of the barrel. Blow though it and see if air passes easily. reassemble and run as you normally do. Be certain the top is attached to the paint reserve tightly and securely. Any air leaks will prevent the sprayer from building up pressure within and thus no spay will be emitted.
Dec 19, 2013 | Titan 440 Impact Airless Paint Sprayer...
Wagner 404 Plus Airless motor stops.
All airless sprayers are on-demand pumps. The two settings are prime and spray. When it is set to prime, the pump will draw liquid from the bucket below and pump it out the side tube and will never stop until you switch it back to spray. When set to spray, the pump will run until the pre-set pressure is reached, then stop. As soon as you start spraying, the pump will run until a few seconds after you stop spraying. Tip size and pressure setting will affect how long after you stop spraying the pump will run. A large tip and high pressure will cause the pump to run longer after you stop spraying.
Sep 02, 2017 | Wagner Air Tools & Compressors
Owners manual for a campbell hausfeld model # AL233300LX airless sprayer
http://www.chpower.com/manualsearch/
Manuals for Model: AL2333Manual Description Classic Mega Bytes
AL SeriesParts List- AL Airless Breakdown.6AL SeriesParts List- AL Airless Models - Breakdown with Block- 2001.073.1AL SeriesSafety Sheet- 2011.06AL SeriesSpecifications- Airless Tip Compatibility.3AL SeriesSpecifications- Paint Tip Selection Chart- 2003.04.5
Nov 12, 2011 | Campbell Hausfeld Airless Spray Guns &...
CH 1/2hp airless paint sprayer model# AL 2310 wont prime, how do i fix
Just had the same problem with the same exact unit. Here's how to fix. Turn the pressure knob fully counterclockwise. Take a 5/8's wrench and back out the pressure knob 2 full turns. Yes, the exact same knob you just reversed only get a wrench on where it connects to the unit. Run it for a minute like that. On off a couple times.Run the gun and get the air out. You should notice it working. This is per the owners manual. Good luck man.
Mar 08, 2011 | Campbell Hausfeld Airless Spray Guns &...
Spray gun wont stop spray when trigger is released
There is an adjustment nut on the back of the neddle but most likely is it wasn't cleaner the last time it was used. Take off the tip houseing then re move the nut on the front of the gun thats the seat for the carbide ball on the front of the neddle re move the neddle and clean all parts in laquor thinner then it should work
Dec 17, 2010 | Wagner GX10 Spraytech Airless Spray Gun...
Can't find a part #
http://www.chpower.com/webapp/wcs/stores/servlet/chCat_10051_10001_10661_-1
service center, find a part. write inlet outlet valve
May 15, 2010 | Campbell Hausfeld Airless Spray Guns &...
Still wont prime new packing new check balls dont know what else to do it is a spraytech ep2105
wish i could offer better advice but call tech support, they are usually pretty helpful with this... theyll talk you through..good luck
Mar 04, 2009 | Campbell Hausfeld Airless Spray Guns &...
AL2340 will not prime. Motor runs but cannot get it to prime
I worked at a tool rental center when I was going to college and learned many useful tips / tricks about airless sprayers. Airless sprayers have two check valves/balls that can stick on their seats or stay open due to chips of paint on seat. Easy method to prime is to remove intake filter from machine, tilt the machine back far enough so that the pick-up tube is pointing up high enough to pour water in tube until full; hold in this position and turn on machine. If water is sucked in turn off machine and tilt machine into pail of water and restart to check for prime. If it still will not prime remove water from pickup tube and use air pressure into tube with bypass valve open. Air pressure will attempt to release the stuck lower check ball. If air pressure does not release stuck ball you may have to use physical pressure against ball. If lower check ball was stuck you can assume that the upper check ball is probably stuck also. An aid to loosen stickey valves is to pour solvent into pickup tube with machine tilted back as before leave overnite. Enjoy
Dec 09, 2008 | Campbell Hausfeld Airless Spray Guns &...
Precision Camera Precision Dual-action Airbrush-auto/car Paint Spray Gun Logo
63 people viewed this question
Top Precision Camera Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Precision Camera Air Tool and Compressor Expert? Answer questions, earn points and help others
