Question about Rohl Plumbing
Rohl de' lux pull-out faucet r3810U-stn. The faucet spout no longer turns. The whole base will move slightly with a fair amount of pressure. 2 1/2 yrs old
Would it be cartridge or something else
Not the cartridge. There are O Rings around the spout that wear out. These need replacing. Call Rohl for replacement parts
www.rohlhome.com/warranty.aspx
Jul 07, 2014 | Rohl R77V3SPN Country Pull-Out Bar Faucet...
I have a leak coming out of the hole in the base of a Rohl pull-out faucet.
sounds like there's a kink in the line leading in,find the kink & unkink it,should help
Dec 08, 2013 | Rohl R3830-APC de Lux Pull Out Kitchen...
I have a R 3830 faucet and it does not change from spray to stream, it does both as the same time. Is there a rebuild kit for this problem, or what should I do to fix.
This function relies on water pressure. Remove the sprayer from the hose and check pressure. If good flow, replace the hand sprayer. If low flow from end of hose, remove hose from underside and check pressure going into hose. You may have blockage in the hose. Hose can be replaced by calling ROHL customer service at 800.777.9762
Mar 11, 2013 | Rohl R3830-APC de Lux Pull Out Kitchen...
How do you remove everything to clean it, the faucet wont swivel left to right anymore
Remove the handle and the retaining ring (nut) and pull the spout up and off you may need to replace the o-rings found there and lube the area with a good plumbers lube, reassemble and you will be good to go.
Mar 03, 2011 | Rohl R3830-APC de Lux Pull Out Kitchen...
How do you take the cap off of a Rohl R3810STN Single handle faucet??
Under the handle is a small cap/cover remove it and the handle set screw in right there.
Feb 13, 2011 | Rohl R3830-APC de Lux Pull Out Kitchen...
The fucet will no longer move from side to side
Take the handle off and remove the retainer cup remove the the spout clean and lube. If the faucet is very old I would go ahead and get a rebuild kit and do it all at one time.
Feb 06, 2011 | Rohl R3830-APC de Lux Pull Out Kitchen...
Single lever with pull out accessory sprayer. Too little flow from the main spout. The pull out sprayer has more pressure than the main spout. I suspect the diverter valve is the trouble. What is the...
The Diverters Parts is C7005. Here's the parts breakdown for your Rohl faucet. Contact Rohl and have them send you new diveter for free, the A3608 seriers came with a limited liftime warranty.
Sep 17, 2010 | Rohl A3608/11LMAPC Single Lever Country...
Plumbing Logo
99 people viewed this question
Top Rohl Plumbing Experts
obsteiner
john h
ray gallant
Are you a Rohl Plumbing Expert? Answer questions, earn points and help others
