Question about Kenwood eXcelon KDC-X879 CD Player
Kenwood kdc-x869 The face flip out for about a second with no lights, then its closes and know the only way the the unit will open is if I disconncet the plug for the back and plug it back up.
  • s_penns10 Jan 28, 2008
    Have the same problem. I was looking for the schematics to possibly repair the stereo myself.
    Problem Solver:
  • 11 Answers
Alot, of the radios have a common problem with the connection from the radio's detachable face. What happens is corrosion builds up on the connectors between the pin and the connector itself. Sometimes you can clean it off with a small file. Also, some KENWOODS with the motorized face are known to have a problem with the ribbon cable connecting the face plate to the main board. The last time I repaired one I called KENWOOD and aquired the cable for about 65 dollars, what the problem is, is the cable is wrapped around a plastic white spindel with a high tension spring and places alot of pressure on the cable from the wear and tear of the face opening and it will cause strange problems such as: turning on and off, some buttons working while others don't, and the display partially turning on and off.
Posted on Dec 16, 2007
I am having a similar problem...the unit will flip open and then close...I am unsure what I can do to resolve this issue....is there something I should look for if it is the ribbon cable?
Thank you very much
Posted on Sep 18, 2008
I have a kenwood excelon kdc-x869.the gears striped on the faceplate when my knee hit the faceplate.installed new gears but cant get switch in right position to operate right.
The gear which moves the lever that opens and closes the face position sensor switch needs to be installed correctly. The best way is to have face horizontal and try to position the gear so the lever closes the switch.
Jul 07, 2011 | Car Audio & Video
It lights up but doesn't come on completely
Try checking two different items.
  • First, using a multimeter or test light ensure that there is correct voltage going to each of the sources and you have a good solid grounding source.
  • Second is trying a reset to the unit.
Nov 11, 2010 | Kenwood eXcelon KDC-X869 CD Player
Unit only has power for a few seconds
could be a couple of things..1. issue with your ground connection 2. ventilation
May 29, 2009 | Kenwood eXcelon KDC-X879 CD Player
Kdc-x869
Hi Homer, sorry mate, unless you have a remote control, thatas the only way I know of to do it.I assume that you have read this.
Other way is to ask your friends if they have the same, or go to a car audio installer in your area, and check to see if they can help you out. I used to do this for people. And not charge them. You don't by chance live in Brisbane do you?
regards
robotek
Sep 16, 2008 | Kenwood eXcelon KDC-X869 CD Player
Kenwood kdc-mp 825
it's a Canadian Kenwood.
http://inform3.kenwoodusa.com/manuals/KDC-MPV8025.pdf
I had the 925 purchased from Ebay, but I sold the car with it.
it's probably the ribbon wire broken between the face and the unit. I know that on Ebay some they use to offer a repair for these type of units.
Sep 06, 2008 | Kenwood KDC-MP828 CD Player
KDC-X869 Face Flips Halfway, Unit Turns Off
I have worked on many of these radios and there is a lever that contacts switch to determine position of face this lever wears out and switch does not operate properly causing radio to lose its mind. This is usually the cause of this failure unless flip gears have been damged somehow. contact kstahl65@att.net for additional info
Jan 21, 2008 | Kenwood eXcelon KDC-X879 CD Player
IHooking up mp3 player
Either buy the adapter from Kenwood and follow the instructions with that. Or go buy a headphone jack to RCA Audio cable and connect the RCA to the AUX RCAs on the back of your deck.
Dec 16, 2007 | Kenwood eXcelon KDC-X869 CD Player
Will power up,will hide, will open on igntion start
yup.. needs a new face plate ribbon cable.. just like mine :-(
Sep 24, 2007 | Kenwood KDC-716S CD Player
Kenwood x969 not working
hi,this unit sounds like one with a motorised face. the problem could be with the flat ribbon cable connection between face and main pc board. chech for cracks alond the body of the ribbon especially where it bends alot. Also try resetting the unit if the unit has a reset switch or reset function.
Aug 03, 2007 | Kenwood eXcelon KDC-X969 CD Player
Kenwood KDC 7024
Some flip face stereos use a tiny micro switch to tell the onboard computer when the face is down or up and sometimes it uses the same switch for both positions sensing. It could be this switch is not working properly (dirty contacts, broken, bad wire, mis-aligned, etc.) and that is causing the problem. Good luck.
Feb 12, 2007 | Kenwood KDC-7024 CD Player
Kenwood eXcelon KDC-X879 CD Player Logo
412 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
