Question about Craftsman 20 Hp 42" Deck Lawn Tractor
Engine won't gain speed and keep running behaves as though it might not be getting enough fuel ran fine for an hour, and then quit have checked spark plugs, fuel flow to the carborator seems fine tried started fluid, and it now starts, but won't gain any rpm...
  • 472 Answers
Still can be the the carb it could be pluged up what moter do you have
Posted on Oct 15, 2009
2002 v star 1100 wont rev over 3000 rpms sputters and runs like is not getting fuel
Could be that's exactly the problem. I'd check the fuel filter first, cars with fuel filter problems often only exhibit problems like this by saying they can only go Xmph, and not over. While the filter may not be clogged enough to keep the car from running, a 13 year old car can through condensation develop rust in the tank, which could not only foul the filter, but foul it continuously after replacement. I once solved the problem with my motorhome by introducing a huge cannister filter, with a magnet to trap the rust, and a smaller fine filter just before the carburetor so I could tell the gas was flowing and the big cannister needed replacing if the flow diminished.
Other problems that may cause the same issue are timing problems, though most of those have gone the way of old spark gaps, and timing belts that need adjustment. But, if your car's timing works like the older cars, having the timing retarded or advanced could change the cycle just enough that it doesn't want to run right, the fuel just doesn't get enough time to burn completely, or begins to foul the plugs.
Another more modern problem is the coil, while capable of producing enough spark at low speeds, low rpm and therefore low gasoline consumption, boost the rpm, the speed, and push down on the gas and suddenly there's not enough juice to burn all of the gas, and the car coughs, sputters and behaves like it has no power.
Hope this helps!
Sep 03, 2015 | Cars & Trucks
I have a 93 K3500 with a 454. Truck was running fine, started no problem, ran great. Driving the other day, turn the corner and the engine quit. Cranked the engine, fired up for 2-3 seconds then quit, ...
Before starting the engine, the fuel pump should only run for a few seconds when the key is first turned, to pressurize the fuel system. Even though the pump appears to be running, you may either have not enough or too much pressure for the engine to keep running (fuel pump or pressure regulator). I think it may just be a coincidence the engine quit while turning a corner, but the gas in your tank may have been so low it sloshed away from what is likely a very old pump, starving it and causing it to failure.
Jul 03, 2017 | 1993 Chevrolet C1500
Toro snowthrower model # HSK 635 won't restart, stated first time, ran about ten minutes, then died, put brand new spark plug in, getting good spark, just won't fire up, even when I tried a li
check and make sure its getting fuel. when trying to start, spray some engine starting fluid in spark plug hole. just a little bit. replace the plug then try to start it. if it starts then quits then its a fuel problem. fuel not reaching engine. good-day !
Jan 30, 2012 | Garden
Hi, I have a Craftsman Eager-1 5.3 3-in-0ne solid state enigine lawn mower..got it used but in almost new condition. worked great cutting 1 1/2 ft of very wet grass for a few hours (couldn't get to it...
Drain the fuel or when you remove the float bowl bolt (also the main jet), then hold up on the float to keep the needle on the seat so gas won't go everywhere. When you have that brass bowl bolt off, clean it! Use nothing metal on it. Pay close attention to the small hole in the bottom and along the smooth unthreaded part at the other end. Use carb/choke cleaner to blast gum and dirt out of those very small fuel orifices. I recommend installing an inline fuel filter also. A shut off valve is recommended too, that way if the needle in the carb sticks open, the crankcase won't be polluted with gas. Usual symptoms on a clogged lawn mower main jet though, are after pushing primer bulb, engine runs about 3 seconds. Try the brass bolt cleaning and post back if needed.
Jun 14, 2011 | Garden
Shadow Aero Stalling Out While Riding
make sure your carb float level heights are good. make sure fuel pump is working properly. could be a fuel or temperature problem. slim chance it could be valves.
Dec 30, 2009 | Honda VT 750 Shadow Aero Motorcycles
96 tacoma, ran fine, parked it and now it won,t start. Has fuel, new fuel filter, new battery, acts like it wants to but will not completely fire up. HMMMM.
are you sure you getting fuel even though you have new fuel filter, check all fuses under the dash to fuel pump and relay under the hood, are you getting sparks? check rotor, cap, coil...make sure you getting 2 important items, gas and fuel to the engine. hope that help some
Jul 12, 2009 | 2001 Toyota Tacoma
Horrible Idle, Then Engine stalls
Sounds like the copper seal that the old owner put in quit working.
a lemon is still a lemon no matter how sour.
Jul 07, 2009 | 1988 Ford Crown Victoria
Engine quit while driving
You will need to check every ground wire! Remove and clean each one. There are so many, too many to list! Frankster016
Oct 25, 2008 | 2005 Ford Ranger
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
74 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
