Question about Maytag Neptune MAH5500B Front Load Washer
Door on my neptune washer is locked and it will not open
  • 220 Answers
Remove the dispenser lid and trim,four screws one in each corner,reach under toward the front,you will find a neon green cord(looks a lot like weed eater line)Pull it to the left that will open the door and get your clothes out,but either it didn't drain for some reason or the latch or control board has gone bad.
Posted on Sep 23, 2009
Front-end door is locked. Can't open it.
Yes there is a plastic lead inside front of soap powder dispenser. Sometimes you have to remove screws from dispenser to gain access to it. JUST PULL IT & THE DOOR WILL OPEN.
Dec 19, 2013 | Maytag Neptune MAH6700A Front Load Washer
My machine is showing the code FL machine has problems locking. How do I resolve this problem
Your Maytag Neptune Washing Machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
Door lock monitor switch in door lock mechanism unable to communicate to control board the door is locked.
1.Check wire connections in harness leading from machine control board to door lock mechanism.2.Check solenoid and door lock enable switch in door lock mechanism.
3.Replace responsible component.
Dec 07, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My Maytag Neptune Washer has an error code "do" What does this mean?
The washer detects that the door is open when
starting a cycle or the door is not locking.
Close the door tightly and restart the cycle.
Nov 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune door lock stuck!!!
Try these steps:
1.) Take the washer outside. 2.) Loosen the two screws on the back panel and remove the back panel. The pump sits on the left-side of the opening. There's a black water hose with a metal clamp; 3.) squeeze the metal clamp with your fingers until it's loose enough to slide away from the pump. 4.) Separate the hose from pump and the trapped water will pour out and the door will then open; and 5.) clear any blockage from the drain hose and the pump.
Jul 01, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Maytag Neptune Washer Door Locked
INSIDE THE SOAP LOADER THERE IS A LIME COLOR STRING PULL IT WILL UNLOCK LATCH
Apr 18, 2008 | Maytag Neptune MAH5500B Front Load Washer
No Locked Light
does the washer actually go into high speed spin? if not the wax motor in the door lock may be no good. that would prevent the door from locking and the indicator on the display would not light.
Aug 03, 2007 | Maytag Neptune Washer
Maytag Neptune MAH5500B Front Load Washer Logo
151 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
