Question about Samsung Refrigerators
I have the samsung rb1944sl with digital temp control on front. refrig on top. the frig light went out and now the thing is beeping a warning sound the frig temp has risen to 59 degree but the freeze is still at 8 degree. does it have something to do with the lite out or the blue lite in the back top of frig. it's about 5 years old please help
I have the same problem and here is what I have found: The door switch is bad. I removed the switch (placed a screw driver under the left side and pried it off (see page 29 of http://www.thisoldappliance.com/library/Samsung_ref.pdf for a pic))
After I disconnected the switch, It worked. I am now off to find a new switch to order.
Hope this helps some one else as your original post is almost a year after mine.
Mike
Posted on Aug 17, 2010
My control wont let me change refrig side temp
Do you hear the fan running? The refer side doesn't have its own cooling. It gets it from the freezer. So if the fan doesn't work or the defrost doesn't work you will not cool the refer. Check two items. Defrost timer, fan
Jan 02, 2015 | Refrigerators
GE frig not cooling, both refrig and freezer. started with ice/water dispenser not working.
WR55X10942 Main Control Board This sounds like motherboard failure. I am not sure what your model number is but that will be important should you have someone to help repair your refrigerator. These problems are common on the Artica Profile Models. I will be here to help you repair if you should choose, Thanks Sea Breeze
Apr 24, 2013 | GE Refrigerators
Whirlpool Frig/Freezer - Frig side too warm at 60 degrees
Check for another fan to cool the fridge side. It could be bad.
murf427
Aug 01, 2012 | Whirlpool Refrigerators
OK, here's the problem - Samsung model RB1955SH - plug refrig in it cools both frig and freezer to desired settings - however, once system reaches stttings and turns off compressor, will not restart system...
the temp controller is bad in the fridge once it reaches cooling temp desired it cause the temp comtroller to go into a shut off mode due to being weak on the temp sensor tube
Jan 18, 2010 | Refrigerators
I have a frigidaire refrig--top freezer. It's my "overflow" refrig--so location is in garage. In SC we've had unreasonable cold for a couple weeks. And the freezer stopped freezing--I probably lost $200...
the thermastate in the frig compartment controls when the compresser comes on,it turns the compresser on at 38 degrees and off at 35 degrees,if the temp goes below 35 degrees the thermastat will no turn the compresser on.to save the food in the freezer you could of put the food in a trash can and put it outside.
Jan 13, 2010 | Frigidaire FRT21P5A Top Freezer...
My refrig. wont cool
It sound like your defrost system has a problem and each time you unplug, the frost goes away and thefrig works ok until frost builds up again. Yoou need to see if it is defrost timer, defrost coil, or defrost thermostat. Now you need to be a good tech person to find each item and know how to test each part. I'll tell you the coil and stat are in the back of the freezer compartment, the timer is either under the frig(front) or in the frig compartment near the cold control. goodluck, macgivor
Dec 27, 2009 | Samsung RM255LASH Side by Side...
No cold air blowing into the refrigerator - temp too low
You have your own answer there - You have overfrosting and icing up behind the freezer, this will affect proper cooling - also if you have seperate freezer and refrigerator controls, it's possible the damper is not opening properly to let the cool air in. But in your case it sounds like a defrost problem. You will need to have a service person inspect your control board and defrost timer components - sometimes it's as simple as a board replacement due to a burnt resistor these things are the most common causes.
Good luck
Sep 25, 2009 | Kenmore Refrigerators
Cooling did not resume after power outage
you need to do a reset on the control by pressing the two top buttons until it resets.
Mar 26, 2009 | Samsung SRS20DTD Side by Side Refrigerator
Programming code not working
Go to this web page to find the text answer below: http://www.fixya.com/support/t233614-reprogram_hv_board
HERE TIS RIGHT OFF THE INSTRUCTION SHEET.  THE TECH JUST LEFT. POWER UP REF. PROGRAM CODE IS LOCATED ON SERIAL PLATE ON THIS UNIT AFTER THE WORD CODE.-1. PRESS & HOLD THE DOOR ALARM KEYPAD.-2. PRESS & HOLD FREEZER TEMP DOWN KEYPAD.-3. RELEASE DOOR ALARM KEYPAD AND WAIT 3 :WILL DISPLAY PE TO INDICATE PROGRAMMING MODE-5. ENTRY IS CONFIRMED BY PRESSING TEMP DOWN - KEYPAD ONCE MORE.-CONTROL WILL DISPLAY CURRENT PROGRAM CODE. THIS VALUE SHOULD BE VALIDATED THE THE PROGRAM CODE PRINTED ON UNIT SERIAL PLATE.-NOTE: IF PROGRAM CODE IS CORRECT, THE PROGRAMMING MODE IS EXITED BY CLOSING THE FRIG DOOR.-7.PRESS REFRIG TEMP UP KEYPAD + OR REFRIG DOWN KEYPAD -TO CHANGE THE DIGIT VALUE WITH EACH KEY PRESS.-8.THE DECIMAL POINT INDICATES THE SELECTED DIGIT. PRESS THE FREEZER TEMP UP KEYPAD + TO SELECT NEXT DIGIT.-9.ONCE DEIRED PROGRAM CODE IS DISPLAYED, PRESS AND HOLD THE FREZZER TEMP DOWN KEYPAD - UNTIL UNIT PROGRAM CODE BEGINS FLASHING INDICATING IT HAS BEEN SAVED. *note* IF YOU ATTEMPT TO ENTER AN INVALID PROGRAM CODE, THE CONTROL WILL NOT SAVE THE NEW CODE, BUT WILL BEEP! (THE UNIT WILL NOT RUN RUN WITH A UNIT PROGRAM CODE OF 0000). ONCE THE PROGRAM CODE HAS BEEN SAVED THE PROGRAMMING MODE IS EXITED BY CLOSING THE FRIG DOORS.
Aug 03, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Samsung RS2533SW freezer not cooling problem
mine did the same thing. It was the mother board.
and guess what? they don't sell that motherboard anymore.
I will never buy Samsung again!
Nov 20, 2007 | Samsung 26.0 Cu. Ft. Side-by-Side...
Refrigerators Logo
511 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
