Question about Maytag Kitchen Ranges
I push bake 350 let say .it shows 350 then goes to 100 and it stays there and does'nt heat.the electronic box is ok its new.all this trouble comes after automatic cleaning of the oven.i did everything possible according to user,s manuel trouble shooting section.When it goes to 100 i hear a little click then few second after and other click and thats it thats all nothing hapen after that Thank you for your help Fern
  • 67 Answers
You need a new ignitor
Posted on Sep 29, 2009
Have a lg oven lre30453st that the oven doent work the displa shows F7 clear the clock and unpluged it for 5min and still doesnt work.push the bake button it showed 375 thena second later went to...
Be sure you have 230 volts across the red and black wires at the terminal block the power cord attaches to. I suspect you have only one line to the range.
It is simpler to check a portion of the range first. Go to the relay board for the bake and broil elements. Check for incoming voltage between the red and black wires. You should have 230 volts all the time.
Set the oven control to bake at 350 degrees and check between the yellow and black wires that go to the bake element. You should have 230 volts. If you have 0 volts, check between the yellow wire that goes to the bake element and the black wire that goes to the terminal block of the range. If you have 230 volts here, the DLB relay on the relay board is bad. This will prevent bake and broil from working.
We can go through the relay board for the cooktop. I think it is best to eliminate one problem at a time.
Oct 16, 2011 | LG LRE30453ST (Electric) Stainless Steel...
I have an XL44 GE Spectra Oven/range. The cleaning feature no longer works and recently we have experienced the oven not getting to the desired temp for both Bake and Convection Bake. We set it to 350 and...
Page 22
Of the service manual shows your diagram. The oven sensor should read 1100 ohms @room temp (75f) All these new fangled electronically controlled ovens use a sensor. The negative temp coefficient sensor relays back changes in resistance whenever the temp changes inside the oven. If that sensor is not correct, open, or shorted to frame then the control will not function properly.
More here
Aug 23, 2011 | Ovens
I turn the oven to 350 degrees and it never gets hot.
First, I guess we need to define hot. If you mean hot enough to bake whatever it is you wanted to bake, then it's possible, if this is a unit that has a "timed bake" feature, that someone neglected to put the control back in manual mode, after having used the "timed bake". If this happened, then the oven will only heat to 160 - 180 degrees, and will maintain that temp. It's called a keep warm setting, which is designed to keep the food that was recently baked, warm, until someone can come get it out and served. Check this feature if you have it and see if it's in manual mode, if not change it and the oven should heat up to 350 and beyond.
If there is NO "timed bake" feature, and there's some heat, just not enough to get to a bake mode, then it's possible that the oven's ceramic glo igniter is cracked and not heating to the point that it allows the oven's safety gas valve to open for gas flow to the burner. If there's no heat at all, the problem could still be the igniter, but it could also be electronic control box feeding the igniter. These things must be checked by a tech with an ohmmeter, and possibly replaced.
Mar 24, 2011 | Ovens
The bake button is not going on how do i fix it
The bottom element is bad...and not working...
Check out this tip that I wrote about this problem...
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 03, 2010 | Magic Chef CGR3742 Gas Kitchen Range
Ge wall oven will not heat up on bake,boil or clean cycle
GE JKP86BF3BB COMBO MICRO/ELECT OVEN
NO HEAT ON BROIL OR BAKE ELEMENTS
CKD WIRING FROM PANEL OK
CKD TERMINALS AT ELEMENT HAVE 120V ON EACH ELMT
FAN COMES ON
THE ON INDICATOR SHOWS WHEN TMP &START PUSHED
MICROWAVE WORKS FINE
I ORDERED A NEW BAKE ELEMENT TO TRY-NOT HERE YET
STUMPED
Mar 16, 2009 | GE JTP15 Electric Single Oven
Top and bottom oven doesn't warm up.
we had a repairman come and he opened the electronic control panel and hit the "reset" on it and it worked after that. hope this helps. these ovens stink.
Jan 03, 2009 | Thermador C302U Electric Double Oven
Whirlpool Electric Oven RBS305 overheats while baking, locks door
The technical manual for your range doesn't show an error code of E2 F2 but all of the F2 codes pertain to the touchpad of the range.
Can you clear the E2 F3 by pressing the cancel button? If not, shut off the power to the range for a few minutes and see if the error code goes away. If the error code remains You should unplug the range from the wall and remove the back panel for the control area. Disconnect the ribbon between the touchpad and the electronic control, clean the end of it and reconnect it.
If this doesn't repair the problem you will need to replace the touchpad on the range. The parts diagram lists two touchpads, they are part numbers 8273575- bisque, and 8272702- white.
Good luck
Dec 18, 2008 | Kitchen Ranges
GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
Mar 29, 2008 | GE Profile JTP56 Electric Double Oven
Jenn-Air w156 Single Wall Oven Problem
Most likely its the EOC (electronic oven control), it needs to be replaced. If you self cleaned the oven a lot the very high heat generated fatigues computers in modern ovens.
Sep 28, 2007 | Jenn-Air JJW7530DDS Electric Single Oven
Kitchen Ranges Logo
189 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
