Question about Refrigerators
LG ICEBEAM GRS512GC. Freezer cooling but fridge not cooling. Just had tech replacee fridge pcb with no sucess... any suggestions? thanks in advance :)
    Sergeant:
    Champion:
  • 255 Answers
Check to see if fan inside freezer is running.
is the evap coil in freezer froze up ?
if fan is running and coil is froze up u need a defrost timer.
Posted on Sep 24, 2009
  • jason king
    jason king Sep 24, 2009
    also check the heating element for proper Resistance.
Hi there I have an LG Icebeam Door Cooling fridge that doesnt seem to be working correctly. The fridge is not that cold and the freezer is defrosting on the top section. The light is on and it seems
Find your model # and put it in the search box here: http://www.lg.com/us/support . Once your fridge is showing, there is great troubleshooting info available. Also, armed with the model #, we can actually give you pertinent advice!
Nov 24, 2014 | LG Refrigerators
Could be your thermostat is defect, but even more likely the compressor is not working correct. Perhaps you even lost the cooling fluid. To be sure, please move everything as quick as you can to another fridge and ask a technician to have a look.
How to replace main circuit board
The circuit board is normally located at the back of the appliance, behind the metal grid along the bottom, unplug the appliance, unscrew the grid and the PCB mount, disconnect the pcb and swap with new one, then reassemble
Apr 10, 2014 | LG LRSC26930TT 36" 25.5 Cu. Ft....
Lg Icebeam Door Cooling fridge/freezer top of freezer not freezing
is the fan not working in it..may be jammed up..we had an old unit that did this all the time.. the door seal was bad allowing house humidity inside and it wpuld frost up so bad the fan got stuck..we eventually bought another used unit..
Jan 20, 2014 | LG Refrigerators
Error fs or f5
Here is the LG LRSC26930TT Service Manual=> HERE When using this manual scroll to page 28 in the PDF. Code fS is #1 abnormal Freezer Sensor, Freezer Sensor Short Circuit. Most likely the sensor needs replaced yet test can also be done to prove this fault as you read from Service Manual what and how to test. I will be here to answer any questions you may have. Here is a location=> LRSC26930TT Freezer Section part location 400A Sea Breeze
Part=> LRSC26930xx Freezer Sensor/Thermistor
I will be waiting should you have other Technical questions, Thanks, Sea Breeze
and Thanks, For Using Fixya
Jun 03, 2011 | LG LRSC26930TT 36" 25.5 Cu. Ft....
LG Fridge Icebeam Door Cooling Refrigerator Freezer is leaking water into very bottom of fridge. Fridge is only 6 years old. What could be the cause of this problem ? Many thanks for feedback.
lg ice beam refrigerator which has door cooling also is not cooling properly. the freezer is working there was ice accumulated in the rear corner of the freezer i defrosted but still the fridge is not cooling and there is a pool of water at the bottom most of the time. sometimes i see the fan inside the fridge is not working
Jan 11, 2011 | LG LRTN22310 Top Freezer Refrigerator
Our lg grs512gc fridge stinks, we think the drain hose could be clogged. Its not the contents and we have thoroughly cleaned the fridge. how to unplug?
use a syringe filled with clorine bleach to clear any drain holes.the smell will dissipate very quickly if the door is left open for 10 mins.
Oct 11, 2010 | LG Refrigerators
LG refrigerator not cooling
open your freezer and hold down your light switch see if you hear a fan running next look on the back wall of the freezer see if it has heavy frost and reply to me with answer but dont rate me till were done lol
Jan 02, 2008 | Refrigerators
LG icebeam door cooling
Normally the fans get turned off when you open the door so it does not blow all the cold air out. The fans should only run when the doors are closed. Push in the door switch and see if the fan works then (of course it has to be in the middle of a cooling cycle or the fans still won't run).
Dec 01, 2007 | Refrigerators
LG fridge suddenly stopped cooling.
If the fan inside the freezer is running and the compressor behind the fridge is running and is hot to touch, you have a gas problem or the compressor is inefficient. This can only be confirmed by connecting refrigeration gauges to the gas system and should only be performed by a fridge tech.
Nov 04, 2007 | Refrigerators
Refrigerators Logo
438 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
