Question about Dryers
My breaker keeps tripping when my dryer is on. The dryer keeps running but is no longer hot. I turn my breaker switch off and on again and then my dryer works running hot for a while, but not for too long. Should I change out my circuit?
    President:
  • 1,776 Answers
First I would check the venting for the dryer. A dryer that is tripping breakers can often indicate a venting problem. Make sure the vent is open and clear all the way to where it exhausts outside. Make sure that the vent hose/pipe isn't collapsed anywhere. I would check this first before considering other possible causes. Sorry for your trouble and I hope this helped. Check the venting and let me know if you require further assistance. Best wishes.
Posted on Sep 23, 2009
Keeps tripping the breaker after running for about 10 minutes or longer. I have tried running it on air only and it does not trip the breaker.
Obviously your heating element is drawing too much current for some reason. I recommend you stop trying to run it with the heater.
Mar 05, 2015 | Samsung DV218AEW Electric Dryer
Dryer 220 Breaker Repeatedly Tripping
Check all your wires again make sure you have a solid connection also your dryer plug has to fit really good in to the outlet not loose
Don't forget always turn off your power before work
Apr 01, 2014 | Electrical Supplies
My beko dryer keeps tripping my electric box
We had similar problem with a different type dryer. Turned out to be a weak / older / bad breaker in the electrical panel. Every so often it would just trip the breaker for no reason.
The owner thought it was the dryer itself - and bought a new one - but problem remained.
In our case - solved by electrician putting in a new breaker in the panel for the dryer.
Could still be your dryer though, in your case.
Suggest:
- make sure dryer vent is not plugged by lint or other stuff.
[ When running, check that you've got good flow of hot air coming out the outside vent. If NO, could be a plugged up vent. We've had that too before. Disassemble, clear out vent tubes, check for plugged up screens, on the outside too, there is sometimes a screen in the outlet - it could get plugged. The screen is important - to keep out leaves & animals & stuff - but typically gets plugged up. Then dryer overheats and shuts itself off or trips the breaker. Also - you'll find that it takes longer to dry anything if the flow of air going out is restricted.]
Oct 25, 2013 | Dryers
Neptune dryer has power but will not spin.I hear a faint click comming from the left side. model#MDE9700AYM
An electric Neptune clothes dryer, like most electric clothes dryers, has two circuit breakers: one for the drum and another for the heating element. Both breakers need to be in the "on" position for it to run properly. Go to your main circuit box. Reset both of the dryer's circuit breakers to the "on" position. If one of the breakers trips again, there's a problem with the dryer component that it operates. Contact a dryer repair technician to evaluate the machine's condition.
The lid switch is a small latch located on the interior of the door frame on your Neptune clothes dryer. It keeps the door securely shut when the dryer's on to prevent injury should you open the door and reach inside while it's turning. If the lid switch becomes damaged, the dryer won't turn on even though its lights might work. Run your finger over the lid switch and listen for a clicking sound. If you don't hear a sound when the latch is compressed, it's faulty and needs to be swapped out.
The thermal cut-off is a heat-sensitive safety feature on a Neptune clothes dryer that shuts off the heating element if the dryer overheats. After it activates, it can't be reset; you must replace it. Until it's replaced, your dryer might only partially function, so while its lights might turn on, the dryer might not spin or heat. Don't exchange an old thermal cut-off for a new one until you first determine what promoted it to trip, otherwise your dryer likely will overheat again.
Oct 19, 2012 | Dryers
Does Not Shut Off
1st go the the house breaker (dbl breaker) for the dryer and shut it off and turn it back on, your dryer runs on 220 volts of power but if the breaker is partially tripped it may be only running on 110 volts which is only enough power to turn the lights on and to turn the drum the element needs 220 volts to turn on. If it still doesn't heat after resetting the breaker then you may need a heating element or thermostat. The dryer isn't shutting off because it isn't detecting the clothes are getting dry so once you fix your heating problem the dryer should start shutting off on its own again.
Apr 21, 2012 | Roper Dryers
My dryer will run but will not get hot. The trouble shooting guide says that on of the two house fuses in the circuit may be blown or the thermal limiter is tripped. Where are the fuses in the dryer. I...
First id make sure you have both phase of AC power coming into dryer.
Go to your house panel and reset yoru house breaker for the dryer. If in the USA the breaker should be a 240volt / 30amp breaker. It will have two breakers tied together at the trip switch.
If AC power is good at the dryer outlet then it could be one of the followings.
  1. Open Thermal limit fuse or trip switch.
  2. Open Heater Element.
  3. Control board is faulty.
Oct 26, 2009 | Frigidaire GLEQ2152ES Electric Dryer
The dryer keep tripping the breaker
It sounds like the current draw is too high This would be due to overload of dryer, motor overheating binding of the drum assy.. First re level the dryer, next disconnect the power and Vacume out the lint inside around moter, try spinning the drum manually to see if it moves freely( some resistance is ok) Another possibility can be lose electrical connections on the breaker or outlet. Disconnect power before testing. Let me know if these tips helped solve issue
May 14, 2009 | Maytag PYE2300AY Electric Dryer
Sde5401ayw keeps tripping breaker
ck the element if the breaker poping as soon as you use heat dead short eather element are wire going to it
Mar 18, 2008 | Maytag SDE5401AYW Electric Dryer
Dryers Logo
144 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
