Question about Sanyo Katana Eclipse X Cell Phone
Just got a new katana and it shuts down after about 20 seconds. what gives
I have pushed every button to turn it off and nothing happens. It is frozen
Depending on why your tablet is frozen, pressing the "Power" button -- sometimes called the "Sleep/Wake" button -- might turn it off. Some tablets give you the option to restart or shut down; if you have this choice, pick the option to shut down the tablet completely. If pressing the button once doesn't do the trick, hold it down for 15 to 20 seconds -- this often forces the tablet into shut-down mode.
Aug 23, 2015 | Tablets & eReaders
3-3 error code mitsubishi 1080p
GIVE MITSUBISHI TECH SUPPORT A QUICK CALL
Nov 09, 2013 | Mitsubishi WD-65731 65" HDTV
2000 suzuki katana 750 runs for 20 mins then stall
Does this motorcycle have a radiator if so, make sure it's full if it is go online and see if there's a sensor that shuts the bike down when it gets too hot. Maybe there's something wrong with that
Sep 11, 2012 | Suzuki GSX 750 F (Katana Motorcycles
Computer shouts down in 15 to 20 seconds after starting
The specs say the PSU is ATX compatible. Whether that is for the connector only or for the whole power supply is something you will have to determine.
If you have an ATX power supply handy (like in an old computer) give it a try. This one is only 300 Watts so it won't likely be expensive to replace.
Have a look at: http://www.techspot.com/community/topics/dell-dimension-1100-shuts-down-after-20-seconds.135987/
Aug 28, 2012 | Dell POWER SUPPLY Power Supply
Is my 2000 Suzuki Katana 600 ok if the oil ran dry on me?
there is a reason the oil light is red, it means stop now!!! my guess is the engine is very badly damaged, only a teardown will tell you how bad
May 20, 2010 | 2000 Suzuki GSX 600 F (Katana)
Runs for about 20 seconds then shuts off
In all likelihood the mangnetron has failed, or perhaps even the Power Supply. or a fault that is shutting the system down for safety reasons You need to have it serviced by a reputable service centre/man.
Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Jan 25, 2010 | Panasonic NN-H664 Microwave Oven
Kohler lp shuts down
What you need to know is there enough fuel going to the regulator. It should be 7 to 11 inches Water Column. If not your problem may be not enough fuel. That includes when the heater in your house kicks on and what ever gas appliance you may have. Once you verify that you need to figure out if you have the proper pressure coming out of the regular on the inside of the generator. Next I would look at compression of the cylinders. It may need new piston rings.
Dec 13, 2008 | Kohler 12 kW Emergency Power System -...
Projection TV keeps shutting down
Good Day;
Sounds like you have a bad green picture tube that has failed. To check this out; remove front speaker grill, remove small panel, you will see three CRT's (pictue tubes) sticking down, remove the little board on the middle tube then restore power. If TV stays on more then likely the CRT is bad but not always the driver on board could also be bad, check voltages.
Good Luck, big IRISH.
Sep 05, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Sanyo Katana
This is phone's software problem. It comes when u pulled out battery in on phone's position. You can give it to repair to any skilled technician or to company customer support. They will put it right. This is not a big problem. If u found this a step towards solving your problem, do vote here.
Dec 30, 2007 | Sanyo Katana SCP-6600 Cellular Phone
Sanyo Katana Eclipse X Cell Phone Logo
Top Sanyo Cell Phones Experts
Jeffrey Thomas
Jeffrey Thomas
Level 1 Expert
270rexton
270rexton
Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
