Question about Freezers
Freezer doesn't freeze
Yesterday I opened my freezer and found that everything had thawed out. There was a small film of ice on the back wall, about halfway down. I've now left it off for 24 hours (with the door open), and drained water from the back area near the motor. I've just briefly turned it on and the motor runs, and I feel cool air being pumped around the inside. Before I turn it on a try a full scale test, is there anything that maybe should be checked / replaced? Note that it has always been extremely noisy when the fluid is circulating through the pipes.
  • 2 more comments
  • gis_mapper Dec 15, 2007
    Note the freezer is a Fisher and Paykel N388 Vertical Freezer
  • gis_mapper Dec 16, 2007
    I've now run the freezer for a half hour, with the interior back panel off (exposing the cooling tubes). Frost is forming and so the system seems to be working again.
    Was it just a case that it needed to be defrosted, even though it is supposed to be a frost-free freezer? If so, if there some component that I could test or should replace?
    Many thanks for that. I suspected that it would be something to do with the defrost system ... having the parts manual will make it that much easier to pinpoint the problem!
  • Dennis Burns
    Dennis Burns Apr 24, 2009
    Found everything was starting to thaw out. Unplugged freezer then plugged back in. Compressor continued to run and cool air was coming out of top vent. Put a thermometer in freezer and let it run overnight. Temp with all the mostly frozen food was only 30 degree F. Emptied freezer except for some thawed bread. Let it run all day and temp is about 35 degree F. Could the defrost sensor be bad.
  • 410 Answers
It could be that something in the defrost system is faulty. in the compressor area find your defrost timer, using a flat tip screwdriver advance the timer until you hear aloud audible click and the freezer shuts off. now wait a minute or two and feel for heat at the heater (careful it gets red hot) if the heater is on the timer is bad, if no heat you will need to check for continuity on the def thermostat and defrost heater to determine which is bad (most likely it will be the thermostat.)
i found this parts breakdown
that should help.
the def thermostat is item #11 on the evaporator and components page 9 and 10
good luck
Posted on Dec 16, 2007
Magic chef freezer model mcuf88w won't freeze
When you thawed it, did you remove ice from it using a metal object. That may have damaged the coils when would allow freon to leak out. This is too coincidental to be a problem itself with the compressor. The t'stat might be the problem. Try turning it off at the t'stat for a few minutes, then turn back on to the normal setting. Keep door closed for 30 minutes and check the inside and see if the walls are freezing. If not, you may have a compressor problem, or t'stat, or relay switch problem.
Feb 04, 2013 | Magic Chef Freezer. 8.8 cu. ft. Upright...
Ice buildup in bottom of freezer--puddle of water on floor
this sounds like your freezer is operating properly, except that the drainage of the water when going through the defrosting mode is not draining properly, pooling on the bottom of the freezer and then freezing. Check the drainage hose for the defrost in the lower pan. I would remove everything, place in ice chest, let the unit completely thaw out and then inspect. I hope this is beneficial.
Aug 05, 2009 | Freezers
I have a Frigidaire freezer LFFU1424DW not freezing. Came home to melting ice and thawed food. I heard clicking noise like a fan but goes off after a few seconds. Help please.
first of all unplug that freezer and wait for 15 mins. move it five feet from the wall. after 15mins, plug it back and kick in compressor at the same time!!!! remember plug and kick at the same time. the ckicking noise come from the starting relais. this says that the compressor has a problem. If it doesn't work ; you will have to call a service person who will replace the compressor for you.
Mar 10, 2012 | Frigidaire 14.1 cu. ft. Upright Freezer...
The top half of the upright freezer is totally thawed but the bottom is frozen. I need the whole thing to freeze.....
Check for ice on back wall if iced up check defrost heater and defrost timer also check and besure evaperator fan is working check wireharness on heater, timer, and evap. fan motor.Sounds like you have a defrost prob. Turn off for 24hrs to melt ice turn unit back on if it works for a few days then ices back up you have a defrost prob.
May 16, 2010 | Freezers
Not freezing
Check your circulatation fan. It may be stuck. Keep me informed The Raz Shack
Apr 20, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer model EV171NYMS04 we have ice build up on
There is a drain the back of the freezer that is frozen. Your trickle of water comes from the ice that melts off of the refrigeration coils during the defrost cycle. You need to turn off the freezer, then remove the rear cover from the back wall to expose the coils. With a hair dryer, melt all of the ice. You will find a drain under the coils. Melts all of the ice in this drain so water can get out of the freezer. When this drain is clear, you can put everything back together, and your freezer should work normally.
Mar 12, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Small upright freezer (4 cu ft) is leaking water
Could be just the coils are iced up, I would pull everything out of it, unplug for a day, plug back in and let it run....
Aug 22, 2009 | Freezers
Kenmore upright freezer
reason is that the evaporator is blocked with ice and hence no air circulation.
switch off for 24 hours with doors open
remove back panel inside freezer and melt ice off with a hairdryer
Oct 16, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezers Logo
2,176 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
