Question about Whirlpool AWG320 Front Load Washer / Dryer
Nothing happening on my whirlpool awg320/2
My washing machine just does nothing, i pull the control knob outb and the power light comes on but for some reason it then wont start a cycle? according to my wife for the last couple of weeks the washer would occasionally not rinse fully. I have removed a fair bit of debri from the filter, could this of caused the present fault?
  • nicholasno8 Mar 04, 2009
    Same as above - pull the dial out but does not start - any ideas
Hi there could you possibly help me with the instruction manual for this washer i just need to know how to work it i have no instructions please email me on i would be most grateful
Posted on Jan 13, 2008
I have a frigidaire gallery front load washer that won't start a regular wash cycle.When i select a regular cycle and pull up the start knob,the cycle light comes on and nothing happens.When i mov
Good Afternoon Leszek - Thank you for your question. Based on the symptoms you are describing it sounds like the unit has a faulty timer or a potential wiring failure. Try reprogramming the unit by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn on the unit. If issue persists, then at this point I strongly suggest reaching out to a professional that can accurately diagnose and repair the washer.
Jun 09, 2013 | Frigidaire Washing Machines
Water not coming inside the washing machine
Water not coming inside solutions:
1. Make sure the inlet has water or the faucet going into the washing machine inlet has free flowing water.
2. Did you turn on the machine on?. This is required specially for heavy duty 10kg Whirlpool industrial grade washing machines..
3. If the two above didnt work. Try rotating the knob to NORMAL and pull it.
4. Contact the nearest Whirlpool service center for repair if problem persists.
Hope this helps
Dec 13, 2010 | Whirlpool Washing Machines
Maytag Performa will not come on. Nothing happens
Burned Thermal Cut Off thermostat. at the bootom of heater housing, which means you have clogged vent as the root of your problem, probably it was taking long time to dry prior to your experiencing dryer not running.
Oct 31, 2009 | Washing Machines
Washing machine stops after final rinse cycle
Your lid switch is bad. It must be replaced.
Jun 26, 2009 | Whirlpool Washing Machines
Knob Comes Off
These knobs are made of plastic and usually have a metal insert inside them. The plastic is the problem. Over time with use these knobs will crack inside near the metal insert. That's how they become so loose. This is an easy fix though. Call your nearest appliance repair service center and give them your model and serial numbers and tell them the part you need. You can usually locate the numbers you need under the lid of the machine. hope this helps you out. Good luck.
May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
The machine is not turning on but the power lead is fine.
This is timer control failuer. you will need to replace the timer on this unit in order to restore proper function.
May 23, 2009 | Whirlpool LSR5132PQ Top Load Washer
Washing Machines Logo
292 people viewed this question
Dan Webster
Dan Webster
Sal De
