I have the Acer S2W 3300U , I am trying to install it into my System, Windows XP but I keep getting the message that it is not able to locate scanner, what do I do ? I seem to have every thing installed correctly. I have even uninstalled the en tire thing and re installed it still no luck. I also am trying to figure out where to turn it on for the power, I have it plugged in and connected to the usb cable as well, I even changed that as well. HELP!
While I am trying to scan the images, I am getting the error Code[ffff:0024] & I am unable...
(More)
While I am trying to scan the images, I am getting the error Code[ffff:0024] & I am unable to scan anything from Epson 1500 model. While I switch on the scanner, it sounds lot from the scanner for continuous 2 minutes. I couldn't get scanned anything ... please give me the solution.
Recently installed Vista and will not scan. Says "No profiles have been created. To create a...
(More)
Recently installed Vista and will not scan. Says "No profiles have been created. To create a new profile use the Mail Icon in the Control Panel"
1.s2w 3300u software did not download what is the problem 2.If it was downloaded then after what is...
(More)
1.s2w 3300u software did not download what is the problem 2.If it was downloaded then after what is the process to use the scanner
