Question about Maytag PYE2300AY Electric Dryer
Where is the thermal fuse located on pye2300ay dryer
  • 304 Answers
Unplug the cord of the dryer before starting.
Raise top by placing a putty knife between top and front in the seam between the two about 2 inches in from each edge and lifting up at the same time. Raise top to full open position.
Heater is located in the left rear corner behind the tub. High Limit thermostat sits atop the heater and thermal fuse is located toward the right side of the can containing the heater.
Kit number LA-1053 contains several thermostats and fuse. replace all parts in the kit.
Posted on Sep 24, 2009
Testimonial: "thanks for the information my friend."
appldoctom
  • 311 Answers
SOURCE: location of thermal fuse on whirlpool estate gas dryer
if this is a gas dryer and the ignitor is working the thermal fuse is fine.need more info .dose the valve coils make any clicking noisecheck with ohm meter to see if coils open/also is gas on
Posted on Dec 31, 2008
SOURCE: thermal fuse location
where located fuse
Posted on Sep 17, 2008
TheMobilian
  • 8220 Answers
SOURCE: location of the thermal fuse on the kenmore gas dryer 80
Posted on Feb 04, 2009
  • 686 Answers
SOURCE: Thermal fuse in Maytag PYE2300AYW not plugged in
NO. YOU ARE OK YOUR DRYER SHOULD ONLY HAVE A HIGH-LIMIT AND A CYCLING THERMOSTAT. YOU CAN LOOK AT YOUR DRYER PARTS AT www.repairclinic.com ENTER MODEL NUMBER SCROLL DOWN ALL THE WAY CLICK THE RED 100 AND SEE ALL.
Posted on Apr 13, 2009
  • 1122 Answers
SOURCE: location of thermal fuse on leq9858 l dryer whirlpool
if this is a top load?if so remove the back panel and you will see the dryer heater box to your right,the fuse is on the left side of box top,the high temp thermostat is on the bootm left and should be replaced also,before you do thatmif you have a meter remove the 2 wires from the heating element and check it on omns,no meter?remove the 2 screws pull the element off and look to see if the coil is broke anywhere,let me know how you do-mkie
Posted on Apr 20, 2009
Dryer stopped running altogether while drying an oversized load of beach towels. Problem is not in the power supply outlet or circuit breaker or the dryer door switch. From another website I learned that...
Go to www.repairclinic.com and enter PYE2300AY. With luck, you will be presented with a list of common repair parts and may be able to view a generic Maytag video showing disassembly and repair.
May 18, 2017 | Maytag PYE2300AY Electric Dryer
Dryer does not work at all on any setting.
The thermal fuse might be blown (just fixed my PYE2300AYW last week - I assume they're similar enough). Easy to check - pull the wires off the terminals of the thermal fuse, put an ohmmeter across the terminals. If no continuity, it's blown and needs to be replaced.
Also replace the high-limit thermostat at the same time, since it wasn't apparently doing it's job (for mine, the 2 came together in a kit, about $20 - fairly standard, so yours very likely uses the same, but you should check it).
You should be able to find a picture showing where the thermal fuse is and what it looks like by googling "PYE2300AY thermal fuse".
And, while you have it open, clean any and all lint out from around/ over/under the hearing coils - that may have contributed to the overheating.
If you DO still have continuity across the thermal fuse, then it's something else, but from what I've read, that's likely the culprit.
Jun 28, 2010 | Maytag PYE2300AY Electric Dryer
Location of Thermal Fuse
The thermal fuse is located near the heating element. The part number for the replacement kit is LA-1053. You can view an illustrated parts break down of your dryer at searspartsdirect.com. Just type in your model number and locate item 5 under the "Heater" section. Pay close attention to the instructions in the thermal fuse replacment kit. One thermostat is for a GAS dryer, one is for an ELECTRIC dryer. Read the instructions and make sure you use the correct one. If you have any questions, please let me know. I hope this helps you.
Jan 06, 2010 | Maytag PYE2300AY Electric Dryer
Where is the thermal fuse located on the Performa dryer model PDET910AYW?
Hi. The fuse is mounted directly on the heater element, in between the heater duct, and duct exhaust.
Click here to view a picture of the fuse.
Dec 20, 2009 | Maytag PYE2300AY Electric Dryer
Thermal Fuse PYE3200AYW Maytag Elec Dryer
BEHIND THE UNIT U WILL SEE A VENT U CANT MISSE IT
Aug 19, 2009 | Maytag PYE2300AY Electric Dryer
Where is the thermal fuse located?
In the back of the dryer. Look for the coiled heaters and follow the lead wires back to the fuse.
Apr 30, 2009 | Maytag PYE2300AY Electric Dryer
Dryer Does Not Start
thermal fuse located on side of heating element
Jan 30, 2009 | Maytag PYE2300AY Electric Dryer
Where in Thermal fuse located maytag model #PYE2300AYW
Take the top off the dryer and you should find it located at or near the drum.
Jan 17, 2009 | Maytag PYE2300AY Electric Dryer
Electric dryer
You can get to the thermal fuse by taking the top of the dryer off. It only has about 4-6 screws. You should see the thermal fuse located at or near the drum. Trying bypassing the fuse first. If it starts, there is your problem. Go get one for about 10 dollars.
Nov 05, 2008 | Maytag PYE2300AY Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
340 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
