Question about Dryers
Have to run dryer 2 3 times to dry clothing clecked the heating element and didnt find and brakes in the coil cleaned the dryer very well when i put it back together it gets warm but not hot to dry the items
    President:
  • 1,776 Answers
Check the high limit thermostat. This small round device is mounted on a metal plate and is typically attached to the internal ductwork. I would check this and the thermal fuse. I will attach a photo for reference. It shows a fuse and thermostat. When one is replaced, it is recommended that the other be replaced as well and may come as a set from a parts supplier. Sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 23, 2009
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
Have duet electric dryer model #9200Lw1 dries slowly
are you overloading the dryer, too many clothes would take longer to dry
Feb 03, 2018 | Whirlpool Dryers
Dryer won't heat up to dry the clothes the heating element works
Check the following to address this issue--
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 03, 2009 | Kenmore Dryers
Not heating properly, many cycles to dry loads
1. Venting
2. Thermostat
3. Heating element
Jun 02, 2009 | Maytag SDG3606A Gas Dryer
Heating but taking a long time for clothes to dry
most of the time if it takes to long to dry it is your wall vent hole or dryer vent hole that has gotten clogged,clean both and you should be ok,let me know how you do.-mike
Mar 18, 2009 | Kenmore Dryers
Gas dryer runs, cleaned hose, get warm does not heat up to dry
with a gas dryer in which your assured te hventing is free and clear of any obstructions, i would look to replace the coil pack located atop the gas valve itself, probably about $25 part number 279834... 2 coils simply mount atop the valvle
Feb 11, 2009 | Whirlpool Dryers
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Dryer not drying
Check your lint filter. Put it under running water to see if the water goes through it. Chances are it is clogged up. Wash it and put it back. Should do the trick.
SGt 48
Jun 18, 2008 | Roper Dryers
Dryer will not dry cloths
make sure that the dryer has the proper voltage going to it and if it does then check the heating element and the safety on the left top of the element housing
Apr 18, 2008 | Whirlpool LGR7646E Dryer
Clothes not getting dry
umplug your vent and run dryer see if that will make a different when dryer your clothe if not may be gas coils
Mar 30, 2008 | Dryers
Dryers Logo
41 people viewed this question
Top Dryers Experts
