Question about Kenmore 64802 Top Freezer Refrigerator
KENMORE TOP FREEZER WORKING BUT NOT COOLING BOTTOM FRIG
I HAVE ICE BUILD UP IN FREEZER BEHIND THE BACK PANEL
    President:
  • 744 Answers
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck & thanks for using fixya! Mike
Posted on Sep 23, 2009
Krazytech
  • 725 Answers
SOURCE: frig not cooling and now freezer is frosting
Val sounds like a defrost problem..go ahead and defrost your freezer again... check your evaporator drain your fan motors let let me know and I can help you Krazytech
Posted on Mar 30, 2008
SOURCE: Maytag side by side freezer ice build up
I HAVE A MSD2454GRW, 23.5 CU, MAYTAG AND ICE BUILDS UP ON THE FLOOR OF THE FREEZER TO A POINT WHERE IT RUNS ON THE FLOOR. CAN CLEAN IT OUT AND 12-15 HOURS LATER, ITS BACK.
Posted on Sep 15, 2008
  • 833 Answers
SOURCE: Hidden Ice build-up inside plastic bottom cover of freezer
Generally, icing is the result of too much water vapor inside the unit, blockage of the circulation channels and too much packing in of the box.  The water vapor is generally caused by: uncapped items in the fridge, opening the door too often, humid conditions, bad door seals.  There is of course, there is a possibility that the defrost cycle on the unit is not working.  About once a day, depending on the brand, you should notice that the fans and compressor don't run and you should hear a bit of creaking, sloshing or other strange noises as the ice melts.  If this is not happening, your defrost timer or the coil it heats could be bad.
Posted on Nov 12, 2008
  • 3 Answers
SOURCE: PLHS69EGSS1 Freezer not cooling properly but Frig is OK
try to check the defrost thermistor and also make sure that the unit is working with the right FULL LOAD AMPERAGE by looking this we will know if it has exact refrigerant in the system.
Posted on May 10, 2009
  • 109 Answers
SOURCE: Subzero freezer has frost/ice build up on the
Check the fan and readjust temperature control to higher. Thanks.
Posted on Oct 22, 2009
Maytag side by side msd264rheb freezer works frig isn't cold. We found ice on bottom freezer side and did melt it with a hair dryer. Frig vent is letting in, now a little cool air, but not a lot.
If you found ice in the freezer then there is usually a lot more behind the back plate. If you let it defrost completely it should work good for a couple days until the ice builds up again. you more than likely have a deefrost issue. There are usually nthree components in a typical defrost circiut. The heater, defrost thermostat and a defrost timer or control. one or those is bad.
Jul 28, 2014 | Maytag Refrigerators
Frig & freezer not cooling enough. Ice forming in back of bottom freezer.
You need to have the defrost cycle checked.( heater, limit stat, timer) If the frig can't defrost air can't move across your coils to cool properly. To temporarily get by until you can get a repairman, use a blow dryer to melt the ice build up. Once melted it will work normally for about 2 days till it freezes up again.
Nov 13, 2013 | Kenmore 73502 / 73504 / 73509 Bottom...
The freezer is working fine but the refrigerator part is warm on the coldest setting and the door has been shut for more than 8 hours.
Hi, I have seen this a lot in my 13 years in maintenance work, the most likely problem is ice build up in back of freezer behind the plastic liner.The drian tub freezes over and when the frig goes into defrost cycle the melted ice has know place to go and covers the air holes that blows into frig to keep it cool. You my have noticed water in the bottom of frig. You will have to either take freezer apart inside and remove ice and thaw out drain tube or unplug frig to thaw it out.
Mar 05, 2011 | Refrigerators
My frig is running but not cooling - frig is 50 degrees,freezer 40 degrees, cleaned the coils,etc GE side by side coils in bottom if frig side feel cool, "box" between freezer and frig side is not blowing...
I can help you diagnose the problems with your GE. Several things can cause these symptoms. All you need is a voltage meter patience and a want to, to repair and do it better than a paid technician. In most cases with the PSS26MSRSS the defrost heater is the cause for this. Look into rear of your freezer and back wall. Is Ice or frost building on rear wall? If yes unplug and prepair to remove contents in freezer compartment. Remove rear panel in freezer and use hair dryer to defrost ice until the defrost heater is visible. BRB , Sea Breeze
Jan 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
No cold air blowing into the refrigerator - temp too low
You have your own answer there - You have overfrosting and icing up behind the freezer, this will affect proper cooling - also if you have seperate freezer and refrigerator controls, it's possible the damper is not opening properly to let the cool air in. But in your case it sounds like a defrost problem. You will need to have a service person inspect your control board and defrost timer components - sometimes it's as simple as a board replacement due to a burnt resistor these things are the most common causes.
Good luck
Sep 25, 2009 | Kenmore Refrigerators
Freezer is working fine, but frig is warm,
Look for the return vent near the bottom probably behind the crisper. You'll have to remove it to see the vent. There may be an adjustable flap in to to adjust the meat keeper area. Make sure it's open.
Aug 22, 2009 | Kenmore 53642 / 53644 Side by Side...
No air coming into refrig to cool
We pulled the back panel in the freezer and found the coils frozen. We defrosted the coils and the fridge started working. We will be getting a new timer. Thanks
May 29, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Top Freezer works fine but there is no ice building up in freezer the bottom fridge not cooling properlyThings are not as cold as they should be
Remove the back panel from the freezer to verify no ice behind the freezer panel. Look inside the air vent on the freezer panel for ice buildup. Make sure the freezer control is set to minimum not coldest freezer.. Make sure the freezer fan motor is working.
May 28, 2009 | Electrolux Refrigerators
Freezer works, frig does not. Also ice build up in freezer coil
I just worked on a FF801W which is supposed to be very similar. The defrost heater in mine was of the glass tube type and located under the evaporator. There was a bimetal thermostat clipped to the top of the evaporator and a thermal fuse (sealed in a clear plastic tube) nearby. The connections were behind a little plastic cover (2 screws) in the back wall just above the evaporator.
Mine was iced up like yours and I had to defrost it with a hair dryer. All the defrosting parts in the freezer compartment turned out to work so I now suspect the defrost timer (down by the compressor). I've marked it and I'm waiting to see if it's turning.
Mar 23, 2009 | Avanti FF1101W Top Freezer Refrigerator
Kenmore 64802 Top Freezer Refrigerator Logo
103 people viewed this question
Top Kenmore Refrigerators Experts
Sal De GO PATS
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
