Question about U-Line Icemaker
Water runs constantly and it is not making ice. The cover over the ice maker is impossiblt to figure out how it fits.
  • jatoy Sep 23, 2009
    it is a u line under the counter ice maker. model number is uln-clr 60B-00
    cover guard will not reattach - runs constantly and does not make ice
  • 2,841 Answers
If water is running constantly the solenoid is defective and not shutting the water off when it is suppose to. It is located where the water supply is connect to the refrigerator. Replace the solenoid. The cover I cannot help with.
Posted on Sep 23, 2009
    President:
  • 1,714 Answers
There is no make or model listed for the machine?
Ice maker won't stop filling. Makes a little ice, but water is almost constant into the maker
The water control valve is shot. It's not making ice because there is a constant flow of water into the ice tray. Shut the water off at the feed point for the fridge for now. If the drain gets plugged you're going to have a small catastrophe on your hands.
Here's a procedure to test it to be sure:
How to Test Fridge Icemaker Water Inlet Valve Refrigerator Repair
Mar 20, 2016 | Kitchen Appliances - Others
Where would a scotmans mv450 leak there is no constant water running enough to make the ice
if water was leaking you would see it. sounds like your not getting water, check water shut off valve to make sure it is on, check water filter make sure it is not stopped up, check water inlet valve make sure it is opening and is not stopped up, check to make sure water supply line is not kinked.
Jan 17, 2014 | Hoshizaki F-1001M Flake Ice Maker
Icemaker runs constantly but never makes enough ice to shot off. Too much water spraying out and melting the ice. What to do? Have run through cleaner cycle several times. Disassembled and cleaned also.
Process of elimination. ... ice thickness sensor (adjust and clean).... water outlet bar with holes that runs down the ice maker plate (make sure all the holes are not clogged and point to correct angle to keep from splashing) check those 1st.. the other steps are more involve if you have refrigeration tools to check refrigerate level, etc.. let me know if this will help 1st
Oct 31, 2013 | Manitowoc SM50 Series Ice Maker
Icemaker not working- red light flashes constantly
The red light should flash twice , pause then flash twice constantly . If you close the flap on the left side , then the light should go off . This shows the optics (ice maker cut off ) are good .
Check the black tube ( fill tube ) , which puts water into the ice maker , to see if it is iced inside . If so , then the water valve behind the refrig is bad . It seeps into the tube and freezes , blocking the water flow .
Pour about 2/3 cup of water into the ice maker . If it freezes and dumps , then the water valve needs replaced . If it doesn't dump , and stays frozen in the ice maker , replace the ice maker . Also , make sure the coils under the front of the refrig are clean , as this will cause warmer temp in the freezer and the ice maker needs 5 degrees to operate .
Sep 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker shuts off when not used
Check to be sure water line is clear of hard water or Ice.
Jul 02, 2009 | Refrigerators
WE have replaced our ice maker in our Whirlpool refrigerator 4 times in the last 4 years. Our refrigerator obviously is a Whirlpool and the ice maker was ordered with the ice maker installed. WE are...
If the fill tube gets choked up with ice, (Figure S-4) it usually means that the water fill solenoid valve is leaking. The valve is not closing properly and is dribbling water. If the leakage is slow enough, water may freeze in the fill tube. Over time it will freeze the tube completely shut.
Apr 04, 2009 | Refrigerators
Water running from bottom front of refridgertor
Can you tell if there is any water in the ice cube "basket"? If it is full, then your ice maker is not sensing the water level "full" and keeps running. The fridge is normally able to handle a little overflow, about one pint or so, but cannot handle a constant run of water. If it is empty, the supply line may be disconnected somehwhere along its route, most likely near the bottom and at the rear of the fridge. You can pull the fridge out and look at it by removing the back cover. If the line is disconnected, reconnect and have a happy new year. If it is connected, here are two options as I see it.
One - check to make sure your ice maker is properly plugged in and installed at its location in the freezer. If you or someone you love has recently cleaned the fridge or shoved a fifty pound turkey in there, the ice maker may have come dislodged.
Two - replace the icemaker. These units come as a single purchase as you cannot just buy the senser. Cost of most of these I have seen are about $125 for the part (easy to install), which can be a deal breaker. Ice cube trays are $1.99 for two at the local hardware and they don't usually overflow.
Dec 26, 2008 | Refrigerators
Update on the above! The water does shut off, but when the water is running it runs and splashes for awhile down all over the ice thats in there. Water bill is very high when it is in use.
Mar 28, 2008 | Hoshizaki Freezer Commercial Ice Machines...
U-Line Icemaker Logo
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
