Question about Dryers
Dryer does not run when you push start
All of the setting indicator lights work properly as does the interior light when door is opened. When you push start you hear a click but the dryer does not start. If left on, the timer does count down.
  • 220 Answers
Is this a Maytag? What brand and model do you have?
Posted on Sep 23, 2009
Have ptdn600emwt dryer when pressing start button makes noise but does not run
I have found that the switch activated by the door close or turns on the interior light when open on is likely the problem. You may notice that if the door is open and you push the start button, it will buzz. So if the door is closed and you get this buzz when pushing the start button, there is a problem with the door switch. The start button "thinks" the door is open, and therefore not start. The defective door switch needs to be replaced. At least highly likely.
Feb 27, 2015 | GE PTDN600EMWT Dryer
Door is ajar message when shut light comes on but doesnt run
That's because the door switch isn't getting pushed when you're closing the dryer door for some reason or another. Its located at the top of the door. Try pushing the switch by hand and seeing if the light shuts off when you manually push it.
Nov 27, 2013 | Samsung DV337 Electric Dryer
Push the start button. The dryer will run. Release start button and the dryer stops. The end of cycle chime sounds. The timer ticks. Placed all controles in every position and the results are the same.If...
probably has a broken belt,there is what is called a "Broken Belt" switch by the motor inside on the idler pulley tensioner for the belt,if the belt breaks this switch opens so the dryer wont run without the drum turning so as not to overheat and burn your clothes,replace the drum belt and you should be good to go
Jan 21, 2011 | Whirlpool GEW9878LW Electric Dryer
Interior lights staying on causing dead battery. also interior lights flash off and on when driving
Inside the door jamb is a little plunger the it pushed in when the door is closed. It sounds like it is not working properly. If it was working properly it turns on the interior lights when you open the door and turns them off when you close the door. Hope this helps.
Dec 14, 2010 | 1995 Jeep Grand Cherokee
Push start button dryer runs 1 second. Hold start
HI! The Push To Start Switch is defective. Click on the following link to order a replacement switch. !http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Dryer-Parts/3977456/0026/110/Model-11063952102/0582/0151200?keySuffixId=NA&productTypeId=x&searchModelNumber=11063952102&subCompDesc=Top%20and%20console&brandDesc=KENMORE&modelDesc=ELECTRIC-DRYER&pathTaken=partSearch&blt=11 for only $9.96. If you have a SEARS store closed by, you can get it from them.
To install, check the diag. on this page http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11063952102/0582/0151200/P0211134/00001?blt=06&prst=&shdMod=
Good Luck! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Dec 08, 2010 | Kenmore 63952 Electric Dryer
Kenmore electric dryer series 70 makes loud buzzing noice
Sounds like you have a motor problem draging and it can't get started I just replaced one same problem.
Apr 24, 2010 | Kenmore 63942 Dryer
The light burned out last week and now the dryer won't turn on
Some dryers that have an interior light that is controled by the door switch, check the light to see if it's burned out, if it's not your door switch may be bad, when you open the door the door switch allows the interior light to come on, when you close the door the door switch shuts the light off, a bad door switch will not allow your dryer to start.
Feb 28, 2009 | Whirlpool LER4634J Electric Dryer
Dryer will not start.
Check your door switch. It sounds like the door switch is not engaging (closing properly). If the switch contacts stay open, the interior light stays on the dryer will beep when you attempt to start it. This is the push button toggle switch on the door frame. This is a common symptom of this problem.
Open the door and push in on the switch, If the switch is working properly, the light will go out. If it doesn't, you will need to make sure the switch is not loose. Next, check the wires leading to the switch to make sure they are not loose, broken or grounded to the case anywhere. If all the wiring checks good, you will need to replace the switch. This is a very simple repair. Let me know if you require further assistance. I hope this helps you.
Oct 16, 2008 | Whirlpool Dryers
3 beeps and lights flash when I push the start button
The door is not compltely closing. Make sure to push it in hard around the clasp areas. If yours has a light, the light should turn off and on as you open and close the door.
Sep 10, 2008 | Frigidaire FEQ1442ES Electric Dryer
Sounds like its blown a thermal fuse.Its under warranty if you just bought it.You need to set up a repair while you have warranty.
May 21, 2008 | Dryers
Dryers Logo
61 people viewed this question
Top Dryers Experts
