Question about Alpine MRP-M1000 Car Audio Amplifier
How do i install mrp m1000 to two type r 12s step by step.
  • 655 Answers
Hello chadbcavanau,
See the link here for a step-by-step install with photos and amp wiring diagram.
First you need to purchase an amp wiring kit (minimum 4 gauge power and ground). If your vehicle is equipped with the stock radio, you'll also need to purchase a line output converter (LOC).
Hope this helps.
Posted on Sep 23, 2009
How do i get my 2 4ohm dvc type r's to 2 ohms for my mrp m1000 to get the full power?
ok its all in the way you wire them, just remember when you wire your speakers in series, the ohms build(add to eachother) which would make them total of 8 ohms, and if you wire in parrallel the ohm load cuts in half (2 ohms). So you want to wire them together in parrallel then run your wire to the amp. Just so you know though, if you bridge your amp, it will also cut the ohm load in half, so you would see total of 1 ohm which gives you more power, just make sure your amp is 1 ohm stable and your subs can handle it.
Oct 10, 2011 | Alpine MRP-M1000 Car Audio Amplifier
Will this amp push 2 2000 watt subs?
hope this helps.
caution
About Power supply wires (MRP-M1000 only)
• 21mm2 is the minimum power and ground cable size
that should be used to connect this amplifier. The
length of these cables should not exceed 1m to assure
safe operation.
• If the length of the power and ground cables exceed
1m, or if you connect more than one amplifier, a distribution
block should be used with 33mm2 or 53mm2
power and ground cables depending on the length
necessary. Ensure that you install a correctly-rated
in-line fuse on the power cable near the battery positive
post.
RMS Continuous Power (at 14.4 V, 20 - 200Hz)
• Per channel into 4 ohms (?1% THD+N)
MRP-M1000 ......................................... 600 W x 1
MRP-M500 ........................................... 300 W x 1
• Per channel into 2 ohms (?1% THD+N)
MRP-M1000 ....................................... 1000 W x 1
MRP-M500 ........................................... 500 W x 1
Total MAX Power
MRP-M1000 ............................................. 1900 W
MRP-M500 ............................................... 1100 W
S/N Ratio
• IHF A Weighted, Reference: rated power into
4 ohms .................................................... 100 dBA
Input Impedance
• RCA IN .................................................. 20k ohms
• SP IN .................................................... 40k ohms
Frequency Response (200Hz/ -3dB) ....... 20 - 200 Hz
Crossover Frequency .......... 50 - 200 Hz (-24dB/oct.)
Input Sensitivity (RCA IN) ............................ 0.2 - 4 V
Dimensions
• Width (Heat Sink/Footprint)
MRP-M1000
......... 320 mm (12 - 19/32")/380 mm (14 - 61/64")
MRP-M500
............... 210 mm (8 - 17/64")/270 mm (10 - 5/8")
• Height ..................................... 60 mm (2 - 23/64")
• Depth .................................... 242 mm (9 - 17/32")
Weight
MRP-M1000 ................................................ 4.2 kg
MRP-M500 .................................................. 2.7 k
Feb 04, 2011 | Alpine MRD-M1000 Car Audio Amplifier
I have two type-rs hooked up to a mrp-m1000 and its not hitting hard at all! but when one is hooked up it hits harder than two... so is it the way its hooked up or do i need another mrp-m1000 amp? or can i...
If the speakers are rated at 500W or greater, then you'll need two amps to get their full potential. When you connect two to a single 500W amp, each speaker only gets a max of 250W. Also, check the ohm rating for the outputs of the amp and the ohm rating of the speakers as well. Unmatches speaker/amp impendence also results in poor performance. If you connect two speakers to one terminal, the total impedence of the speakers falls by 1/2 (two 4 ohm speakers wire together will result in 2 ohm impedence). So, if you have an amp rated at 4 ohms, you could connect two 8 ohm speakers to a single output. Hope this helps some!
Feb 14, 2010 | Alpine MRP-M1000 Car Audio Amplifier
Hi ive got a alpine mrp-m1000 it lights up no sound was woking fine in the car didnt use car for 3 months then i wouldnt work all wires are fine and so is the sub please help
If your not getting any sound make sure the sub input is in the right spot on you radio. if not check the speaker wires on your harness
How do i hook up the mrp-m1000 to 2 type r subs since it is a one channel amp? the subs r 4 ohms so it should work right?
hook the positive to positive and negative to negative on both subs then run wire to the amp the amp will see a 2ohm load
Jan 07, 2010 | Alpine MRP-M1000 Car Audio Amplifier
No light on Alpine MRP-M1000
Ok. Have you check the Ground and the Power connection.
Jan 25, 2009 | Alpine MRP-M1000 Car Audio Amplifier
Bump
What do you mean it will bump, then cuts out?, Then you say it just wont't bump? Does it cut out after you go over a bump in the road, does the speaker bottom out and cuts out? Please you need to be a little bit clearer with the fault. and the symptoms.
May 28, 2008 | Alpine Type-R SWR-1222D Car Subwoofer
Alpine MRP-M1000 Car Audio Amplifier Logo
326 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
