Question about Logitech X-530 Computer Speakers
Logitech x-530 Speakers Issue :(
So the deal is, I have no connection problems or anything of the sort, when I run the test option all of the speakers work correctly, however when I go to play music or something say off youtube I only get the 2 front speakers and the subwoofer? Not too sure what the problem is any comments or help is very much appreciated! Thanks and Cheers.
  • 82 Answers
If you have an analog connector for your speakers and your audiocard/onboard audio at the back of your computer supports 5.1 audio, connect the green to green, yellow to yellow, black to black. then on your audio tray in in windows, you must enable 5.1 sound.
Posted on Sep 23, 2009
I bought a Logitech X-530 5.1 Speakers today. I have connected correctly all the speakers, but there is no sound from rear speakers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems:
hope this helps
Jun 30, 2011 | Logitech X-530 Computer Speakers
X-530 logitech surround speakers how do I install please
coming from the speaker with volume control, there is a cable with 3 jacks, connect them while your computer is running, yellow to pink, green to green, black to blue. a window should open asking what you connected. green is front, yellow is center/sub, black is rear
Dec 27, 2009 | Logitech X-530 Computer Speakers
Computer can't find the damn speakers
I didn't find the x-530 but I did find the install guide for the x-540 which I assume is similar to yours. Most speakers (including yours) do NOT require software to work. If anything it's the sound card on your PC that requires drivers to work but if that is working fine then your speakers should plug and play and work w/o any software.
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/fattach_get.php?p_sid=5FDKVTAj&p_li=&p_accessibility=0&p_redirect=&p_tbl=9&p_id=5524&p_created=1160578991&p_olh=0
Copy and paste the entire contents above into your address bar to go to installation guide. If you have it connected correctly and it is receiving power then perhaps your Sound Card is not working correctly.
Jun 21, 2009 | Logitech X-530 Computer Speakers
I have logitech x-120 speakers and cant get any sound out fo them
I have logitech 530 speakers, can only get 2 speakers and sub to work. Just installed new sound card. When I run a test on all speakers they work, till i try to listen to music, then only 3 work
Mar 09, 2009 | Logitech X-530 Computer Speakers
Logitch 530 speakers quit
If you right click the volume control on your desktop.
Do you have something called
Playback devices?
If you do, select "advanced."
change the drop down to how many speakers you have.
Apply it and restart your computer.
Feb 06, 2009 | Logitech X-530 Computer Speakers
One speaker is musch louder X-530
On the TV sound options see if there is a balance option. Adjust according to taste if there is that option. Hope this helps.
Dec 24, 2008 | Logitech X-530 Computer Speakers
Logitech x-530 speakers connected to Highlander DVD recorder
YOu need to install the right drivers, for your sound and video card, latest. and Direct X9c.
Jan 13, 2008 | Logitech X-530 Computer Speakers
Connecting Logitech X-530 speakers to TV flatscreen.
It really depends on what the Tv is capable of, and how you want to strategize the connection, but yes, it can be done.
According to the X-530 User Manual , the speaker system comes with an included video game adapter, for hookup with a console. if your LCD TV has stereo RCA output jacks, you could hook up your speakers to it in that fashion. If not, you may have to buy an adapter that converts whatever you have to RCA.
Another way you could attempt to connect it, is to buy a stereo RCA-to-3.5mm (g9) adapter, and connect to your computer's line in (if it's stereo). Your computer would be doing all the speaker sound positioning, and would have to be left on while you're watching TV, but that would work, as well.
Jan 01, 2008 | Logitech X-530 Computer Speakers
Speakers not working correctly
pls swap the spk pin in to your sound card jack socket . bye
Sep 22, 2007 | Logitech X-530 Computer Speakers
Connecting dvd player to logitech x-530
Well, if you have a DVD-ROM, all you need is a video card with a s-video out to connect to your TV and then you could put your DVD player in your room and play your DVD's from your PC. Another way to do it (without having to buy anything) is to connect the sound of your DVD player to a stereo receiver and then plug the sub into the headphone jacks and the speakers to the sub.
Mar 19, 2007 | Logitech X-530 5.1 Channel Speaker System...
Logitech X-530 Computer Speakers Logo
206 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
