Question about Briggs & Stratton Garden
Same problem as above
OK, mower won't turn over, but I need more info as I'm not that repair-savy.
Where am I testing voltage? You said at the solenoid, does that mean remove the solenoid and clip to the wire that feeds it?
Also, that solenoid gets warm after turning the key several times. This would lead me to think it is getting voltage. I also hear the audible click at the solenoid when the key is turned. Is there a way to test this solenoid?
  • 389 Answers
You are absolutely correct, if you are hearing a clicking sound you are getting voltage.
Take one lead (red or black doesn't matter) of your jumper cables if you have them or a very heavy piece of wire and jump across the 2 large terminals of the solenoid while everything is still connected. If your starter cranks, your solenoid is bad.
You could also remove the solenoid and with a VOM meter and 2 jumper wires, test the solenoid by connecting the VOM to the 2 large posts and a 12 volt positive and negative source to the 2 small posts or if only 1 small post, positive to it and ground to the frame of the solenoid checking for continuity but the other way is quicker and easier. Oh Yeah, if you use a wire, don't hold it there very long, it can get HOT
Posted on Sep 23, 2009
I changed the main relay/ fuse on my 1999 ford escort sport zx2 and I still have the same problem. My brake lights, blinkers, radio, interior lights and locks do not work. What do I do now?
https://s9.postimg.org/cukz9jgv3/turn_brake.jpg
Click on the link
At the moment, I'm talking about turn signal and brake lites.
As far as brake lites, does the high mount brake lite work? If not, did it go out at the same time as the lower brake lites? The reason I ask, while both high mount and lower brake lamps get voltage from the same fuse, but, are wired differently. Did you check the fuse and check for voltage on fuse circuit using a test lite, hot all the time. You can also check the fuse above turn signal switch, that fuse circuit goes hot with the key on. As you can see the turn and lower brake voltage is wired through that flasher. I can't rule out a problem with flasher?
Jul 09, 2017 | Ford Cars & Trucks
PTO wont engage unless battery is charged up
Dale, it is normal for the PTO not to engage when voltage is low. Have battery and charging system diagnosed and repaired.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Charging System Battery Alternator Test Briggs FAQ
CHARGING SYSTEM MAINTENANCE
LAWN MOWER TRACTOR ZTR HOW TO TEST SMALL ENGINE VOLTAGE REGULATOR...
May 25, 2016 | Cub Cadet Garden
Mower won't start
Glenn, check the lawn mower engine trouble shooting links below for engines that do not start.
Top 5 Mower Troubleshooting Tips Briggs Stratton
Lawn Mower Won Start Here The FIX
May 07, 2016 | Garden
My gages won,t reset when I go to start my truck.when that happens it won,t start when thay reset it starts whats my problem to look at
Some instrument clusters may be able to self-test, it will turn warning lamps on and off, plus, sweep the gages, w/o outside input, meaning buss or serial data. If it passes that test, it is considered to be ok.
Yes, checking voltage and ground for instrument cluster is always a good idea, when problem is ongoing. At least, one voltage feed to instrument cluster should go hot with key on, could be problem in that area?
Are there any applicable trouble codes?
I can't look up much info w/o year--make--model?
Apr 23, 2016 | Cars & Trucks
I just asked about pto clutch o husqvarna gth2254xp. I should have said clutch turns but pulley does not with engine running.
If you are tech savy and have a volt meter then check to see if wires going to clutch have voltage. if yes then with" engine not running" check voltage again and if yes then take a screwdriver or such down near clutch and see if it is drawn towards clutch. The clutch is an electromagnet and if power is there then it may need distance adjustment per the manual.
Mar 24, 2015 | Husqvarna Garden
Dynamark riding lawn mower won't start, new battery but will not turn over?
use jumper cable to test the starter if ok jump the small wire at the solenoid to power and see if it kicks it over if yes check the safety switches
May 13, 2012 | Garden
Mtd riding mower won't start clicking noise
Take some sort of 12V tester and measure voltage on the small terminal on the starter to ground. You should get close to 12 V with key turned. If you see the 12 V, test the incoming large battery terminal. It should also be close to 12V. IF that's ok, check the large terminal on the starter. If you have 12V here, then check for bad ground connection. If any of these are not 12V remove cable and clean connection. How are you sure the battery is ok?
Jul 23, 2010 | Mtd FASTATTACH MANUAL SLEEVE HITCH
Blades stopped can't restart now engine won't turn over
Check battery voltage should be 12v or above. Battery could have gone bad or charging system bad. Voltage draw of electric clutch pulled battery down.
Sep 25, 2017 | John Deere 420,1020,2010,2020,2510,2520...
99 ACCORD BRAKE LIGHTS
ok well you start with the most common, obvious, and easiest to repair.
1. fuse
2. bulbs
3. bad relay
4. bad switch
5. open circuit
6. short
This is the best order to diagnose your problem with. not sure how electricly savy you are but my first test would be to check for voltage at the bulb. Get yourself a voltmeter, a test light might work but a volt meter can give you the exact reading. unplug the harness from the bulb or vise versa, have someone hold the brake down, stick your diodes into the terminals of the harness and get your reading. if no voltage pull some fuses... still nothin, my moneys on the wires...
Aug 19, 2009 | 1991 Honda Accord
Garden Logo
389 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
