Question about Korg Pa800 Synthesizer
I have noise on ram samples
I turned on my pa800 and when i play ram samples there was some noise like cracking and distortion, that happened 2 or 3 times, now its normal, but i think it may hapen again??? where is the problem, somebody says it is on motherboard? or its just ram overheating? since i install 2.01 os i noticed that its kinda warm in right display corner, can u help me???
    New Friend:
Korg Pa800 Synthesizer i have noise on ram samples Answer i turned on my pa800 and when i play ram samples there was some noise like cracking and distortion,... (More) i turned on my pa800 and when i play ram samples there was some noise like cracking and distortion, that happened 2 or 3 times, now its normal, but i think it may hapen again??? where is the problem, somebody says it is on motherboard? or its just ram overheating? since i install 2.01 os i noticed that its kinda warm in right display corner, can u help me???
Posted on Oct 06, 2009
Hello.sure there is a problem with ram.i think the best way to protect your keyboard from this problem is to delete all samples data before you load another set.And i have one big error with my korg pa800 because when i try to import any KMP file it says not enough memory but i have 10 mb free and i can't load sample with 1 mb ??? very bad!!!
Posted on Jun 22, 2012
Hello, I have a big problem with my korg pa800.i was install os 2.02 my sample ram have been disappaired when i have os 1.01 the sample ram was working.. but when i upate the os 2.02 sample was not saving...
After updating the firmware, you likely must do a factory reset. This is probably required so the keyboard will read and decide how much ram actually exists. At this site do the "factory reset" version:
http://www.korgpa.com/pa_root/en/products/pa800_soft.html
Sep 11, 2011 | Korg Pa800 Synthesizer
Hello, My Pa800 is few years old now has always worked perfectly. I recently combined few sets of rhythms together and loaded it there seemed to be no problem, few days later i was getting glitches in all...
The splicing of rhythms to play seamlessly would be tricky. Also you need to consider if you might be exceeding the number of generators available. If you are splicing external samples, that take great care and a lot of editing. Part of the problem is syncronizing the clocks of individual samples. It is hard to avoid glitches and changing mode of clock and quantizing will expose these glitches.
Sep 07, 2011 | Korg Pa800 Synthesizer
Hello, I have a big problem with my korg pa800 , yesterday I was on gig, and suddenly the whole keyboard in the middle of playing got the distortion on every sampled or fabric tone!!! I have tried...
It will require repair. I suspect by you description that the D-A convertor has failed. This is a chip that is far beyond a DIY project to change. Do further testing to make sure the power supply voltages are correct and that headphone output sounds the same problem.
Here is your service manual: http://elektrotanya.com/korg_pa800_sm.pdf/download.html
Scroll down to "get manual" and click to download the manual. IGNORE other download links.
Aug 07, 2011 | Korg Pa800 Synthesizer
Korg PA800. Ram Upgrade
The pa800 has a fixed amount of Ram at 64mbs and it is not physically possible to upgrade the Ram. The pa2x has a removable128mbs Module and that can be upgraded via a 256mb Module from Korg.
Keith [mrniceneasy - KorgForums]
Nov 13, 2009 | Korg Pa800 Synthesizer
Recording problem on pa800
It seems as though it may just be a sample issue.I have had this similar problem before,because each drum hit corresponds to a key on the piano.It could also be the program you are using to open it.
Sep 22, 2009 | Korg Pa800 Synthesizer
PA800 Instruments making noise
you have memory problem it cost $150 to fix it
Aug 06, 2009 | Korg Pa800 Synthesizer
Korg Pa800 Synthesizer Logo
1,472 people viewed this question
Top Korg Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Korg Music Expert? Answer questions, earn points and help others
