Question about Garden
No pressure in hose
Engine runs great but no pressure
Why does it build pressure, but when I squeeze the trigger the engine stays at idle?
POSSIBLE this look picture hose coupling with water stop put on the tap side or lime in valves after long time or a nozzle with dirt close beaten
clogged nozzle on the lance
Bypass not working (lyme)
if you disconnect the lance and the handle grip is giving enough water and water comes out then the nozzle clean it with a little paperclip.25944841-me02dbjx1ofpduv3i0g3gg4u-5-0.jpg
Nov 06, 2015 | Garden
My 89 f-150 300,000 miles starts great runs great with good oil pressure never been hot loses power at times and will die when idling. the check engine light comes on immediately when this happens and
check all vacuum hoses for deterioration /hard /loose. Check power brake booster for air leaks with the foot on the brake (idle will drop or stall)
Nov 22, 2014 | 1989 Ford F 150
Aireated fuel after cold soak
check for a loose fuel line hose/connection that is allowing the fuel to drain back over time and filling the line with air that is causing a air lock when trying to start
Apr 08, 2014 | Ford F-250 Cars & Trucks
99 buick start easy then dies unless you give it gas. then stays running until you go to start again.
Check the fuel pressure regulator. It is on the drivers side, front of the engine near the throttle body. Remove the vacuum hose and see if fuel comes out of the nipple. If it does than the regulator needs to be replaced.
If the regulator is fine than you will need to check fuel pressure with a gauge. If fuel pressure drops as soon as you shut off the car than the fuel pump is likely bad.
Jul 26, 2012 | 1999 Buick Century
I bought a honda pressure washer power boss 3000. I load the gasoline, start the machine, but pressure water is not coming out from the trigger. i tried so many things , but can t get started.
If you are using a water tank for water supply, remove the water supply line from the pressure washer and connect a water hose from a faucet. Turn the water on, then crank the engine. Pull the trigger of the spray gun until water comes out. When then water starts to spray properly the release the trigger, shut engine down with pressure on the line then reconnect the water supply from the tank to the pressure washer. If this fixes the problem then the problem was "air-locked"! Happens alot with new pressure washers that have never been run. If you need any other help, please email me @ davidandlisacampbell@yahoo.com
Feb 18, 2011 | Honda Pressure Washer PSI 3000
My Honda GCV160 Pressure washer runs great, but isn't creating any pressure out of the nozzle. Not even a drop out of the wand. Its been on hiatus while I've been recovering from an injury for 3mos. It...
Take hose and gun off pump.
Start engine.
See if pressure comes out of pump.
Next, remove water hose and look at filter washer.
Clean or replace filter washer.
Turn on water and it should come out of pump on other side.
These steps will tell you if problem is water supply or pump.
Sometimes the problems happen because the gun lever is bad.
Hook up hose but not the gun
See if pressure comes out hous.
These steps will tell you if problem is gun or hose.
Oct 25, 2010 | Honda Garden
Engine runs great, when i turn the hose on it dies.if i hold the trigger and start engine it runs, as soon as i release trigger the engine dies
Make sure thre is no air lock in the system line. So first of all use a clean line to wash off and blow out any dirt in the spray gun.
make sure the engine is having good fuel and power it on to run and warm up . let it run over without any load on it . Now turn the hose on it and power it on slowing, do not stop but keep it running to power spray . The accumulated dirt might come off and make the run smooth after some time.
Sep 18, 2010 | Karcher 2500 PSI Pressure Washer
I have had my husky for about 2 years. Was using
you may have a broken or sheared pin. That being said I am stepping out of my comfort zone because I do not know that exact model but I have seen it happen to others. Any small engine shop should be able to repair it for a reasonable price.
Jul 22, 2010 | Garden
No pressure
you will have to try the following start up purge up onece with just water then start the powerwasher if that does'nt give u pressure ther is gaskets inside the pumping sometimes 4 to 8 of them these might be to wore down to hold pressure if u can locate the pump and desemable it run it to ur local dealer tell u need new gaskets put into it
Apr 09, 2010 | Porter Cable PCH3200 Commercial Pressure...
Gas driven portable pressure washer no longer draws chemicals up
Picks up under low pressure conditions by adjusting wand or changing tip.
Mar 18, 2009 | Honda Garden
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
