Question about Alesis Sr 16 Stereo Drum Machine
Ihave an Alesis D4 drum sampler.I have not used in several years I have hooked it up now an everything lites up but I cant get any sound out of it. with triggers or pads?
  • Alesis Master
  • 5,603 Answers
Some of the Alesis products have a setup and data memory backed up by a battery. It is POSSIBLE that your battery expired and took the sound memory with it.
Investigate if you have a battery in yours (buried in the guts) and check the voltage. It should be above about 3 volts.
If it is below that, replace the battery and find another unit to clone the data from.
Posted on Sep 24, 2009
No sound from bass drum
MAKE SURE YOU DIDNT TURN OFF THE TINY SWITCH IN THE BACK OF THE MODUELE
Jan 04, 2013 | Alesis DM6 Electronic Drum Set
Only distortion..
Check your power adapter. This unit REQUIRES a 9 volt AC adapter, NOT a DC one... It MAY appear to operate on DC BUT it can't generate the +/- voltages internally for sound generation with a DC adapter. This is a common problem as people try to run these on a DC adapter.
Here is a link:
http://cgi.ebay.com/AC-POWER-ADAPTER-Alesis-HR16-SR16-D4-DM5-/380178938839
Apr 10, 2011 | Alesis Sr 16 Stereo Drum Machine
I have a Alesis DM10 pro kit and both the 8" drums
They show the make up of this on You Tube...search for DM10 there.
Feb 08, 2011 | Alesis DMPad 8" Dual-Zone Drum Pad
Have the alesis dm6 there is no out put sound. monitor appears to be working. hooked to small amp or headphones. just fuzz. please help. little guys christmas present!!!
Two things:
Check that cables are seated, especially the one at the main module.
Second, look for a setting for "Local Control" in your user's manual; That setting should be "On" to accept the triggers from the pads.
Dec 25, 2010 | Alesis DM6 Electronic Drum Set
My Alesis D4 Drum Module shows squares in the Display screen and both the both the Store and Note Chase light come on and stay on. I have tried both a new power supply and pushing both the Voice and Output...
Open the unit and see if it has a battery that holds the settings. Check the voltage... it should be around 3 volts. If less than 2.5 volts replace it.
Verify the INTERNAL regulated power supply as the external you verified with new unit. The external is likely regulated within the D4 and either due to an overload or bad regulator may be below the voltage to run the processor. It is likely 5 volts and anything over 4.85 would be acceptable.
Jul 27, 2010 | Alesis Sr 16 Stereo Drum Machine
Alesis sr16: How do you hook it up??
Come from the main outputs, probably labeled L/mono and R and connect those to your mixer for your audio system on either stereo mix input OR two two inputs that are panned opposite.. DO NOT connect this to a consumer type stereo system as you may blow the speakers or amp. Consumer stuff just isn't able to take output from music equipment such as this UNLESS the volume is kept very low.
May 23, 2010 | Alesis Sr 16 Stereo Drum Machine
Sampling into yamaha dtxpress iv
If you have a sampler, you could midi out of the DTX brain into the midi in of the sampler to trigger the sounds. If not ,try downloading KORE2 from Native Instruments onto your computer and triggering it using the above mentioned method . Midi out from your brain to Midi in on your computer. Hope this helps.
Jan 13, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
My alesis d4 readout looks like it is in some other language I replaced the batt but did'nt help the screen will then black out..
try resetting the system.the directions are in the manual.if you don't have the manual contact alesis customer service.
Dec 27, 2009 | Alesis Sr 16 Stereo Drum Machine
Can i hook the alesis drum machine up to my computer and use it to make beats?
Are you talking about recording the beats from the Alesis or are you talking about designing beats on your computer to load into the Alesis? If it's the latter, try this link:http://www.squest.com/Windows/Instruments/AlesisSR-16/index.html This link might also be useful:http://www.synthzone.com/alesis.htm Please let me know how you make out.
Nov 25, 2009 | Alesis Sr 16 Stereo Drum Machine
Alesis Sr 16 Stereo Drum Machine Logo
477 people viewed this question
Top Alesis Music Experts
drivealot
Lawrence Oravetz
Robert Graf
Are you an Alesis Music Expert? Answer questions, earn points and help others
